Shower Water Mixer Repair?
01-04-2007, 19:56
Kevin, when I had my 35 for sale and we were headed to RIV to deliver the
coach, same thing happened. Due to non use, it would not operate and we sprayed wd-40 in it. Finally had to take it apart and clean it. Guess it works, fine, now. Ernie Ekberg 83PT40 Weatherford, tx [Non-text portions of this message have been removed] |
01-04-2007, 20:10
I am not sure if you year BB uses the same shower valve as my 91, however, I
replaced the internal parts on my Moen shower faucet which fixed the mixing problem. Replacing the parts can be done without removing the valve. The Moen web site has assembly drawings you can navigate to. I ordered the parts from Moen. Roger Webb 91WBWL Cedar Rapids, IA [Non-text portions of this message have been removed] |
01-04-2007, 23:48
Hello:
My shower water mixer will no longer shut off on my 1982 PT40, and my questions is can this be repaired or do I have to replace it (I assume it is orginal)? I'm hoping it can be repaired since it will be "very" difficult to remove without damaging the shower stall. As always your help is greatly appreciated! Kevin Ford 1982 PT-40, Richmond TX |
01-05-2007, 00:40
Kevin:
I recently replaced the cartridge in my shower mixer valve because of the same problem. My mixer is a Moen. Take out the cartridge and a plumbing supply house can match it up. To remove the cartridge, remove the handle, remove the U clip and pull out the cartridge. Leroy Eckert 1990 WB-40 "Smoke N Mirrors" Niceville, FL ----- Original Message ----- From: Kevin Ford To: WanderlodgeForum@yahoogroups.com Sent: Friday, January 05, 2007 5:48 AM Subject: [WanderlodgeForum] Shower Water Mixer Repair? Hello: My shower water mixer will no longer shut off on my 1982 PT40, and my questions is can this be repaired or do I have to replace it (I assume it is orginal)? I'm hoping it can be repaired since it will be "very" difficult to remove without damaging the shower stall. As always your help is greatly appreciated! Kevin Ford 1982 PT-40, Richmond TX [Non-text portions of this message have been removed] |
01-05-2007, 01:45
Thats what I needed to know, you are a master...
Thanks Leroy! Kevin Ford 1982 PT-40 Richmond TX --- In WanderlodgeForum@yahoogroups.com, "Leroy Eckert" > > Kevin: > I recently replaced the cartridge in my shower mixer valve because of the same problem. My mixer is a Moen. Take out the cartridge and a plumbing supply house can match it up. To remove the cartridge, remove the handle, remove the U clip and pull out the cartridge. > > Leroy Eckert > 1990 WB-40 "Smoke N Mirrors" > Niceville, FL > > > > > > ----- Original Message ----- > From: Kevin Ford > To: WanderlodgeForum@yahoogroups.com > Sent: Friday, January 05, 2007 5:48 AM > Subject: [WanderlodgeForum] Shower Water Mixer Repair? > > > Hello: > My shower water mixer will no longer shut off on my 1982 PT40, and my > questions is can this be repaired or do I have to replace it (I assume > it is orginal)? I'm hoping it can be repaired since it will be "very" > difficult to remove without damaging the shower stall. > > As always your help is greatly appreciated! > > Kevin Ford > 1982 PT-40, Richmond TX > > > > > > [Non-text portions of this message have been removed] > |
01-05-2007, 01:49
Thanks Erine, I'm going to take it apart and have a look.
Kevin --- In WanderlodgeForum@yahoogroups.com, erniecarpet@... wrote: > > Kevin, when I had my 35 for sale and we were headed to RIV to deliver the > coach, same thing happened. Due to non use, it would not operate and we sprayed > wd-40 in it. Finally had to take it apart and clean it. Guess it works, fine, > now. > > Ernie Ekberg > 83PT40 > Weatherford, tx > > > > [Non-text portions of this message have been removed] > |
01-05-2007, 01:50
IF it is a Moen any HomeDepot,Lowe's or hardware store had the
replacement about $20.00. If you can wait Moen will sent it free, just call the 800 number. Bill 88 FC --- In WanderlodgeForum@yahoogroups.com, "Kevin Ford" > > Hello: > My shower water mixer will no longer shut off on my 1982 PT40, and my > questions is can this be repaired or do I have to replace it (I assume > it is orginal)? I'm hoping it can be repaired since it will be "very" > difficult to remove without damaging the shower stall. > > As always your help is greatly appreciated! > > Kevin Ford > 1982 PT-40, Richmond TX > |
01-05-2007, 01:50
Thanks Rogger I didn't think about checking the website, thats a good
idea. Kevin --- In WanderlodgeForum@yahoogroups.com, rogerwwebb@... wrote: > > I am not sure if you year BB uses the same shower valve as my 91, however, I > replaced the internal parts on my Moen shower faucet which fixed the mixing > problem. Replacing the parts can be done without removing the valve. > > The Moen web site has assembly drawings you can navigate to. I ordered the > parts from Moen. > > > Roger Webb > 91WBWL > Cedar Rapids, IA > > > [Non-text portions of this message have been removed] > |
01-05-2007, 02:37
Bill, took the words right out of my "keyboard" :>) I did alll the
valves in RUBY last fall, and they work great... Kevin, I would suggest you also get some "plumbers grease" to lube the o'rings inside. A tiny tube of "high temp, water proof" grease will work. I used Q tips to apply. Also on our 86FC I needed the "special wrench" (small plastice piece) came with the rebuild from HD to remove the existing core. Really easy job.. Good Luck Scott B 86FC35 RUBY Murrells Inlet SC "leaving for OKC in the am" --- In WanderlodgeForum@yahoogroups.com, "pattypape" wrote: > > > > IF it is a Moen any HomeDepot,Lowe's or hardware store had the > replacement about $20.00. If you can wait Moen will sent it free, just > call the 800 number. > > Bill 88 FC > > --- In WanderlodgeForum@yahoogroups.com, "Kevin Ford" wrote: > > > > Hello: > > My shower water mixer will no longer shut off on my 1982 PT40, and my > > questions is can this be repaired or do I have to replace it (I > assume > > it is orginal)? I'm hoping it can be repaired since it will be "very" > > difficult to remove without damaging the shower stall. > > > > As always your help is greatly appreciated! > > > > Kevin Ford > > 1982 PT-40, Richmond TX > > > |
01-05-2007, 02:51
Thanks Bill thats good to know.
Kevin --- In WanderlodgeForum@yahoogroups.com, "pattypape" wrote: > > > > IF it is a Moen any HomeDepot,Lowe's or hardware store had the > replacement about $20.00. If you can wait Moen will sent it free, just > call the 800 number. > > Bill 88 FC > > --- In WanderlodgeForum@yahoogroups.com, "Kevin Ford" wrote: > > > > Hello: > > My shower water mixer will no longer shut off on my 1982 PT40, and my > > questions is can this be repaired or do I have to replace it (I > assume > > it is orginal)? I'm hoping it can be repaired since it will be "very" > > difficult to remove without damaging the shower stall. > > > > As always your help is greatly appreciated! > > > > Kevin Ford > > 1982 PT-40, Richmond TX > > > |
