one more question
12-06-2006, 15:03
one more question
Above the stering wheel on a 83FC Their is a tv, generator start
button, radio, and somthing called a (safe line) switch. what is this switch? |
12-07-2006, 02:50
one more question
The Safe Line will buzz or flash a light if you start the engine with
the shore power cord plugged in to power. The switch selects either the light or the buzzer. - Jeff Miller in Holland, MI --- In WanderlodgeForum@yahoogroups.com, "divadcrockett" > > Above the stering wheel on a 83FC Their is a tv, generator start > button, radio, and somthing called a (safe line) switch. what is this > switch? > |
12-07-2006, 03:23
one more question
If my memory is correct, that switch turns off the annoying buzzer that
sounds when the engine is running but the coach is still plugged into shore power. Phil Olson Appleton,WI 83FC35SB --- In WanderlodgeForum@yahoogroups.com, "divadcrockett" > > Above the stering wheel on a 83FC Their is a tv, generator start > button, radio, and somthing called a (safe line) switch. what is this > switch? > |
