Shocks
01-02-2007, 08:24
Shocks
Bob- didn't your coach come with Konis? If so they are adjustable. On my
coach, when i was at Steve Gureaskos', we adjusted 1 shock and replaced another- made agreat difference Ernie Ekberg 83PT40 Weatherford, tx [Non-text portions of this message have been removed] |
01-02-2007, 13:12
Shocks
How do I determine which Bilsteins will fit our '84 FC31 WLII?
The rear axle is air suspension and is no doubt the same setup as other '84 FCs. The front axle is leaf springs and probably the same as FCs just before BB started using air suspension (81? 82?). As always, thanks for the help! Bob Griesel '84 FC31 WLII WA |
01-02-2007, 15:48
Shocks
Thanks Earnie. Does anyone have Koni part numbers for an 84 FC? - Bob
> > Bob- didn't your coach come with Konis? If so they are adjustable. On my > coach, when i was at Steve Gureaskos', we adjusted 1 shock and replaced another- > made agreat difference > > Ernie Ekberg > 83PT40 > Weatherford, tx > > > > [Non-text portions of this message have been removed] > |
01-02-2007, 23:46
Shocks
Hey Bob, Happy New Year to you and Sandy.
Below is the correspondence I had with Koni recently. (Read from bottom up) As you know, my 79 does not have air suspension either front or back. I replaced the fronts this week and have not had the opportunity yet to drive it since so at this point I am unable to say if there is a difference. I do know there was a substantial difference in the resistance by hand. The originals on my coach were Gabriels per the original manual. The replacements were crossed from those numbers. I replaced the rears with Monroes as Koni says they do not have a replacement that size. I did drive the coach after replacing the rears only and noticed a significant difference, so, I am eager to see the difference with the fronts replaced. I purchased my stainless steel top hats from Mansker Tires (Les Schwaub). I don't know if they were a standard stock item for them, but they did have them in stock that day. Steve Anderson 79 FC 35 Poulsbo, Wa. We have a front shock that is pretty close to the specifications of the Gabriel shock (based on an aftermarket catalog). Please see the following: BB # 614966 = Monroe 74028 lMax = 22.625 lMin = 14.625 Koni 90 2256SP1 lMax = 22.52 lMin = 14.80 Our shock was designed for the front axle of a transit bus, so it should be close to what you need. It is also adjustable, in case you need more force to control the bouncing. The rear shock is a little more difficult BB #614974 = Monroe 74006 lMax = 21.625 lMin = 14.25 We don't have a Koni shock that is close to that. You may have to call Bluebird about the rear, and see if they know if there is a Koni equivalent to the Bluebird number. What they should know (that I don't) is where the actual limits to the suspension are... What is the lowest the shock can go, and what is the nominal height of the shock? If I get the dimensions wrong either way, you could rip the shocks apart. The fronts have a suggested list of $206, but you can get them through is for $165 each. Just call 866.566.4175 and ask for customer service. Hope this helps. Regards, Justin McCoy 859-488-0314 866-566-4175 x 314 (toll free) -----Original Message----- From: ebirder2000@... [mailto:ebirder2000@...] Sent: Tuesday, November 21, 2006 11:44 AM To: jmccoy@... Subject: Koni Web Site Contact - Heavy Duty name : John S. (Steve) Anderson address : 1079 NW Liberty Ln Poulsbo, Wa. 98370 phone : 360.779.4156 fax : Comments : I would like to purchase a set of KONI adjustable shocks for my 1979 Blue Bird motorhome. The original coach shocks were Gabriel brand. The part numbers I have for the front shocks are Gabriel part no. 0680054 with a Blue Bird part no. 0614966. The stroke on these front shocks is 8.76 in. The Gabriel part no for the rear shocks is 680010, with a Blue Bird part no. of 0614974. The stroke for the rears is 7.51 in. I will also need the bushings for all these shocks if they do not come with the shocks. Please let me know the Koni part numbers, the cost of these parts and how I can purchase them. VR Steve Anderson SUBMIT : Submit Query CFID : 13489092 CFTOKEN : 4ca660c17daeb771-0B48770F-0869-F5AD-C1D91148BD7B0D5F ************************************ This e-mail and any files transmitted with it are proprietary and intended solely for the use of the individual or entity to whom they are addressed. If you have received this e-mail in error please notify the sender. Please note that any views or opinions presented in this e-mail are solely those of the author and do not necessarily represent those of ITT, Inc. In a message dated 1/2/2007 5:22:39 PM Pacific Standard Time, sundance101@... writes: How do I determine which Bilsteins will fit our '84 FC31 WLII? The rear axle is air suspension and is no doubt the same setup as other '84 FCs. The front axle is leaf springs and probably the same as FCs just before BB started using air suspension (81? 82?). As always, thanks for the help! Bob Griesel '84 FC31 WLII WA [Non-text portions of this message have been removed] |
01-03-2007, 08:57
Shocks
Hi
we just put new Koni adj shocks on our bird a week or so ago, I called Koni but was able to get them thru bluebird for about $40 less per shock (around $130) just for your info. Rose Mary 82 FC Rocky Point Mex beautiful and warm! --- In WanderlodgeForum@yahoogroups.com, ebirder2000@... wrote: > > > > Hey Bob, Happy New Year to you and Sandy. > > Below is the correspondence I had with Koni recently. (Read from bottom up) > As you know, my 79 does not have air suspension either front or back. I > replaced the fronts this week and have not had the opportunity yet to drive it > since so at this point I am unable to say if there is a difference. I do know > there was a substantial difference in the resistance by hand. The originals on > my coach were Gabriels per the original manual. The replacements were crossed > from those numbers. I replaced the rears with Monroes as Koni says they do > not have a replacement that size. I did drive the coach after replacing the > rears only and noticed a significant difference, so, I am eager to see the > difference with the fronts replaced. > > I purchased my stainless steel top hats from Mansker Tires (Les Schwaub). I > don't know if they were a standard stock item for them, but they did have them > in stock that day. > > Steve Anderson > 79 FC 35 > Poulsbo, Wa. > > > We have a front shock that is pretty close to the specifications of the > Gabriel shock (based on an aftermarket catalog). Please see the > following: > BB # 614966 = Monroe 74028 > lMax = 22.625 > lMin = 14.625 > Koni 90 2256SP1 > lMax = 22.52 > lMin = 14.80 > > Our shock was designed for the front axle of a transit bus, so it should > be close to what you need. It is also adjustable, in case you need more > force to control the bouncing. > > The rear shock is a little more difficult > BB #614974 = Monroe 74006 > lMax = 21.625 > lMin = 14.25 > > We don't have a Koni shock that is close to that. > > You may have to call Bluebird about the rear, and see if they know if > there is a Koni equivalent to the Bluebird number. What they should > know (that I don't) is where the actual limits to the suspension are... > What is the lowest the shock can go, and what is the nominal height of > the shock? > > If I get the dimensions wrong either way, you could rip the shocks > apart. > > The fronts have a suggested list of $206, but you can get them through > is for $165 each. Just call 866.566.4175 and ask for customer service. > > Hope this helps. > > Regards, > > Justin McCoy > 859-488-0314 > 866-566-4175 x 314 (toll free) > > -----Original Message----- > From: ebirder2000@... [mailto:ebirder2000@...] > Sent: Tuesday, November 21, 2006 11:44 AM > To: jmccoy@... > Subject: Koni Web Site Contact - Heavy Duty > > name : John S. (Steve) Anderson > address : 1079 NW Liberty Ln Poulsbo, Wa. 98370 > phone : 360.779.4156 > fax : > Comments : I would like to purchase a set of KONI adjustable shocks for > my 1979 Blue Bird motorhome. The original coach shocks were Gabriel > brand. The part numbers I have for the front shocks are Gabriel part no. > 0680054 with a Blue Bird part no. 0614966. The stroke on these front > shocks is 8.76 in. The Gabriel part no for the rear shocks is 680010, > with a Blue Bird part no. of 0614974. The stroke for the rears is 7.51 > in. I will also need the bushings for all these shocks if they do not > come with the shocks. Please let me know the Koni part numbers, the cost > of these parts and how I can purchase them. VR Steve Anderson > SUBMIT : Submit Query > CFID : 13489092 > CFTOKEN : 4ca660c17daeb771-0B48770F-0869-F5AD-C1D91148BD7B0D5F > ************************************ > This e-mail and any files transmitted with it are proprietary and intended > solely > for the use of the individual or entity to whom they are addressed. If you > have > received this e-mail in error please notify the sender. Please note that any > views > or opinions presented in this e-mail are solely those of the author and do > not > necessarily represent those of ITT, Inc. > In a message dated 1/2/2007 5:22:39 PM Pacific Standard Time, > sundance101@... writes: > > > > > How do I determine which Bilsteins will fit our '84 FC31 WLII? > > The rear axle is air suspension and is no doubt the same setup as > other '84 FCs. > > The front axle is leaf springs and probably the same as FCs just before > BB started using air suspension (81? 82?). > > As always, thanks for the help! > > Bob Griesel '84 FC31 WLII WA > > > > > > > > > [Non-text portions of this message have been removed] > |
User(s) browsing this thread: 6 Guest(s)
