Keyed Power?
12-15-2006, 07:20
Keyed Power?
While fiddling with my RH heater motor switch, I noticed that this has
power, even if the ingition is off. Upon a little more inspection, I noticed that my voltmeter is registering and all forward fans have power, even with the key off. Seems like when I drove Pokey home, this all went dead when the key was turned off. Is this normal, or do I have a problem somewhere? Thanks, Doug Engel, Gunnison, CO. 1981 FC35SB "Pokey" |
12-15-2006, 07:36
Keyed Power?
Could be a funny relay some where. Happy hunting. I still have to find out
where the left turn circuit is shorted on my FC MH ----- Original Message ----- From: doug_ngl To: WanderlodgeForum@yahoogroups.com Sent: Friday, December 15, 2006 1:20 PM Subject: [WanderlodgeForum] Keyed Power? While fiddling with my RH heater motor switch, I noticed that this has power, even if the ingition is off. Upon a little more inspection, I noticed that my voltmeter is registering and all forward fans have power, even with the key off. Seems like when I drove Pokey home, this all went dead when the key was turned off. Is this normal, or do I have a problem somewhere? Thanks, Doug Engel, Gunnison, CO. 1981 FC35SB "Pokey" [Non-text portions of this message have been removed] |
12-15-2006, 11:12
Keyed Power?
Doug,
On my 86 PT40 it will sure kill the batteries if I forget to cut off the two 12 volt master switches. Howard Truitt Camilla, Ga. Sowega ----- Original Message ----- From: doug_ngl To: WanderlodgeForum@yahoogroups.com Sent: Friday, December 15, 2006 2:20 PM Subject: [WanderlodgeForum] Keyed Power? While fiddling with my RH heater motor switch, I noticed that this has power, even if the ingition is off. Upon a little more inspection, I noticed that my voltmeter is registering and all forward fans have power, even with the key off. Seems like when I drove Pokey home, this all went dead when the key was turned off. Is this normal, or do I have a problem somewhere? Thanks, Doug Engel, Gunnison, CO. 1981 FC35SB "Pokey" ------------------------------------------------------------------------------ No virus found in this incoming message. Checked by AVG Free Edition. Version: 7.1.409 / Virus Database: 268.15.20/588 - Release Date: 12/15/2006 [Non-text portions of this message have been removed] |
12-15-2006, 13:38
Keyed Power?
My '77 had power to the blowers with the key off (pull-on switches in
overhead), by '82 they were keyed. I don't know when they changed, might have been '82. - Jeff Miller in Holland, MI --- In WanderlodgeForum@yahoogroups.com, "doug_ngl" wrote: > > While fiddling with my RH heater motor switch, I noticed that this has > power, even if the ingition is off. Upon a little more inspection, I > noticed that my voltmeter is registering and all forward fans have > power, even with the key off. Seems like when I drove Pokey home, this > all went dead when the key was turned off. Is this normal, or do I have > a problem somewhere? Thanks, Doug Engel, Gunnison, CO. 1981 > FC35SB "Pokey" > |
12-16-2006, 08:18
Keyed Power?
They will run in my '82 with the key off.
Scott Forman 82 FC35RB Memphis --- In WanderlodgeForum@yahoogroups.com, "Jeff Miller" wrote: > > My '77 had power to the blowers with the key off (pull-on switches in > overhead), by '82 they were keyed. I don't know when they changed, > might have been '82. > > - Jeff Miller > in Holland, MI > > > --- In WanderlodgeForum@yahoogroups.com, "doug_ngl" > wrote: > > > > While fiddling with my RH heater motor switch, I noticed that this > has > > power, even if the ingition is off. Upon a little more inspection, I > > noticed that my voltmeter is registering and all forward fans have > > power, even with the key off. Seems like when I drove Pokey home, > this > > all went dead when the key was turned off. Is this normal, or do I > have > > a problem somewhere? Thanks, Doug Engel, Gunnison, CO. 1981 > > FC35SB "Pokey" > > > |
12-16-2006, 09:22
Keyed Power?
Thanks to all. Mr. Corona and I sat down with the BlueBook and traced wiring
diagrams. They get power from the overhead breaker bar, which also powers the waterpump, some lighting and a few other key off items. Seems to draw power from some main, key off power source, so all systems are normal...or as normal as they get in Pokey. Doug n' Pokey Scott Forman <sforman@...> wrote: They will run in my '82 with the key off. Scott Forman 82 FC35RB Memphis --- In WanderlodgeForum@yahoogroups.com, "Jeff Miller" wrote: > > My '77 had power to the blowers with the key off (pull-on switches in > overhead), by '82 they were keyed. I don't know when they changed, > might have been '82. > > - Jeff Miller > in Holland, MI > > > --- In WanderlodgeForum@yahoogroups.com, "doug_ngl" > wrote: > > > > While fiddling with my RH heater motor switch, I noticed that this > has > > power, even if the ingition is off. Upon a little more inspection, I > > noticed that my voltmeter is registering and all forward fans have > > power, even with the key off. Seems like when I drove Pokey home, > this > > all went dead when the key was turned off. Is this normal, or do I > have > > a problem somewhere? Thanks, Doug Engel, Gunnison, CO. 1981 > > FC35SB "Pokey" > > > Doug Engel, Gunnison, CO. 1981 FC35SB "Pokey" __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com [Non-text portions of this message have been removed] |
12-16-2006, 13:12
Keyed Power?
They run in mine with the key off, also...
Sea Ya Larry NYC 84 35FCSB ----- Original Message ---- From: Scott Forman <sforman@...> To: WanderlodgeForum@yahoogroups.com Sent: Saturday, December 16, 2006 3:18:10 PM Subject: [WanderlodgeForum] Re: Keyed Power? They will run in my '82 with the key off. Scott Forman 82 FC35RB Memphis --- In WanderlodgeForum@ yahoogroups. com, "Jeff Miller" wrote: > > My '77 had power to the blowers with the key off (pull-on switches in > overhead), by '82 they were keyed. I don't know when they changed, > might have been '82. > > - Jeff Miller > in Holland, MI > > > --- In WanderlodgeForum@ yahoogroups. com, "doug_ngl" > wrote: > > > > While fiddling with my RH heater motor switch, I noticed that this > has > > power, even if the ingition is off. Upon a little more inspection, I > > noticed that my voltmeter is registering and all forward fans have > > power, even with the key off. Seems like when I drove Pokey home, > this > > all went dead when the key was turned off. Is this normal, or do I > have > > a problem somewhere? Thanks, Doug Engel, Gunnison, CO. 1981 > > FC35SB "Pokey" > > > <!-- #ygrp-mlmsg {font-size:13px;font-family:arial,helvetica,clean,sans-serif;} #ygrp-mlmsg table {font-size:inherit;font:100%;} #ygrp-mlmsg select, input, textarea {font:99% arial,helvetica,clean,sans-serif;} #ygrp-mlmsg pre, code {font:115% monospace;} #ygrp-mlmsg * {line-height:1.22em;} #ygrp-text{ font-family:Georgia; } #ygrp-text p{ margin:0 0 1em 0; } #ygrp-tpmsgs{ font-family:Arial; clear:both; } #ygrp-vitnav{ padding-top:10px; font-family:Verdana; font-size:77%; margin:0; } #ygrp-vitnav a{ padding:0 1px; } #ygrp-actbar{ clear:both; margin:25px 0; white-space:nowrap; color:#666; text-align:right; } #ygrp-actbar .left{ float:left; white-space:nowrap; } .bld{font-weight:bold;} #ygrp-grft{ font-family:Verdana; font-size:77%; padding:15px 0; } #ygrp-ft{ font-family:verdana; font-size:77%; border-top:1px solid #666; padding:5px 0; } #ygrp-mlmsg #logo{ padding-bottom:10px; } #ygrp-vital{ background-color:#e0ecee; margin-bottom:20px; padding:2px 0 8px 8px; } #ygrp-vital #vithd{ font-size:77%; font-family:Verdana; font-weight:bold; color:#333; text-transform:uppercase; } #ygrp-vital ul{ padding:0; margin:2px 0; } #ygrp-vital ul li{ list-style-type:none; clear:both; border:1px solid #e0ecee; } #ygrp-vital ul li .ct{ font-weight:bold; color:#ff7900; float:right; width:2em; text-align:right; padding-right:.5em; } #ygrp-vital ul li .cat{ font-weight:bold; } #ygrp-vital a { text-decoration:none; } #ygrp-vital a:hover{ text-decoration:underline; } #ygrp-sponsor #hd{ color:#999; font-size:77%; } #ygrp-sponsor #ov{ padding:6px 13px; background-color:#e0ecee; margin-bottom:20px; } #ygrp-sponsor #ov ul{ padding:0 0 0 8px; margin:0; } #ygrp-sponsor #ov li{ list-style-type:square; padding:6px 0; font-size:77%; } #ygrp-sponsor #ov li a{ text-decoration:none; font-size:130%; } #ygrp-sponsor #nc { background-color:#eee; margin-bottom:20px; padding:0 8px; } #ygrp-sponsor .ad{ padding:8px 0; } #ygrp-sponsor .ad #hd1{ font-family:Arial; font-weight:bold; color:#628c2a; font-size:100%; line-height:122%; } #ygrp-sponsor .ad a{ text-decoration:none; } #ygrp-sponsor .ad a:hover{ text-decoration:underline; } #ygrp-sponsor .ad p{ margin:0; } o {font-size:0;} .MsoNormal { margin:0 0 0 0; } #ygrp-text tt{ font-size:120%; } blockquote{margin:0 0 0 4px;} .replbq {margin:4;} --> __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com [Non-text portions of this message have been removed] |
