Hot water and boondocking
12-11-2006, 08:44
I have a system such as you describe in my home. A small pump and timer
(110 volt) in the water hot water line circulates the hot water throughout the house, so hot water is available at each faucet when it is turned on. The timer can be set like a light timer, so it does not circulate at night. Roger Webb 91WBWL Cedar Rapids, IA [Non-text portions of this message have been removed] |
12-11-2006, 13:24
We took a 4 day trip and had only power available. I left with a
full water tank and mostly empty grey and black tanks. By the last day I had about 1/4 tank of water left. I began to think about ways to conserve water to streach the time we could stay. One thought was the waste of water waiting for the sink or shower hot water to come up to temperature. It was cold outside so it took a while, wasted water and holding tank capacity. In hotels/motels/large buildings they use a circulating system that keeps the hot water supply hot so you don't wait for hot water at the tub or tap. It would seem that this could be done in an RV by adding a return line from the far end of the hot water system, a one- way valve and a pump. Then all you would need to do is activate the pump for a minute or so to charge the system, and then start the shower. It would conserve the water supply as well as the grey tank space. Has anyone seen this kind of system in use? Gardner 78FC33 |
12-11-2006, 13:34
Gardner,
I'm all ears for this. Had the same thought while out camping this past weekend. Thanks for posting. Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, Calif. Gardner Yeaw wrote: > We took a 4 day trip and had only power available. I left with a >full water tank and mostly empty grey and black tanks. By the last >day I had about 1/4 tank of water left. I began to think about ways >to conserve water to streach the time we could stay. One thought was >the waste of water waiting for the sink or shower hot water to come >up to temperature. It was cold outside so it took a while, wasted >water and holding tank capacity. > > In hotels/motels/large buildings they use a circulating system >that keeps the hot water supply hot so you don't wait for hot water >at the tub or tap. It would seem that this could be done in an RV by >adding a return line from the far end of the hot water system, a one- >way valve and a pump. Then all you would need to do is activate the >pump for a minute or so to charge the system, and then start the >shower. It would conserve the water supply as well as the grey tank >space. > > Has anyone seen this kind of system in use? > >Gardner >78FC33 > > > > >Yahoo! Groups Links > > > > > > |
12-11-2006, 13:44
One easy water saver is a recirculating toilet. I had one in my previous Travco
and really liked it. I haven't seen a hot water recirculating system on an RV. You could catch the cold water in a pan and use it to wash dishes etc. Kerry 82 FC 35 Denver --- In WanderlodgeForum@yahoogroups.com, "Gardner Yeaw" > > We took a 4 day trip and had only power available. I left with a > full water tank and mostly empty grey and black tanks. By the last > day I had about 1/4 tank of water left. I began to think about ways > to conserve water to streach the time we could stay. One thought was > the waste of water waiting for the sink or shower hot water to come > up to temperature. It was cold outside so it took a while, wasted > water and holding tank capacity. > > In hotels/motels/large buildings they use a circulating system > that keeps the hot water supply hot so you don't wait for hot water > at the tub or tap. It would seem that this could be done in an RV by > adding a return line from the far end of the hot water system, a one- > way valve and a pump. Then all you would need to do is activate the > pump for a minute or so to charge the system, and then start the > shower. It would conserve the water supply as well as the grey tank > space. > > Has anyone seen this kind of system in use? > > Gardner > 78FC33 > |
12-11-2006, 14:01
Gardner,
Form my post last night: It seems like Kathy and are in cold weather a lot and many times dry camping. I hated to waste water getting hot water to the shower so I routed a return line from the shower back to the water heater. I then placed a relay on the pressure control switch of the primary pump to control both pumps. If the primary pump is running the recirculation pump is off. If pressure is up and the primary pump shuts off then the recirculation pump runs. When you turn the pump switch on before stepping into the shower you have instant hot water. It works well for it's intended purpose to conserve water but I don't believe that it would keep the cold water side from freezing. - Chuck Wheeler - 82 FC 31 SB Fort Worth, TX _____ From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Gardner Yeaw Sent: Monday, December 11, 2006 7:25 PM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Hot water and boondocking We took a 4 day trip and had only power available. I left with a full water tank and mostly empty grey and black tanks. By the last day I had about 1/4 tank of water left. I began to think about ways to conserve water to streach the time we could stay. One thought was the waste of water waiting for the sink or shower hot water to come up to temperature. It was cold outside so it took a while, wasted water and holding tank capacity. In hotels/motels/large buildings they use a circulating system that keeps the hot water supply hot so you don't wait for hot water at the tub or tap. It would seem that this could be done in an RV by adding a return line from the far end of the hot water system, a one- way valve and a pump. Then all you would need to do is activate the pump for a minute or so to charge the system, and then start the shower. It would conserve the water supply as well as the grey tank space. Has anyone seen this kind of system in use? Gardner 78FC33 [Non-text portions of this message have been removed] |
12-11-2006, 14:19
Chuck,
Thanks. By the way, My wife's name is Kathy also, so it seems that wives named Kathy like the solution, so it must be a winner. I like the idea of using relays so that the pumps don't fight each other. I have a similar relay logic system in my home. The garage and bedroom share the same supply side for the hot water heating system, so I built a relay logic system that gives the bedroom priority. A little boolean logic and some radio shack relays and you are in business. Gardner 78FC33 --- In WanderlodgeForum@yahoogroups.com, "Chuck winner. > > Gardner, > > Form my post last night: > > It seems like Kathy and are in cold weather a lot and many times dry > camping. I hated to waste water getting hot water to the shower so I routed > a return line from the shower back to the water heater. I then placed a > relay on the pressure control switch of the primary pump to control both > pumps. If the primary pump is running the recirculation pump is off. If > pressure is up and the primary pump shuts off then the recirculation pump > runs. When you turn the pump switch on before stepping into the shower you > have instant hot water. It works well for it's intended purpose to conserve > water but I don't believe that it would keep the cold water side from > freezing. > > > - Chuck Wheeler - > 82 FC 31 SB > Fort Worth, TX > > > _____ > > From: WanderlodgeForum@yahoogroups.com > [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Gardner Yeaw > Sent: Monday, December 11, 2006 7:25 PM > To: WanderlodgeForum@yahoogroups.com > Subject: [WanderlodgeForum] Hot water and boondocking > > > > We took a 4 day trip and had only power available. I left with a > full water tank and mostly empty grey and black tanks. By the last > day I had about 1/4 tank of water left. I began to think about ways > to conserve water to streach the time we could stay. One thought was > the waste of water waiting for the sink or shower hot water to come > up to temperature. It was cold outside so it took a while, wasted > water and holding tank capacity. > > In hotels/motels/large buildings they use a circulating system > that keeps the hot water supply hot so you don't wait for hot water > at the tub or tap. It would seem that this could be done in an RV by > adding a return line from the far end of the hot water system, a one- > way valve and a pump. Then all you would need to do is activate the > pump for a minute or so to charge the system, and then start the > shower. It would conserve the water supply as well as the grey tank > space. > > Has anyone seen this kind of system in use? > > Gardner > 78FC33 > > > > > > > [Non-text portions of this message have been removed] > |
12-11-2006, 17:09
Chuck and Gardner:
Am interested in this as well, by why can one not use the cold water line with a few solenoids as well?? Bill 84 FC 35 SB "$quanderlodge" Terrace, B.C. Canada ----- Original Message ---- From: Gardner Yeaw To: WanderlodgeForum@yahoogroups.com Sent: Monday, December 11, 2006 6:19:12 PM Subject: [WanderlodgeForum] Re: Hot water and boondocking Chuck, Thanks. By the way, My wife's name is Kathy also, so it seems that wives named Kathy like the solution, so it must be a winner. I like the idea of using relays so that the pumps don't fight each other. I have a similar relay logic system in my home. The garage and bedroom share the same supply side for the hot water heating system, so I built a relay logic system that gives the bedroom priority. A little boolean logic and some radio shack relays and you are in business. Gardner 78FC33 --- In WanderlodgeForum@ yahoogroups. com, "Chuck winner. > > Gardner, > > Form my post last night: > > It seems like Kathy and are in cold weather a lot and many times dry > camping. I hated to waste water getting hot water to the shower so I routed > a return line from the shower back to the water heater. I then placed a > relay on the pressure control switch of the primary pump to control both > pumps. If the primary pump is running the recirculation pump is off. If > pressure is up and the primary pump shuts off then the recirculation pump > runs. When you turn the pump switch on before stepping into the shower you > have instant hot water. It works well for it's intended purpose to conserve > water but I don't believe that it would keep the cold water side from > freezing. > > > - Chuck Wheeler - > 82 FC 31 SB > Fort Worth, TX > > > _____ > > From: WanderlodgeForum@ yahoogroups. com > [mailto:WanderlodgeForum@ yahoogroups. com] On Behalf Of Gardner Yeaw > Sent: Monday, December 11, 2006 7:25 PM > To: WanderlodgeForum@ yahoogroups. com > Subject: [WanderlodgeForum] Hot water and boondocking > > > > We took a 4 day trip and had only power available. I left with a > full water tank and mostly empty grey and black tanks. By the last > day I had about 1/4 tank of water left. I began to think about ways > to conserve water to streach the time we could stay. One thought was > the waste of water waiting for the sink or shower hot water to come > up to temperature. It was cold outside so it took a while, wasted > water and holding tank capacity. > > In hotels/motels/ large buildings they use a circulating system > that keeps the hot water supply hot so you don't wait for hot water > at the tub or tap. It would seem that this could be done in an RV by > adding a return line from the far end of the hot water system, a one- > way valve and a pump. Then all you would need to do is activate the > pump for a minute or so to charge the system, and then start the > shower. It would conserve the water supply as well as the grey tank > space. > > Has anyone seen this kind of system in use? > > Gardner > 78FC33 > > > > > > > [Non-text portions of this message have been removed] > <!-- #ygrp-mlmsg {font-size:13px;font-family:arial,helvetica,clean,sans-serif;} #ygrp-mlmsg table {font-size:inherit;font:100%;} #ygrp-mlmsg select, input, textarea {font:99% arial,helvetica,clean,sans-serif;} #ygrp-mlmsg pre, code {font:115% monospace;} #ygrp-mlmsg * {line-height:1.22em;} #ygrp-text{ font-family:Georgia; } #ygrp-text p{ margin:0 0 1em 0; } #ygrp-tpmsgs{ font-family:Arial; clear:both; } #ygrp-vitnav{ padding-top:10px; font-family:Verdana; font-size:77%; margin:0; } #ygrp-vitnav a{ padding:0 1px; } #ygrp-actbar{ clear:both; margin:25px 0; white-space:nowrap; color:#666; text-align:right; } #ygrp-actbar .left{ float:left; white-space:nowrap; } .bld{font-weight:bold;} #ygrp-grft{ font-family:Verdana; font-size:77%; padding:15px 0; } #ygrp-ft{ font-family:verdana; font-size:77%; border-top:1px solid #666; padding:5px 0; } #ygrp-mlmsg #logo{ padding-bottom:10px; } #ygrp-vital{ background-color:#e0ecee; margin-bottom:20px; padding:2px 0 8px 8px; } #ygrp-vital #vithd{ font-size:77%; font-family:Verdana; font-weight:bold; color:#333; text-transform:uppercase; } #ygrp-vital ul{ padding:0; margin:2px 0; } #ygrp-vital ul li{ list-style-type:none; clear:both; border:1px solid #e0ecee; } #ygrp-vital ul li .ct{ font-weight:bold; color:#ff7900; float:right; width:2em; text-align:right; padding-right:.5em; } #ygrp-vital ul li .cat{ font-weight:bold; } #ygrp-vital a { text-decoration:none; } #ygrp-vital a:hover{ text-decoration:underline; } #ygrp-sponsor #hd{ color:#999; font-size:77%; } #ygrp-sponsor #ov{ padding:6px 13px; background-color:#e0ecee; margin-bottom:20px; } #ygrp-sponsor #ov ul{ padding:0 0 0 8px; margin:0; } #ygrp-sponsor #ov li{ list-style-type:square; padding:6px 0; font-size:77%; } #ygrp-sponsor #ov li a{ text-decoration:none; font-size:130%; } #ygrp-sponsor #nc { background-color:#eee; margin-bottom:20px; padding:0 8px; } #ygrp-sponsor .ad{ padding:8px 0; } #ygrp-sponsor .ad #hd1{ font-family:Arial; font-weight:bold; color:#628c2a; font-size:100%; line-height:122%; } #ygrp-sponsor .ad a{ text-decoration:none; } #ygrp-sponsor .ad a:hover{ text-decoration:underline; } #ygrp-sponsor .ad p{ margin:0; } o {font-size:0;} .MsoNormal { margin:0 0 0 0; } #ygrp-text tt{ font-size:120%; } blockquote{margin:0 0 0 4px;} .replbq {margin:4;} --> __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com [Non-text portions of this message have been removed] |
12-11-2006, 17:21
That's a real good idea Bill. Moving water won't "normally" freeze.
Terry Neal Bozeman, MT 82PT40 74FC34 Wilhelmus Schreurs wrote: > Chuck and Gardner: > > Am interested in this as well, by why can one not use the cold water > line with a few solenoids as well?? > > Bill 84 FC 35 SB "$quanderlodge" > Terrace, B.C. Canada > > ----- Original Message ---- > From: Gardner Yeaw > To: WanderlodgeForum@yahoogroups.com > > Sent: Monday, December 11, 2006 6:19:12 PM > Subject: [WanderlodgeForum] Re: Hot water and boondocking > > Chuck, > > Thanks. By the way, My wife's name is Kathy also, so it seems > > that wives named Kathy like the solution, so it must be a winner. > > I like the idea of using relays so that the pumps don't fight each > > other. I have a similar relay logic system in my home. The garage > > and bedroom share the same supply side for the hot water heating > > system, so I built a relay logic system that gives the bedroom > > priority. A little boolean logic and some radio shack relays and you > > are in business. > > Gardner > > 78FC33 > > --- In WanderlodgeForum@ yahoogroups. com, "Chuck > > winner. > > > > > > Gardner, > > > > > > Form my post last night: > > > > > > It seems like Kathy and are in cold weather a lot and many times > > dry > > > camping. I hated to waste water getting hot water to the shower so > > I routed > > > a return line from the shower back to the water heater. I then > > placed a > > > relay on the pressure control switch of the primary pump to > > control both > > > pumps. If the primary pump is running the recirculation pump is > > off. If > > > pressure is up and the primary pump shuts off then the > > recirculation pump > > > runs. When you turn the pump switch on before stepping into the > > shower you > > > have instant hot water. It works well for it's intended purpose to > > conserve > > > water but I don't believe that it would keep the cold water side > > from > > > freezing. > > > > > > > > > - Chuck Wheeler - > > > 82 FC 31 SB > > > Fort Worth, TX > > > > > > > > > _____ > > > > > > From: WanderlodgeForum@ yahoogroups. com > > > [mailto:WanderlodgeForum@ yahoogroups. com] On Behalf Of Gardner Yeaw > > > Sent: Monday, December 11, 2006 7:25 PM > > > To: WanderlodgeForum@ yahoogroups. com > > > Subject: [WanderlodgeForum] Hot water and boondocking > > > > > > > > > > > > We took a 4 day trip and had only power available. I left with a > > > full water tank and mostly empty grey and black tanks. By the last > > > day I had about 1/4 tank of water left. I began to think about > > ways > > > to conserve water to streach the time we could stay. One thought > > was > > > the waste of water waiting for the sink or shower hot water to > > come > > > up to temperature. It was cold outside so it took a while, wasted > > > water and holding tank capacity. > > > > > > In hotels/motels/ large buildings they use a circulating system > > > that keeps the hot water supply hot so you don't wait for hot > > water > > > at the tub or tap. It would seem that this could be done in an RV > > by > > > adding a return line from the far end of the hot water system, a > > one- > > > way valve and a pump. Then all you would need to do is activate > > the > > > pump for a minute or so to charge the system, and then start the > > > shower. It would conserve the water supply as well as the grey > > tank > > > space. > > > > > > Has anyone seen this kind of system in use? > > > > > > Gardner > > > 78FC33 > > > > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > <!-- > > #ygrp-mlmsg {font-size:13px;font-family:arial,helvetica,clean,sans-serif;} > #ygrp-mlmsg table {font-size:inherit;font:100%;} > #ygrp-mlmsg select, input, textarea {font:99% > arial,helvetica,clean,sans-serif;} > #ygrp-mlmsg pre, code {font:115% monospace;} > #ygrp-mlmsg * {line-height:1.22em;} > #ygrp-text{ > font-family:Georgia; > } > #ygrp-text p{ > margin:0 0 1em 0; > } > #ygrp-tpmsgs{ > font-family:Arial; > clear:both; > } > #ygrp-vitnav{ > padding-top:10px; > font-family:Verdana; > font-size:77%; > margin:0; > } > #ygrp-vitnav a{ > padding:0 1px; > } > #ygrp-actbar{ > clear:both; > margin:25px 0; > white-space:nowrap; > color:#666; > text-align:right; > } > #ygrp-actbar .left{ > float:left; > white-space:nowrap; > } > .bld{font-weight:bold;} > #ygrp-grft{ > font-family:Verdana; > font-size:77%; > padding:15px 0; > } > #ygrp-ft{ > font-family:verdana; > font-size:77%; > border-top:1px solid #666; > padding:5px 0; > } > #ygrp-mlmsg #logo{ > padding-bottom:10px; > } > > #ygrp-vital{ > background-color:#e0ecee; > margin-bottom:20px; > padding:2px 0 8px 8px; > } > #ygrp-vital #vithd{ > font-size:77%; > font-family:Verdana; > font-weight:bold; > color:#333; > text-transform:uppercase; > } > #ygrp-vital ul{ > padding:0; > margin:2px 0; > } > #ygrp-vital ul li{ > list-style-type:none; > clear:both; > border:1px solid #e0ecee; > } > #ygrp-vital ul li .ct{ > font-weight:bold; > color:#ff7900; > float:right; > width:2em; > text-align:right; > padding-right:.5em; > } > #ygrp-vital ul li .cat{ > font-weight:bold; > } > #ygrp-vital a { > text-decoration:none; > } > > #ygrp-vital a:hover{ > text-decoration:underline; > } > > #ygrp-sponsor #hd{ > color:#999; > font-size:77%; > } > #ygrp-sponsor #ov{ > padding:6px 13px; > background-color:#e0ecee; > margin-bottom:20px; > } > #ygrp-sponsor #ov ul{ > padding:0 0 0 8px; > margin:0; > } > #ygrp-sponsor #ov li{ > list-style-type:square; > padding:6px 0; > font-size:77%; > } > #ygrp-sponsor #ov li a{ > text-decoration:none; > font-size:130%; > } > #ygrp-sponsor #nc { > background-color:#eee; > margin-bottom:20px; > padding:0 8px; > } > #ygrp-sponsor .ad{ > padding:8px 0; > } > #ygrp-sponsor .ad #hd1{ > font-family:Arial; > font-weight:bold; > color:#628c2a; > font-size:100%; > line-height:122%; > } > #ygrp-sponsor .ad a{ > text-decoration:none; > } > #ygrp-sponsor .ad a:hover{ > text-decoration:underline; > } > #ygrp-sponsor .ad p{ > margin:0; > } > o {font-size:0;} > .MsoNormal { > margin:0 0 0 0; > } > #ygrp-text tt{ > font-size:120%; > } > blockquote{margin:0 0 0 4px;} > .replbq {margin:4;} > --> > > __________________________________________________ > Do You Yahoo!? > Tired of spam? Yahoo! Mail has the best spam protection around > http://mail.yahoo.com <http://mail.yahoo.com> > > [Non-text portions of this message have been removed] > > |
12-12-2006, 03:16
Gardner,
I like your hot water circulating idea. Just a thought on cold water freeze up. Could you put a seperate water heater in the cold water line with a circulating pump and set a thermostat at say 50 degrees. Howard Truitt Camilla, Ga. 86 PT40 ----- Original Message ----- From: Chuck Wheeler To: WanderlodgeForum@yahoogroups.com Sent: Monday, December 11, 2006 9:01 PM Subject: RE: [WanderlodgeForum] Hot water and boondocking Gardner, Form my post last night: It seems like Kathy and are in cold weather a lot and many times dry camping. I hated to waste water getting hot water to the shower so I routed a return line from the shower back to the water heater. I then placed a relay on the pressure control switch of the primary pump to control both pumps. If the primary pump is running the recirculation pump is off. If pressure is up and the primary pump shuts off then the recirculation pump runs. When you turn the pump switch on before stepping into the shower you have instant hot water. It works well for it's intended purpose to conserve water but I don't believe that it would keep the cold water side from freezing. - Chuck Wheeler - 82 FC 31 SB Fort Worth, TX _____ From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Gardner Yeaw Sent: Monday, December 11, 2006 7:25 PM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Hot water and boondocking We took a 4 day trip and had only power available. I left with a full water tank and mostly empty grey and black tanks. By the last day I had about 1/4 tank of water left. I began to think about ways to conserve water to streach the time we could stay. One thought was the waste of water waiting for the sink or shower hot water to come up to temperature. It was cold outside so it took a while, wasted water and holding tank capacity. In hotels/motels/large buildings they use a circulating system that keeps the hot water supply hot so you don't wait for hot water at the tub or tap. It would seem that this could be done in an RV by adding a return line from the far end of the hot water system, a one- way valve and a pump. Then all you would need to do is activate the pump for a minute or so to charge the system, and then start the shower. It would conserve the water supply as well as the grey tank space. Has anyone seen this kind of system in use? Gardner 78FC33 [Non-text portions of this message have been removed] ------------------------------------------------------------------------------ No virus found in this incoming message. Checked by AVG Free Edition. Version: 7.1.409 / Virus Database: 268.15.15/580 - Release Date: 12/8/2006 [Non-text portions of this message have been removed] |
12-12-2006, 04:30
Gardner,
Thanks to Howard for his cold water idea. Here is a "whole house" hot water recirculating kit that will do what we are talking about. Crosses the hot water over to the cold line for it's return trip to the water heater. No additional return line needed. Just buy an additional cold water connector for any additional water line runs you may have. The PT coaches have 2 runs, one down each side of the coach, so this will work. Link is: http://www.rewci.com/whhohotwaci.html Terry Neal Bozeman, MT 82PT40 74FC34 Howard O. Truitt wrote: > Gardner, > I like your hot water circulating idea. > Just a thought on cold water freeze up. > Could you put a seperate water heater in the cold water line with a > circulating pump and set a thermostat at say > 50 degrees. > Howard Truitt > Camilla, Ga. > 86 PT40 > > ----- Original Message ----- > From: Chuck Wheeler > To: WanderlodgeForum@yahoogroups.com > > Sent: Monday, December 11, 2006 9:01 PM > Subject: RE: [WanderlodgeForum] Hot water and boondocking > > Gardner, > > Form my post last night: > > It seems like Kathy and are in cold weather a lot and many times dry > camping. I hated to waste water getting hot water to the shower so I > routed > a return line from the shower back to the water heater. I then placed a > relay on the pressure control switch of the primary pump to control both > pumps. If the primary pump is running the recirculation pump is off. If > pressure is up and the primary pump shuts off then the recirculation pump > runs. When you turn the pump switch on before stepping into the shower you > have instant hot water. It works well for it's intended purpose to > conserve > water but I don't believe that it would keep the cold water side from > freezing. > > - Chuck Wheeler - > 82 FC 31 SB > Fort Worth, TX > > _____ > > From: WanderlodgeForum@yahoogroups.com > > [mailto:WanderlodgeForum@yahoogroups.com > > Sent: Monday, December 11, 2006 7:25 PM > To: WanderlodgeForum@yahoogroups.com > > Subject: [WanderlodgeForum] Hot water and boondocking > > We took a 4 day trip and had only power available. I left with a > full water tank and mostly empty grey and black tanks. By the last > day I had about 1/4 tank of water left. I began to think about ways > to conserve water to streach the time we could stay. One thought was > the waste of water waiting for the sink or shower hot water to come > up to temperature. It was cold outside so it took a while, wasted > water and holding tank capacity. > > In hotels/motels/large buildings they use a circulating system > that keeps the hot water supply hot so you don't wait for hot water > at the tub or tap. It would seem that this could be done in an RV by > adding a return line from the far end of the hot water system, a one- > way valve and a pump. Then all you would need to do is activate the > pump for a minute or so to charge the system, and then start the > shower. It would conserve the water supply as well as the grey tank > space. > > Has anyone seen this kind of system in use? > > Gardner > 78FC33 > > [Non-text portions of this message have been removed] > > ---------------------------------------------------------- > > No virus found in this incoming message. > Checked by AVG Free Edition. > Version: 7.1.409 / Virus Database: 268.15.15/580 - Release Date: 12/8/2006 > > [Non-text portions of this message have been removed] > > |
