1985 FC water problem
04-26-2005, 05:49
I finally was able to water and sanitized the water system. No leaks,
after that winter !!!! The problem that I have is in the hot water system . No water hot or otherwise.I have tried to follow the manual.I would appriciate if anyone could help me. I'm that close to taking a (first)short trip. Mario 1985 FC |
04-26-2005, 06:00
Mario,
While not a standard feature on your Wanderlodge, someone may have installed a water heater bypass circuit in the plumbing to assist with winterizing the coach. Assuming you have the side bath model, I'd pull up the bed (road side if you have twins) and follow along the plumbing near the water heater. If there are valves, turn them to the logical position to allow flow through the heater. Gary Miller 83 FC 33 Wauwatosa, WI --- In WanderlodgeForum@yahoogroups.com, "ssyd1" <ssyd1@y...> wrote: > > I finally was able to water and sanitized the water system. No leaks, > after that winter !!!! > The problem that I have is in the hot water system . No water hot or > otherwise.I have tried to follow the manual.I would appriciate if > anyone could help me. I'm that close to taking a (first)short trip. > Mario 1985 FC |
