Issues with 84 35FC
11-27-2006, 08:50
Issues with 84 35FC
Hi All,
After a trip out to my sisters and beyond, the Bird ran great, I just had a
couple of questions regarding and engine alarm light that keep coming on and
off...
All the vital signs of oil, oil temp, water temp, transmission temp and all
levels were up to where they are supposed to be... Does anyone have an idea why
this was happening???
Also a buzzer was going off from the day I first drove the Bus... I had the
digital multimeter out and was checking the bus=zzer, when I put the probes on
both terminals, it stopped buzzing, strange!!!
Any ideas on these issues??? Suggestions...
Also I put the coach in a storage facility and it is 50 miles from me now, I
need to know the group size of the Gen battery, as I will have to replace it, it
started to get weak when trying to start it yesterday, had to use the aux batt
switch...
Enough for now...
TIA
Sea Ya
Larry
84 35FCSB
NYC
Access over 1 million songs - Yahoo! Music Unlimited.
11-27-2006, 09:04
Issues with 84 35FC
Larry,
The size for the generator (4 cyl Perkins) on my coach is "group 31". Yours
could vary.
Steve Anderson
79 FC 35
Poulsbo, Wa.
-----Original Message-----
To: wanderlodgeforum@yahoogroups.com
Sent: Mon, 27 Nov 2006 12:50 PM
Subject: [WanderlodgeForum] Issues with 84 35FC
Hi All,
off...
switch...
Enough for now...
TIA
Sea Ya
Larry
84 35FCSB
NYC
________________________________________________________________________
Check out the new AOL. Most comprehensive set of free safety and security
tools, free access to millions of high-quality videos from across the web, free
AOL Mail and more.
11-27-2006, 09:53
Issues with 84 35FC
Larry- my 84 35FC had the intermitten buzzer come on, also. I checked all the
gauges and just surmised that it was another gremlin in the coach. Seemed to
phase out the longer I drove her.
83 PT40
Livingston, Montana
11-27-2006, 10:40
Issues with 84 35FC
Hi Larry:
Your engine alarm light intermittent is usually caused by the temp sensor
wire at the top of the radiator being broken or bad connector to ground.
There is a major stress point on the wiring harness that goes through the
frame on the drivers side. This is a common problem. The buzzer, depending
on which system it is for could be the sensor, or ground, I would bet on
the ground. It stops buzzing with the meter because your adding a
resistance through the meter and supplying a floating ground, so to speak
with the added resistance. On Bird's, when things are going haywire with
systems, one checks the grounds, then when nothing is found, one checks
grounds, then you repair it by fixing the ground.
Safe travels,
At 12:50 PM 11/27/2006 -0800, you wrote:
>Hi All,
>a couple of questions regarding and engine alarm light that keep coming on
>and off...
>all levels were up to where they are supposed to be... Does anyone have an
>idea why this was happening???
>the digital multimeter out and was checking the bus=zzer, when I put the
>probes on both terminals, it stopped buzzing, strange!!!
>I need to know the group size of the Gen battery, as I will have to
>replace it, it started to get weak when trying to start it yesterday, had
>to use the aux batt switch...
>Enough for now...
>TIA
>Sea Ya
>Larry
>84 35FCSB
>NYC
11-27-2006, 11:12
Issues with 84 35FC
Mine was doing the same thing when I bought it and a buzzer wire was cut. I
assume the
alarm light and buzzer are connected. All my levels were fine also. I stopped
doing it
after a while. I have no idea why. If you find the source of your problem, let
me know. I
anticipate mine will reoccur.
Kerry
82 FC 35
Denver
--- In WanderlodgeForum@yahoogroups.com, Larry wrote:
> Hi All,
couple of
questions regarding and engine alarm light that keep coming on and off...
levels were up
to where they are supposed to be... Does anyone have an idea why this was
happening???
digital
multimeter out and was checking the bus=zzer, when I put the probes on both
terminals,
need to know
the group size of the Gen battery, as I will have to replace it, it started to
get weak when
trying to start it yesterday, had to use the aux batt switch...
> Enough for now...
> TIA
> Sea Ya
> Larry
> 84 35FCSB
> NYC
11-27-2006, 12:40
Issues with 84 35FC
Lary,
Turn up the stereo, it will drown out that annoying buzzer.
Where is your storage facility? I am in New Jersey and have a 15 or
20 mile trip to my bird, near Greenwood Lake. I am not sure where
you are in NYC, but this one is about 12 miles from the thruway/287
interchange. $68/month, security cameras. The owner also runs an
excavation business out of the location so he has some skin in the
security game as well. It is outdoors, however.
Gardner
78FC33
> Hi All,
just had a couple of questions regarding and engine alarm light that
temp and all levels were up to where they are supposed to be... Does
anyone have an idea why this was happening???
I had the digital multimeter out and was checking the bus=zzer, when
I put the probes on both terminals, it stopped buzzing, strange!!!
me now, I need to know the group size of the Gen battery, as I will
have to replace it, it started to get weak when trying to start it
> Enough for now...
> TIA
> Sea Ya
> Larry
> 84 35FCSB
> NYC
11-27-2006, 12:59
Issues with 84 35FC
Gardner,
That's what I have been doing ;o)...
I am on City Island, The Bronx, NYC...
I store the coach in Chester, NY off of US 17, I only pay $70... Gated,
cameras, 6am - 8pm access 7 days/week...
Sea Ya
Larry
NYC
84 35FCSB
Gardner Yeaw wrote:
Lary,
Gardner
78FC33
> Hi All,
> Enough for now...
> TIA
> Sea Ya
> Larry
> 84 35FCSB
> NYC
Everyone is raving about the all-new Yahoo! Mail beta.
11-27-2006, 13:02
Issues with 84 35FC
Hi Ralph,
Thank you, I will check out that ground and all the other grounds...
Sea Ya
Larry
NYC
84 35FCSB
"Ralph L. Fullenwider" wrote:
Hi Larry:
Safe travels,
>Hi All,
>and off...
>Enough for now...
>TIA
>Sea Ya
>Larry
>84 35FCSB
>NYC
Check out the all-new Yahoo! Mail beta - Fire up a more powerful email and get
things done faster.
11-27-2006, 13:18
Issues with 84 35FC
Larry:
I don't know anything about FC's but I bet that bus=zzer will not bother you
again. It is most likely fried. Is the light still blinking, ie are the light
and buzzer related. Just a thought.
Please do not turn up the stereo it could cost you a bundle.
ouch.
Leroy Eckert
1990 WB-40 "Smoke N Mirrors"
Niceville, FL
Sent: Monday, November 27, 2006 6:40 PM
Subject: [WanderlodgeForum] Re: Issues with 84 35FC
Lary,
Gardner
78FC33
> Hi All,
> Enough for now...
> TIA
> Sea Ya
> Larry
> 84 35FCSB
> NYC
11-27-2006, 13:23
Issues with 84 35FC
Larry,
Mine isn't gated, but the main office building has a living
facility so I think there is someone there most of the time so it's
pretty safe. I haven't had any problems. They also store 18 wheeler
truck tractors and boats plus the normal storage facility buildings.
I am beginning to think I should store it closer to home since I
seem to bring it home every weekend to work on it. The mileage adds
up and with towing the Jeep I think I am spending more than the
extra cost of local storage.
Gardner
78FC33
> Gardner,
Gated, cameras, 6am - 8pm access 7 days/week...
> Sea Ya
> Larry
> NYC
> 84 35FCSB
> Gardner Yeaw
wrote: Lary,
or
where
thruway/287
> Gardner
> 78FC33
> > Hi All,
I
that
Does
Bus...
when
strange!!!
from
will
it
> > Enough for now...
> > TIA
> > Sea Ya
> > Larry
> > 84 35FCSB
> > NYC
