In Yuma.....hydraulic levelers fuse??? solenoid part number that would exchange
12-22-2006, 10:27
Hi group
mom and I are still in Yuma area, sun's out, nice.... Levelers quit (motor, solanoid?) service came out today, still uncertain if the solenoid is good, went back to shop to get one and they haven't one and HWH not available to get a crossover number. Couldn't find where the fuse might be.....anyone able to help me there? Guess now we have to wait until after Christmas, tho if there is a fuse I could check as per trouble shooting the motor not coming on.... the blue lights activate without the key being on or in accessory.... when I turn on the switch....didn't do that before. I damaged the L front leveler a couple weeks ago, (took out a hidden post (ha!) anyway the other 3 still worked and haven't needed to use them this last week. The other night tho I could have used one of the rear ones and that is when I found the blue lights came on with the switch without the key on and the motor is quiet..... I thought the problem was crushed hydraulic lines (it was a big solid low post) anyway those lines are the chassis heat lines next to the frame under left front. Would there be a problem if I just bypassed, plugged or ran them back into each other with more hose? We aren't using the chassis heat. Don't want to take a chance of springing a leak and loosing coolant on the road. Have a great holiday Rose Mary 82 FC 33 JP's White Bird Yuma |
12-22-2006, 14:22
RoseMary:
Fuse or circuit breaker for the pump? Under the top entry step, it should lift up and you might or might now have to remove a cover to see it. Merry Christmas to you Bill 84 FC 35 SB "$quanderlodge" Terrace, B.C. Canada ----- Original Message ---- From: Rose Mary To: WanderlodgeForum@yahoogroups.com Sent: Friday, December 22, 2006 2:27:12 PM Subject: [WanderlodgeForum] In Yuma.....hydraulic levelers fuse??? solenoid part number that would exchange Hi group mom and I are still in Yuma area, sun's out, nice.... Levelers quit (motor, solanoid?) service came out today, still uncertain if the solenoid is good, went back to shop to get one and they haven't one and HWH not available to get a crossover number. Couldn't find where the fuse might be.....anyone able to help me there? Guess now we have to wait until after Christmas, tho if there is a fuse I could check as per trouble shooting the motor not coming on.... the blue lights activate without the key being on or in accessory... . when I turn on the switch....didn' t do that before. I damaged the L front leveler a couple weeks ago, (took out a hidden post (ha!) anyway the other 3 still worked and haven't needed to use them this last week. The other night tho I could have used one of the rear ones and that is when I found the blue lights came on with the switch without the key on and the motor is quiet..... I thought the problem was crushed hydraulic lines (it was a big solid low post) anyway those lines are the chassis heat lines next to the frame under left front. Would there be a problem if I just bypassed, plugged or ran them back into each other with more hose? We aren't using the chassis heat. Don't want to take a chance of springing a leak and loosing coolant on the road. Have a great holiday Rose Mary 82 FC 33 JP's White Bird Yuma __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com [Non-text portions of this message have been removed] |
12-23-2006, 15:38
Bill
I know about the leveler reservoir under the step, there is a hole there to fill, can't see a fuse anywhere??? thanks Rose Mary --- In WanderlodgeForum@yahoogroups.com, Wilhelmus Schreurs > > RoseMary: > Fuse or circuit breaker for the pump? > Under the top entry step, it should lift up and you might or might now have to remove a cover to see it. > Merry Christmas to you > > Bill 84 FC 35 SB "$quanderlodge" > Terrace, B.C. Canada > > > > > ----- Original Message ---- > From: Rose Mary > To: WanderlodgeForum@yahoogroups.com > Sent: Friday, December 22, 2006 2:27:12 PM > Subject: [WanderlodgeForum] In Yuma.....hydraulic levelers fuse??? solenoid part number that would exchange > > Hi group > mom and I are still in Yuma area, sun's out, nice.... > Levelers quit (motor, solanoid?) service came out today, still > uncertain if the solenoid is good, went back to shop to get one and > they haven't one and HWH not available to get a crossover number. > > Couldn't find where the fuse might be.....anyone able to help me there? > Guess now we have to wait until after Christmas, tho if there is a fuse > I could check as per trouble shooting the motor not coming on.... > the blue lights activate without the key being on or in accessory... . > when I turn on the switch....didn' t do that before. > I damaged the L front leveler a couple weeks ago, (took out a hidden > post (ha!) anyway the other 3 still worked and haven't needed to use > them this last week. The other night tho I could have used one of the > rear ones and that is when I found the blue lights came on with the > switch without the key on and the motor is quiet..... > I thought the problem was crushed hydraulic lines (it was a big solid > low post) anyway those lines are the chassis heat lines next to the > frame under left front. Would there be a problem if I just bypassed, > plugged or ran them back into each other with more hose? We aren't > using the chassis heat. Don't want to take a chance of springing a leak > and loosing coolant on the road. > > Have a great holiday > Rose Mary > 82 FC 33 > JP's White Bird > Yuma > > > > > __________________________________________________ > Do You Yahoo!? > Tired of spam? Yahoo! Mail has the best spam protection around > http://mail.yahoo.com > > [Non-text portions of this message have been removed] > |
