Oil pressure gauge
01-02-2007, 07:32
Oil pressure gauge
Mike Mine has always ran at 80# when just starting up until it gets
warmed up then it cruses at 70# & drops back to 35# at idle at a stop. Mine has done that since I have had it which is aver 3 years.& 25000 miles. Do you think there is something wrong with the gauge or sender when it starts & runs at 80# till operating temp? Don 89 SP 36' Butler, PA I wonder about both gages. 80 is about 40 #s high for idle pressure. Sweet spot is 35 hot idle and 65/75 at cruise with Rottella 15/40. The dash gage has an electric sender as far as I know and that sender might be faulty. Mike Hohnstein Germantown, WI 83FC35 ----- Original Message ----- From: putneyflash To: _WanderlodgeForum@WanderlodgeFWan_ (mailto:WanderlodgeForum@yahoogroups.com) Sent: Tuesday, January 02, 2007 2:54 PM Subject: [WanderlodgeForum] Oil pressure gauge My engine oil pressure gauge is not working properly. I was road testing the other day and the gauge read 25 Psi. I installed a caterpillar mechnical gauge in the r.h. cylinder headtoday and at idle cold it shows 80 PSI (it was about 51 degrees when testing)while the dash gauge still shows 25 psi Anyone replaced the dash gauge? it looks to be a job. ANY suggestions or knowledge would be appreciated. RE Brake [Non-text portions of this message have been removed] |
01-02-2007, 08:54
Oil pressure gauge
testing the other day and the gauge read 25 Psi. I installed a caterpillar mechnical gauge in the r.h. cylinder headtoday and at idle cold it shows 80 PSI (it was about 51 degrees when testing)while the dash gauge still shows 25 psi Anyone replaced the dash gauge? it looks to be a job. ANY suggestions or knowledge would be appreciated. RE Brake 1983 35' sb |
01-02-2007, 10:56
Oil pressure gauge
spot is 35 hot idle and 65/75 at cruise with Rottella 15/40. The dash gage has an electric sender as far as I know and that sender might be faulty. Mike Hohnstein Germantown, WI 83FC35 ----- Original Message ----- From: putneyflash To: WanderlodgeForum@yahoogroups.com Sent: Tuesday, January 02, 2007 2:54 PM Subject: [WanderlodgeForum] Oil pressure gauge My engine oil pressure gauge is not working properly. I was road testing the other day and the gauge read 25 Psi. I installed a caterpillar mechnical gauge in the r.h. cylinder headtoday and at idle cold it shows 80 PSI (it was about 51 degrees when testing)while the dash gauge still shows 25 psi Anyone replaced the dash gauge? it looks to be a job. ANY suggestions or knowledge would be appreciated. RE Brake 1983 35' sb [Non-text portions of this message have been removed] |
01-02-2007, 15:34
Oil pressure gauge
Indicated 80 # @ low idle is high, even cold. I would be much more concerned
with pressures at operating temp. MH ----- Original Message ----- From: dspithaler@... To: WanderlodgeForum@yahoogroups.com Sent: Tuesday, January 02, 2007 6:32 PM Subject: Re: [WanderlodgeForum] Oil pressure gauge Mike Mine has always ran at 80# when just starting up until it gets warmed up then it cruses at 70# & drops back to 35# at idle at a stop. Mine has done that since I have had it which is aver 3 years.& 25000 miles. Do you think there is something wrong with the gauge or sender when it starts & runs at 80# till operating temp? Don 89 SP 36' Butler, PA I wonder about both gages. 80 is about 40 #s high for idle pressure. Sweet spot is 35 hot idle and 65/75 at cruise with Rottella 15/40. The dash gage has an electric sender as far as I know and that sender might be faulty. Mike Hohnstein Germantown, WI 83FC35 ----- Original Message ----- From: putneyflash To: _WanderlodgeForum@WanderlodgeFWan_ (mailto:WanderlodgeForum@yahoogroups.com) Sent: Tuesday, January 02, 2007 2:54 PM Subject: [WanderlodgeForum] Oil pressure gauge My engine oil pressure gauge is not working properly. I was road testing the other day and the gauge read 25 Psi. I installed a caterpillar mechnical gauge in the r.h. cylinder headtoday and at idle cold it shows 80 PSI (it was about 51 degrees when testing)while the dash gauge still shows 25 psi Anyone replaced the dash gauge? it looks to be a job. ANY suggestions or knowledge would be appreciated. RE Brake [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] |
01-03-2007, 04:38
Oil pressure gauge
Sounds like the sensor,
Try here for troubleshooting tips and tech support phone number. http://www.teleflexmarine.com/cgi-bin/frameset2.cgi? site=gauges&type=us&link2=1047 Bill 88 FC --- In WanderlodgeForum@yahoogroups.com, "putneyflash" > > My engine oil pressure gauge is not working properly. I was road > testing the other day and the gauge read 25 Psi. I installed a > caterpillar mechnical gauge in the r.h. cylinder headtoday and at idle > cold it shows 80 PSI (it was about 51 degrees when testing)while the > dash gauge still shows 25 psi > Anyone replaced the dash gauge? it looks to be a job. ANY suggestions > or knowledge would be appreciated. > > RE Brake 1983 35' sb > |
01-03-2007, 11:26
Oil pressure gauge
I don't think it has a sensor, I think its a mechnical gauge. will keep ypu
posted thanks re brake 1983 fc-35 sb > > From: "pattypape" > Date: 2007/01/03 Wed AM 11:38:38 EST > To: WanderlodgeForum@yahoogroups.com > Subject: [WanderlodgeForum] Re: Oil pressure gauge > > > > > Sounds like the sensor, > Try here for troubleshooting tips and tech support phone number. > > http://www.teleflexmarine.com/cgi-bin/frameset2.cgi? > site=gauges&type=us&link2=1047 > > Bill 88 FC > > > > --- In WanderlodgeForum@yahoogroups.com, "putneyflash" > > > > > My engine oil pressure gauge is not working properly. I was road > > testing the other day and the gauge read 25 Psi. I installed a > > caterpillar mechnical gauge in the r.h. cylinder headtoday and at > idle > > cold it shows 80 PSI (it was about 51 degrees when testing)while the > > dash gauge still shows 25 psi > > Anyone replaced the dash gauge? it looks to be a job. ANY suggestions > > or knowledge would be appreciated. > > > > RE Brake 1983 35' sb > > > > > > |
01-03-2007, 11:28
Oil pressure gauge
I agree with hot oil operating pressure, i was simply making sure i had oil
pressure thanks re brake > > From: "Mike Hohnstein" <MHOHNSTEIN@...> > Date: 2007/01/02 Tue PM 10:34:12 EST > To: > Subject: Re: [WanderlodgeForum] Oil pressure gauge > > Indicated 80 # @ low idle is high, even cold. I would be much more concerned with pressures at operating temp. > MH > ----- Original Message ----- > From: dspithaler@... > To: WanderlodgeForum@yahoogroups.com > Sent: Tuesday, January 02, 2007 6:32 PM > Subject: Re: [WanderlodgeForum] Oil pressure gauge > > > > Mike Mine has always ran at 80# when just starting up until it gets > warmed up then it cruses at 70# & drops back to 35# at idle at a stop. Mine has > done that since I have had it which is aver 3 years.& 25000 miles. Do you > think there is something wrong with the gauge or sender when it starts & runs > at 80# till operating temp? > Don > 89 SP 36' > Butler, PA > > I wonder about both gages. 80 is about 40 #s high for idle pressure. Sweet > spot is 35 hot idle and 65/75 at cruise with Rottella 15/40. The dash gage has > an electric sender as far as I know and that sender might be faulty. > Mike Hohnstein > Germantown, WI > 83FC35 > ----- Original Message ----- > From: putneyflash > To: _WanderlodgeForum@WanderlodgeFWan_ > (mailto:WanderlodgeForum@yahoogroups.com) > Sent: Tuesday, January 02, 2007 2:54 PM > Subject: [WanderlodgeForum] Oil pressure gauge > > My engine oil pressure gauge is not working properly. I was road > testing the other day and the gauge read 25 Psi. I installed a > caterpillar mechnical gauge in the r.h. cylinder headtoday and at idle > cold it shows 80 PSI (it was about 51 degrees when testing)while the > dash gauge still shows 25 psi > Anyone replaced the dash gauge? it looks to be a job. ANY suggestions > or knowledge would be appreciated. > > RE Brake > > [Non-text portions of this message have been removed] > > > > > > [Non-text portions of this message have been removed] > > > |
02-24-2008, 08:30
Oil pressure gauge
Thanks, Ron, I now recollect that gauge. I'll have to do some cleaning to read it~
Ernie Ekberg 83PT40 Buffalo, Wy Delicious ideas to please the pickiest eaters. Watch the video on AOL Living. |
02-24-2008, 08:32
Oil pressure gauge
I'm wondering if that sending unit is located beside the direct reading gauge that Ron just mentioned?
Ernie Ekberg 83PT40 Buffalo, Wy, on my way to Livingston, Mt in the am---if it don't SNOW Delicious ideas to please the pickiest eaters. Watch the video on AOL Living. |
02-24-2008, 09:12
Oil pressure gauge
In a message dated 2/24/2008 8:04:29 P.M. Central Standard Time, billpatty@... writes:
miles and a few more climbs. and one big decent into Billings
