Cold weather camping, part 2
12-04-2006, 07:46
Thanks Hank, its good to be almost home. Ernie-83PT40 in Texas- Amarillo,
that is
12-04-2006, 07:54
Kerry- I have been there. I spent from 67- 90 in Lubbock, in the Air Force
and in private life. Worked all over West Texas- in 90 we moved east to get
away from the blowing dust and relatives.
12-04-2006, 07:56
Tom, you may be correct. i have noticed that when the dryer blows off, there
is a little more air coming through. It used to blow off then quit- no more
air. Since I'll be home for a while, I can address this issue without lying
on ice~ ernie -83PT40 in Texas
12-04-2006, 08:17
Hi Steve- thanks for your input. Glad to know that I'm not the only one that
has cold weather issues. Wish we could figure a way around the cold- other
then going south.
I know that the water line runs are enclosed and that no warm air can get
to them. I wonder if there is something better then heat tape to help us out?
If Nasa can go in space~ ernie- 83PT40 in Texas- water lines thawed- holding
tanks- not
12-04-2006, 09:14
I believe it was that cold.~ Ernie-83PT40 in Texas
12-04-2006, 10:33
Arrived in Amarillo, Tx this afternoon. Came off the freeway and slush
came off the roof. I suspect that it took 1000 miles south to actually
thaw that out. My new step valve had been acting up- it would operate
the step, but expell large volumes of air in the retract position. So
for 1000 miles- it was in the extend position. Today- I retracted it-
and no air expelled. Probably that was frozen, too. It will take many
days for my holding tanks to thaw.
Ernie Ekberg-83PT40 in Amarillo- almost thawed out
12-04-2006, 12:31
Sounds like you had water in your air lines. I would suspect that
your air dryer needs a new dissicant pack and maybe a spitter valve.
tom warner
vernon center,ny
>Yahoo! Groups Links
12-04-2006, 12:39
---ERNIE:
No doubt these birds shutter in cold weather...a few years ago, I
took the 90SP to Chicago in the "winter" and I noticed radiator
fluid in the driveway...had to tighten many hoses to stop the flow.
Now I keep the birds in warm weather...Vegas is hot & dry and nice
in winter for birds.
Glad to see you made it back to TEXAS..hookem horns!!! I can say
that being a tesip 1970!!
Regards,
Hank Hannigan
90SP36
80FC31
In WanderlodgeForum@yahoogroups.com, "Ernest Ekberg"
slush
actually
operate
So
it-
many
12-04-2006, 12:42
There's a really good Museum of the Plains (?) in the town just south of
Amarillo where one
would turn to go to Palo Duro Canyon (itself a nice camping place with a very
steep road into
the Canyon.) Lots of interesting historical material on the development of oil
in that part of
the world. Worth a stop.
Kerry
82 FC 35
Denver
--- In WanderlodgeForum@yahoogroups.com, "Ernest Ekberg"
12-04-2006, 12:52
http://www.panhandleplains.org/about/about_pphm.php
Amarillo where
one
steep road
into
oil in that
part of
> Kerry
> 82 FC 35
> Denver
