Microwave
12-28-2006, 05:10
Microwave
Hi Fellows,
I am looking at replacing my Sharp Microwave the Sharp replacement that fits the opening best looks to be the R-930AK. I have read where folks are having some problems with the R-930. Have any of you used this model and have you had any problems. Also have you used other brand units to replace the Sharp. Thanks to all. Howard Truitt Camilla, Ga. "Sowega" 86 PT40 [Non-text portions of this message have been removed] |
12-28-2006, 06:45
Microwave
Howard,
I replaced our Sharp Micro/convection with a GE #JE1590SH. Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, Calif. Howard O. Truitt wrote: >Hi Fellows, >I am looking at replacing my Sharp Microwave the Sharp replacement that fits the opening best looks to be the R-930AK. I have read where folks are having some problems with the R-930. Have any of you used this model and have you had any problems. >Also have you used other brand units to replace the Sharp. >Thanks to all. >Howard Truitt >Camilla, Ga. >"Sowega" > 86 PT40 > > >[Non-text portions of this message have been removed] > > > > >Yahoo! Groups Links > > > > > > |
12-28-2006, 08:16
Microwave
I am looking for a replacement also and was informed that the table top
microwave/convection ovens should not be enclosed in a cabinet. They require air space for heat dissipation. The built-in microwaves have a fan and shroud to remove the heat. I recall one member mentioning that they vented the heat with a fan thru the cooktop heat vent. Unfortunately all the built-in microwave/convection ovens I have found are $700+. Troy Tikalsky 1986 Newell ----- Original Message ----- From: Howard O. Truitt To: WanderlodgeForum@yahoogroups.com Sent: Thursday, December 28, 2006 11:10 AM Subject: [WanderlodgeForum] Microwave Hi Fellows, I am looking at replacing my Sharp Microwave the Sharp replacement that fits the opening best looks to be the R-930AK. I have read where folks are having some problems with the R-930. Have any of you used this model and have you had any problems. Also have you used other brand units to replace the Sharp. Thanks to all. Howard Truitt Camilla, Ga. "Sowega" 86 PT40 [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] |
12-28-2006, 08:23
Microwave
Thanks Curt
----- Original Message ----- From: Curt Sprenger To: WanderlodgeForum@yahoogroups.com Sent: Thursday, December 28, 2006 1:45 PM Subject: Re: [WanderlodgeForum] Microwave Howard, I replaced our Sharp Micro/convection with a GE #JE1590SH. Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, Calif. Howard O. Truitt wrote: >Hi Fellows, >I am looking at replacing my Sharp Microwave the Sharp replacement that fits the opening best looks to be the R-930AK. I have read where folks are having some problems with the R-930. Have any of you used this model and have you had any problems. >Also have you used other brand units to replace the Sharp. >Thanks to all. >Howard Truitt >Camilla, Ga. >"Sowega" > 86 PT40 > > >[Non-text portions of this message have been removed] > > > > >Yahoo! Groups Links > > > > > > ------------------------------------------------------------------------------ No virus found in this incoming message. Checked by AVG Free Edition. Version: 7.1.409 / Virus Database: 268.15.29/607 - Release Date: 12/28/2006 [Non-text portions of this message have been removed] |
12-28-2006, 09:54
Microwave
Is it hard to gut a microwave and just refit the old unit with new
gismo's????? I had that done at a shade tree appliance shop for $75.00 but don't know what was done other than it worked after the repair. GregoryO'Connor 94ptRomolandCa--- In WanderlodgeForum@yahoogroups.com, "Troy Tikalsky" > > I am looking for a replacement also and was informed that the table top microwave/convection ovens should not be enclosed in a cabinet. They require air space for heat dissipation. The built-in microwaves have a fan and shroud to remove the heat. I recall one member mentioning that they vented the heat with a fan thru the cooktop heat vent. Unfortunately all the built-in microwave/convection ovens I have found are $700+. > > Troy Tikalsky > 1986 Newell > > > ----- Original Message ----- > From: Howard O. Truitt > To: WanderlodgeForum@yahoogroups.com > Sent: Thursday, December 28, 2006 11:10 AM > Subject: [WanderlodgeForum] Microwave > > > Hi Fellows, > I am looking at replacing my Sharp Microwave the Sharp replacement that fits the opening best looks to be the R-930AK. I have read where folks are having some problems with the R-930. Have any of you used this model and have you had any problems. > Also have you used other brand units to replace the Sharp. > Thanks to all. > Howard Truitt > Camilla, Ga. > "Sowega" > 86 PT40 > > [Non-text portions of this message have been removed] > > > > > > [Non-text portions of this message have been removed] > |
12-28-2006, 10:34
Microwave
I replaced my original Sharp with the 930 a month or two ago. Easy
installation. Used the correct install kit from Sharp but after I received it I believe I could have used the original install kit. So far it works great and looks good. I think that the best price I found was thru beveragefactory.com. Hope this helps. Mike McMahan 1989 PT40 --- In WanderlodgeForum@yahoogroups.com, "Howard O. Truitt" > > Hi Fellows, > I am looking at replacing my Sharp Microwave the Sharp replacement that fits the opening best looks to be the R-930AK. I have read where folks are having some problems with the R-930. Have any of you used this model and have you had any problems. > Also have you used other brand units to replace the Sharp. > Thanks to all. > Howard Truitt > Camilla, Ga. > "Sowega" > 86 PT40 > > > [Non-text portions of this message have been removed] > |
12-28-2006, 11:39
Microwave
Thanks Mike
----- Original Message ----- From: Mike McMahan To: WanderlodgeForum@yahoogroups.com Sent: Thursday, December 28, 2006 5:34 PM Subject: [WanderlodgeForum] Re: Microwave I replaced my original Sharp with the 930 a month or two ago. Easy installation. Used the correct install kit from Sharp but after I received it I believe I could have used the original install kit. So far it works great and looks good. I think that the best price I found was thru beveragefactory.com. Hope this helps. Mike McMahan 1989 PT40 --- In WanderlodgeForum@yahoogroups.com, "Howard O. Truitt" > > Hi Fellows, > I am looking at replacing my Sharp Microwave the Sharp replacement that fits the opening best looks to be the R-930AK. I have read where folks are having some problems with the R-930. Have any of you used this model and have you had any problems. > Also have you used other brand units to replace the Sharp. > Thanks to all. > Howard Truitt > Camilla, Ga. > "Sowega" > 86 PT40 > > > [Non-text portions of this message have been removed] > ------------------------------------------------------------------------------ No virus found in this incoming message. Checked by AVG Free Edition. Version: 7.1.409 / Virus Database: 268.15.29/607 - Release Date: 12/28/2006 [Non-text portions of this message have been removed] |
12-28-2006, 14:45
Microwave
I replaced mine with a GE JES1290 micro/conv. combo...a little
smaller..ended up with a 2 in. gap on three sides. Finally air gets to circulate out instead on being forced into the hall closet. Cost was $257.00 at Lowes. Wife likes it so I am happy. Bob Lawrence 84 PT36 Tacoma, Wa. (Where my work truck was stolen this morning at the gas station while refueling... ![]() > > Hi Fellows, > I am looking at replacing my Sharp Microwave the Sharp replacement that fits the opening best looks to be the R-930AK. I have read where folks are having some problems with the R-930. Have any of you used this model and have you had any problems. > Also have you used other brand units to replace the Sharp. > Thanks to all. > Howard Truitt > Camilla, Ga. > "Sowega" > 86 PT40 > > > [Non-text portions of this message have been removed] > |
12-28-2006, 17:17
Microwave
Now did you pay for the fuel? He stole that too, dern!
Interesting? Suppose a person fills up his tank, he goes to the register to pay and someone steals his vehicle, who owes for the stolen fuel? Maybe as soon as the nozzle starts flowing fuel in you tank, you are presumed to pay for it regardless?? Well!, doggies!! I hope you got your truck back undamaged, full of fuel too. bob janes, greenville, sc --- In WanderlodgeForum@yahoogroups.com, "Bob Lawrence" > > I replaced mine with a GE JES1290 micro/conv. combo...a little > smaller..ended up with a 2 in. gap on three sides. > Finally air gets to circulate out instead on being forced into the hall > closet. > Cost was $257.00 at Lowes. > Wife likes it so I am happy. > Bob Lawrence > 84 PT36 > Tacoma, Wa. (Where my work truck was stolen this morning at the gas > station while refueling... ![]() > > > > Hi Fellows, > > I am looking at replacing my Sharp Microwave the Sharp replacement > that fits the opening best looks to be the R-930AK. I have read where > folks are having some problems with the R-930. Have any of you used > this model and have you had any problems. > > Also have you used other brand units to replace the Sharp. > > Thanks to all. > > Howard Truitt > > Camilla, Ga. > > "Sowega" > > 86 PT40 > > > > > > [Non-text portions of this message have been removed] > > > |
12-28-2006, 18:01
Microwave
Thanks Bob and sorry about the truck.
Howard Truitt Camilla, Ga. "Sowega" 86 PT40 ----- Original Message ----- From: Bob Lawrence To: WanderlodgeForum@yahoogroups.com Sent: Thursday, December 28, 2006 9:45 PM Subject: [WanderlodgeForum] Re: Microwave I replaced mine with a GE JES1290 micro/conv. combo...a little smaller..ended up with a 2 in. gap on three sides. Finally air gets to circulate out instead on being forced into the hall closet. Cost was $257.00 at Lowes. Wife likes it so I am happy. Bob Lawrence 84 PT36 Tacoma, Wa. (Where my work truck was stolen this morning at the gas station while refueling... ![]() > > Hi Fellows, > I am looking at replacing my Sharp Microwave the Sharp replacement that fits the opening best looks to be the R-930AK. I have read where folks are having some problems with the R-930. Have any of you used this model and have you had any problems. > Also have you used other brand units to replace the Sharp. > Thanks to all. > Howard Truitt > Camilla, Ga. > "Sowega" > 86 PT40 > > > [Non-text portions of this message have been removed] > ------------------------------------------------------------------------------ No virus found in this incoming message. Checked by AVG Free Edition. Version: 7.1.409 / Virus Database: 268.15.29/607 - Release Date: 12/28/2006 [Non-text portions of this message have been removed] |
