Back up Monitor System
12-03-2006, 14:48
Hi Everyone,
My back up camera went out on my coach. I want to replace both the
camera and the monitor as the monitor picture area was getting smaller
and smaller and I figured the monitor is giving out. The monitor is a
small tv tube that has a myriad of wires going to a circular plug that
plugs into the back of the tube. I'm wondering if anyone has replaced
this style system with a newer system and if a new cable needs to be
run from front to back of coach or if the current cable can be used
with appropriate adapters?
Any advice anyone can give will be appreciated.
Thanks,
Randy Merrill
1993 40 WLWB
Ocala, FL
12-03-2006, 15:09
I and a others have had good success using http://www.rvcams.com
Tim is very knowledgeable and will work with you to put a system together
that will work. I've posted before on my installation of camera and monitor
so it should be in the archieves somewhere.
On 03/12/06, Randy Merrill wrote:
> Hi Everyone,
> Thanks,
> Randy Merrill
> 1993 40 WLWB
> Ocala, FL
Rob, Sue & Merlin Robinson
94 WLWB
12-03-2006, 15:55
Check out the pics on the wanderlodge forum.
My LCD/Camera upgrade pics are there.. I love my new color setup and the new
low-light CCD cameras now-days are far superior than the old tube cameras.
Stephen
81-FC-33SB Plant City, FL
_____
[mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Randy Merrill
Sent: Sunday, December 03, 2006 9:49 PM
Subject: [WanderlodgeForum] Back up Monitor System
Hi Everyone,
Thanks,
Randy Merrill
1993 40 WLWB
Ocala, FL
12-04-2006, 05:12
Hi,
I used an Audiovox system Camera moves low light function, several
possible inputs (cameras) color lcd. I got a piece of plexi cut to
fit in old crt location and mounted the lcd to it...worked
great..hardest part pulling the new wire from the rear of
coach..Camera fit in the original location..
Jim
88WLWB XXV
Stuart, Fl
--- In WanderlodgeForum@yahoogroups.com, "Randy Merrill"
> Hi Everyone,
smaller
a
that
replaced
be
> Thanks,
> Randy Merrill
> 1993 40 WLWB
> Ocala, FL
