Hitch Extender Adapter
12-03-2006, 07:09
Hey guys, when Steve Gureasko arrives home tonite from the Galveston rally,
he can chime in on your question. We installed one for his neighbor this past
spring. I don't remember what it was but it was a heavy duty extension.
Ernie-83PT40 in Co going to Texas
12-03-2006, 11:51
Hello everyone. We're looking for a mount for a bike rack. We know
what bike rack we want (Thule T2) and we want to mount it on the back
of the coach. But we can't mount the bike rack and tow the car at the
same time without an adapter.
We have seen such an adapter. Its called a 2" Dual Tow Hitch
Extension Receiver Adapter. It is an extension for our tow bar and
has another tow bar receiver welded on the side. With it we can tow
the car AND have a hitch mount bike rack on the back of the coach. We
found the adapter at toolprice.com SKU: 9164P. But that one is rated
for 4000 lbs and we tow a Honda Pilot – 4500 lbs. Does anyone know of
one off the shelf? Has anyone had one fabricated? All thoughts
welcome.
Pen Sand & Jim O'Connor
'83 PT 35
Yuma AZ this week (70's and sunny)
12-03-2006, 12:12
Jim, Having worked at the local welding shop and seen many "extensions", I can
say I have never seen one that I thought looked like a good idea. How about
putting the rack of your choice on the back of the Pilot? Doug
jimocon wrote: Hello everyone. We're looking for
welcome.
'83 PT 35
Doug Engel, Gunnison, CO. 1981 FC35SB "Pokey"
Cheap Talk? Check out Yahoo! Messenger's low PC-to-Phone call rates.
12-03-2006, 12:51
TrailerHitches.com has several "towing racks" listed -- with class 3
and 4 hitches. It notes that the "hitch's towing capacity is reduced
by half when using towing racks."
A class 4, nominally a 10,000 lb. hitch would then be rated at 5000 lbs.
See <http://www.trailerhitches.com/carriers/b...ducts.cfm?
action=view&key=CE716> for details.
Might a rack that attaches to the ladder be better for you? See
< http://www.jcwhitney.com/autoparts/Produ...-10101/Pr-
p_Product.CATENTRY_ID:2007103/p-2007103/N-111+600005760/c-10107> for
one example. Or, <http://www.toplinemfg.com/html/rv-
ladderbikerk.html> for another.
aeonix1@...
El Sobrante, CA
> "extensions", I can say I have never seen one that I thought looked
> like a good idea. How about putting the rack of your choice on the
> welcome.
> '83 PT 35
12-03-2006, 12:58
Cabelas.com has a very nice one for $60. Perfect for a bike rack.
Brent
77fc31
Ventura,CA
--- In WanderlodgeForum@yahoogroups.com, "jimocon"
know
back
tow
coach. We
rated
know of
> welcome.
> '83 PT 35
12-03-2006, 13:03
I had the same problem. Solved it by taking bike rack which had square to
accomidate extender and then welded a piece of 1&1/2 x6" steel on the bottom of
the rack and drilling two holes to take bolts with lock nuts which fit over the
extender and then was clamped to the extender by running the bolts through
another identical piece of steel on the underside of the extender.
I know that this sounds like a "rube goldberg" solution, but it actually
worked and the load was not an issue since it was not affected. If this does not
make any sense you can call me at 817 221-2404.
welcome.
'83 PT 35
Yahoo! Groups Links
Wallace Craig
95 WLWB 42
Azle, Texas
12-03-2006, 13:27
I've got one that I use when I pull our 4 dr Sidekick. The hitch extension part
is very heavy
duty. It's as strong as any hitch material I've seen. The top section that
holds the bike
rack is much less heavy duty. I suspect the downrating of the hitch is because
the hitch is
extended further away from the vehicle limiting the amount of the tongue weight
on the
extension. I wouldn't think it would make much of a difference when towing
since there is
very little tongue weight. It would roughly be equivalent to extending your tow
bar by an
additional 18 inches, which, as far as I can see, would make virtually no
difference at all in
the amount you could tow.
Kerry
82 Fc 35
Denver
> welcome.
> '83 PT 35
12-03-2006, 13:30
Blue Ox are rated at 10,000 lbs. I use one of the drop recievers,
they also have straight extensions. I ordered from towing world.
http://www.blueox.us/Accessories/droprcvrs.htm
http://www.blueox.us/Accessories/bikeracks.htm
http://www.towingworld.com/Accessories/d...eivers.htm
Dan
94 BMC 37'
know
back
tow
We
rated
of
> welcome.
> '83 PT 35
12-03-2006, 13:30
Another solution I've seen is to weld another receiver to the top of
the one on your coach, use the top one for your bike rack and the
original receiver for your dinghy.
- Jeff Miller
in Holland, MI
--- In WanderlodgeForum@yahoogroups.com, Wallace Craig
square to accomidate extender and then welded a piece of 1&1/2 x6"
steel on the bottom of the rack and drilling two holes to take bolts
with lock nuts which fit over the extender and then was clamped to
the extender by running the bolts through another identical piece of
actually worked and the load was not an issue since it was not
affected. If this does not make any sense you can call me at 817 221-
2404.
know
back
We
rated
of
> welcome.
> '83 PT 35
> Yahoo! Groups Links
> Wallace Craig
> 95 WLWB 42
> Azle, Texas
12-03-2006, 13:38
This is the one I use:
http://www.northerntool.com/webapp/wcs/s...929_492929
Kerry
part is very
heavy
holds the bike
because the hitch
is
weight on the
since there
is
tow bar by
an
difference at all
in
> Kerry
> 82 Fc 35
> Denver
> > welcome.
> > '83 PT 35
