Cold weather camping
12-03-2006, 06:47
Hi Bob- it's all VFR now!!! Ernie- in Co
[Non-text portions of this message have been removed] |
12-03-2006, 07:16
Hi Doug- it was a bit frustrating trying to figure out some of these things
that normally wouldn't crop up. Maybe I'm just ready to be home after 6 months~Ernie- 83PT40- only one at KOA in Limon, Co [Non-text portions of this message have been removed] |
12-03-2006, 07:44
Hank- if you hit the big one- send Brenda and I a ticket. Ernie-83PT40 in Co
12-03-2006, 07:50
Doug, I live in Weatherford, Tx.Work in Montana and fulltime in my coach
while there. I was in La during the winter months. I hope to get some flooring work while I'm south till I head back north next spring. Ernie-83PT40, temporarily in Limon, Co [Non-text portions of this message have been removed] |
12-03-2006, 08:16
Doug, will go to the Mesquite Pit when I get home. Flying P is north of
where we live in Weatherford. Ernie- 83PT40- in Co, behind the FlyingJ-- all i see are the lites on the trailers [Non-text portions of this message have been removed] |
12-03-2006, 11:08
NEVER AGAIN!!!-- I have been subjected to the extreme- well, to me, and
my coach, for the last week. Wind, snow, ice, and temps close to zero wreck havoc on things you never think about. Yesterday, after leaving Livingston, my susp dump lite was flickering. No problem- usually corrects itself in due time. Noticed the front air gauge cycling between 90 and 125. Pulled off the road and listened- couldn't hear anything. Got to Billings to a Freightliner shop and parked way out in parking lot. After talking to Steve Gureasko, Bim Burt, and Terry Neal, i performed some tests. Luckily one of those was dumping the air out of the suspension- it WORKS!! Drove to Kaycee, Wy and spent the nite. Got up, fired the coach and air was leaking from valve on accelerator. What next? Messed with that and finally that worked. I guess all the extremely cold temps froze up things- other then my shower drain and all fresh water, holding tanks, etc. Hopefully, will be able to drive out of this cold tomorrow. Ernie-83PT40, Limon, Co- KOA wifi |
12-03-2006, 11:31
Hey Ernest, We're pullin fer you ! Sounds like your going 287 home,
watch that section thru Oklahoma, it's bad when it's good. Your getting really close hang in there......Bob & Carol PS..Keep you AIRSPEED up and watch those tight TURNS...ha In WanderlodgeForum@yahoogroups.com, "Ernest Ekberg" > > NEVER AGAIN!!!-- I have been subjected to the extreme- well, to me, and > my coach, for the last week. Wind, snow, ice, and temps close to zero > wreck havoc on things you never think about. > Yesterday, after leaving Livingston, my susp dump lite was flickering. > No problem- usually corrects itself in due time. Noticed the front air > gauge cycling between 90 and 125. Pulled off the road and listened- > couldn't hear anything. Got to Billings to a Freightliner shop and > parked way out in parking lot. After talking to Steve Gureasko, Bim > Burt, and Terry Neal, i performed some tests. Luckily one of those was > dumping the air out of the suspension- it WORKS!! > Drove to Kaycee, Wy and spent the nite. Got up, fired the coach and air > was leaking from valve on accelerator. What next? > Messed with that and finally that worked. I guess all the extremely > cold temps froze up things- other then my shower drain and all fresh > water, holding tanks, etc. > Hopefully, will be able to drive out of this cold tomorrow. > Ernie-83PT40, Limon, Co- KOA wifi > |
12-03-2006, 12:06
Ernie, Sorry to hear about the problems, but join the club. We drove 'Pokey"
home from Tampa into freezing weather, and now sub zero temps. I have set up a aux. air connection to air the rig up off or shop air while I look for leaks. My LH air gauge leaks down pretty fast, but I can't find the leak. Seems like every time I crawl under, I find a new one. Tighten fittings, snug up flanges, replace valves, and still I lose air. Hopefully most of your woes will remedy themselves when you reach warmer temps. I do know that moisture in your air system will let air crystals form and create leaks in blowoff valves like at your dryer. Glad you visited, but you'll probably be happy when you're out of here. Doug Engel, Gunnison, CO, 1981 FC35SB "Pokey" Ernest Ekberg NEVER AGAIN!!!-- I have been subjected to the extreme- well, to me, and my coach, for the last week. Wind, snow, ice, and temps close to zero wreck havoc on things you never think about. Yesterday, after leaving Livingston, my susp dump lite was flickering. No problem- usually corrects itself in due time. Noticed the front air gauge cycling between 90 and 125. Pulled off the road and listened- couldn't hear anything. Got to Billings to a Freightliner shop and parked way out in parking lot. After talking to Steve Gureasko, Bim Burt, and Terry Neal, i performed some tests. Luckily one of those was dumping the air out of the suspension- it WORKS!! Drove to Kaycee, Wy and spent the nite. Got up, fired the coach and air was leaking from valve on accelerator. What next? Messed with that and finally that worked. I guess all the extremely cold temps froze up things- other then my shower drain and all fresh water, holding tanks, etc. Hopefully, will be able to drive out of this cold tomorrow. Ernie-83PT40, Limon, Co- KOA wifi --------------------------------- Everyone is raving about the all-new Yahoo! Mail beta. [Non-text portions of this message have been removed] |
12-03-2006, 12:29
---Ernie: Come out of that cold and come to Melbourne,
Australia...SUMMER here! Also, the Aussie Millions" poker tourney starts in a few weeks. Regards mates! Hank the yank Hannigan 90SP36 80FC31...FOR SALE $31,000 BOTH in storage in Vegas until we return home in late January In WanderlodgeForum@yahoogroups.com, "Bob & Carol Howald`" > > Hey Ernest, We're pullin fer you ! Sounds like your going 287 home, > watch that section thru Oklahoma, it's bad when it's good. Your > getting really close hang in there......Bob & Carol PS..Keep you > AIRSPEED up and watch those tight TURNS...ha > > > > > > > In WanderlodgeForum@yahoogroups.com, "Ernest Ekberg" > > > > > NEVER AGAIN!!!-- I have been subjected to the extreme- well, to me, > and > > my coach, for the last week. Wind, snow, ice, and temps close to > zero > > wreck havoc on things you never think about. > > Yesterday, after leaving Livingston, my susp dump lite was > flickering. > > No problem- usually corrects itself in due time. Noticed the front > air > > gauge cycling between 90 and 125. Pulled off the road and listened- > > couldn't hear anything. Got to Billings to a Freightliner shop and > > parked way out in parking lot. After talking to Steve Gureasko, Bim > > Burt, and Terry Neal, i performed some tests. Luckily one of those > was > > dumping the air out of the suspension- it WORKS!! > > Drove to Kaycee, Wy and spent the nite. Got up, fired the coach and > air > > was leaking from valve on accelerator. What next? > > Messed with that and finally that worked. I guess all the extremely > > cold temps froze up things- other then my shower drain and all > fresh > > water, holding tanks, etc. > > Hopefully, will be able to drive out of this cold tomorrow. > > Ernie-83PT40, Limon, Co- KOA wifi > > > |
12-03-2006, 12:36
Hang in there, sounds like you nearly got it made. Where are you headed? Doug
erniecarpet@... wrote: Hi Doug- it was a bit frustrating trying to figure out some of these things that normally wouldn't crop up. Maybe I'm just ready to be home after 6 months~Ernie- 83PT40- only one at KOA in Limon, Co [Non-text portions of this message have been removed] Doug Engel, Gunnison, CO. 1981 FC35SB "Pokey" --------------------------------- Want to start your own business? Learn how on Yahoo! Small Business. [Non-text portions of this message have been removed] |
