CRS
11-27-2006, 10:11
CRS
Gardner-- how many times have we left the block heater on~~~
83 PT40
Livingston, Montana
11-27-2006, 14:00
CRS
CRS (can't temember sh@#)
I was fixin my generator this weekend and when I tested it I turned
on all the breakers to check out all the 120 volt AC stuff. I had shut
some down cause I was tripping the 20 amp circuit at the house
connection. Like a real genius, I also turned on the hot water heater,
DUH, The water system is drained for the winter. I am hopeing there is
a sensor to protect the heater element when there is no water in the
system; Is that present on a '78? I won't be able to check it out
until this weekend, but if I smoked it, does anyone have a replacement
part number for the heater element?
Gardner
78FC33 (victem of an absent minded dufus)
11-27-2006, 14:18
CRS
Gardener,
Can't speak for the 78 but the 77 did not have a "no water, no heat"
system, so you may find an element with a downward bend. Seems simple
enough to do, use a pressure switch at the HWH, no pressure, no heat.
Can't help you with the element, maybe yours is still good?
Bob Janes, '87FC35, Greenville, SC
turned
shut
heater,
is
replacement
> Gardner
11-27-2006, 14:43
CRS
the best way to cure a crs injury is to pull the elemant and take it
to the rv supply house and match it up its also the easiest enew
elelment if needed is fairly inexpensive
Stephen 77fc35
--- In WanderlodgeForum@yahoogroups.com, "one_dusty_hoot"
> Gardener,
> turned
> shut
> heater,
> is
> the
> replacement
> > Gardner
11-27-2006, 23:21
CRS
>Stephen: sorry to bust in i need a sporan valve? repair kit.I hope
you still have my address where i bought the tv antenna.if not
please respond.
re brake
it
> Stephen 77fc35
> > Gardener,
heat"
simple
heat.
I
> > turned
had
> > shut
> > heater,
there
> > is
in
> > the
out
> > replacement
> > > Gardner
11-28-2006, 07:59
CRS
The block heater, in my opinion- and that of my neighbors- is an absolute
must in cold weather. You will eliminate most of the smoke-vs a cold start. It
also helps on the wear and tear.
83 PT40
Livingston, Montana
11-28-2006, 09:22
CRS
Gardner- thats cool- in fact- here in Montana- damn cold- 2 degrees and
"supposed" to drop to -14. I'm leaving here- if I'm not frozen to the ground
maybe
in less then a week.
83 PT40
Livingston, Montana
11-28-2006, 09:36
CRS
Terry- just took a nice hot shower in my coach. The only thing I need is a
thawed out "P" trap for the shower. Looks like I didn't put enough pink stuff
down there.
83 PT40
Livingston, Montana--but not for long!!!
11-28-2006, 12:19
CRS
Ernie,
I've never done that! But then, I've never used the block heater.
Gardner
> Ernie Ekberg
> 83 PT40
> Livingston, Montana
11-28-2006, 12:51
CRS
Since I don't have a 'no water' switch to protect the element, can
anyone give me a part number and description of what you have? I
know I will do it again, so why not head it off at the pass.
Gardner
78FC33
> Ernie,
heater.
> Gardner
> > Ernie Ekberg
> > 83 PT40
> > Livingston, Montana
