'81 FC air leak
11-27-2006, 13:55
'81 FC air leak
Howdy Crew,
Well, I got the Bird moved into its garage for the winter and when I
parked it, there was a sizeable air leak (noise) coming from the front
end. Upon investagation, I found the leak coming from whats looks like
a small vaccum solenoid that appears to be on the end of an air
manifold. It is on the drivers side, pretty much inside and just above
the step hole in the bumper. I think the manifold distributes air to
the suspension. The air is leaking out of a small (1/8") tube coming
out of the bottom of this gizmo. Any ideas? It's cold here and I
suppose an ice crystal could be in there, but what is this thing, what
does it do, why is it leaking air? What is the meaning of life. Any
and all input is appreciated. Doug Engel, Gunison,CO 1981 FC35SB
11-27-2006, 14:35
'81 FC air leak
I am thinking it might be the cruise control. Does the cruise work? My vacuum
unit set right behind the foot step of the bumper. I recently bought a new
vacuum unit from john blakey Motors but have not installed it as of yet. you can
take it off start the bird and see if it doesn't start leaking air at about 75
pounds. if you plug it it will go to regular pressure
re brake 1983 fc-35 sb " sagecoach"
> From: "doug_ngl"
> Date: 2006/11/27 Mon PM 08:55:00 EST
> Subject: [WanderlodgeForum] '81 FC air leak
> Howdy Crew,
11-27-2006, 14:42
'81 FC air leak
Doug,
It may be the vacuum generator for the cruise control. They use
the flow of air past an oriface to generate vacuum. I was told that
if it continues to leak then there may be a leak in the cruise
control system.
Gardner
78FC33
--- In WanderlodgeForum@yahoogroups.com, "doug_ngl"
> Howdy Crew,
when I
front
like
above
to
coming
what
Any
11-27-2006, 15:04
'81 FC air leak
Doug,
Mine does the same thing. I have an 81 as well. It's normal from what I read
on here.
There has been much talk about that noise on these forums recently--Kerry
will probably chime in.. I believe he took his vacuum generator out and
replaced the cruise control with another system. I am going to try to get
mine working here soon, by replacing all my vacuum lines going to and from
it.
Stephen H
81 FC-33SB
Plant City, FL
_____
[mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Gardner Yeaw
Sent: Monday, November 27, 2006 9:43 PM
Subject: [WanderlodgeForum] Re: '81 FC air leak
Doug,
control system.
Gardner
78FC33
> Howdy Crew,
when I
front
like
above
to
coming
what
Any
11-27-2006, 15:37
'81 FC air leak
Yep, it's the vacuum generator. You've been messing with the cruise control
haven't you!!
If there's a leak in the cruise control system, it will cause the generator to
bleed off. It also
could be bad vacuum generator. They are NO LONGER AVAILABLE. Plug the main
line
coming out of generator and see if the leak stops. If it does, there's a leak
somewhere up
in the cruise control system.
kerry
82
fc 35
Denver
--- In WanderlodgeForum@yahoogroups.com, "Gardner Yeaw" wrote:
> Doug,
> control system.
> Gardner
> 78FC33
> > Howdy Crew,
> when I
> front
> like
> above
> to
> coming
> what
> Any
11-27-2006, 15:40
'81 FC air leak
Are you saying you found a replacement vacuum generator? If so, can you give me
phone number or website for the source. Everyone I checked with said they are
no longer
available and I'm about to install an electric cruise.
Kerry
82 FC 35
Denver
unit set
right behind the foot step of the bumper. I recently bought a new vacuum unit
from john
blakey Motors but have not installed it as of yet. you can take it off start the
bird and see if
it doesn't start leaking air at about 75 pounds. if you plug it it will go to
regular pressure
> > From: "doug_ngl"
> > Howdy Crew,
11-27-2006, 23:14
'81 FC air leak
I think you can get a replacement vacuum from john bleckly motors in macon. i
will get the name and number of the contact and send on.
re brake "sagecoach"
> From: "davidkerryedwards"
> Date: 2006/11/27 Mon PM 10:37:45 EST
haven't you!!
bleed off. It also
line
somewhere up
> kerry
> 82
> fc 35
> Denver
> > Doug,
> > control system.
> > Gardner
> > 78FC33
> > wrote:
> > > Howdy Crew,
> > when I
> > front
> > like
> > above
> > to
> > coming
> > what
> > Any
Loading...
