multiple inverters
01-08-2007, 03:53
multiple inverters
I have 2 trace 3KW inverters. How are they wired? I have
6 deep discharge batteries. Only one inverter is wired with a shunt. I'm guessing that both inverters connect to the full array of 6 batteries (wired in parallel) for inverting, and that only one inverter charges the batteries. Is this correct? Thanks, David Brady '02 LXi, Smokey NC |
01-08-2007, 06:05
multiple inverters
Probably... I, have 2 Heart inverters (2500 watts each), but only one
Link-R 2000 controller which seems to manage the charging. There's a second, less sophisticated, Heart controller but it seems to have a reporting function only (on the operation of the inverter it's attached to) and doesn't seem to affect the battery charging. I haven't tried to run down the functionality completely (yet) as everything is working and there are enough other things that seem to occupy my time on the coach. Pete Masterson aeonix1@... '95 Blue Bird Wanderlodge WBDA 42' El Sobrante, CA On Jan 8, 2007, at 7:53 AM, David Brady wrote: > I have 2 trace 3KW inverters. How are they wired? I have > 6 deep discharge batteries. Only one inverter is wired with > a shunt. I'm guessing that both inverters connect to the full > array of 6 batteries (wired in parallel) for inverting, and that > only one inverter charges the batteries. Is this correct? > > Thanks, > David Brady > '02 LXi, Smokey > NC [Non-text portions of this message have been removed] |
01-08-2007, 09:19
multiple inverters
Hi David,
My '99 may be different; I have two 3K inverters, two controllers and both inverters show that they are charging the batteries. One shuts down to "Float" ahead of the other. I'll check my box for wiring diagrams next tie out. Rich D. '99LXi43' CT --- In WanderlodgeForum@yahoogroups.com, David Brady > > I have 2 trace 3KW inverters. How are they wired? I have > 6 deep discharge batteries. Only one inverter is wired with > a shunt. I'm guessing that both inverters connect to the full > array of 6 batteries (wired in parallel) for inverting, and that > only one inverter charges the batteries. Is this correct? > > Thanks, > David Brady > '02 LXi, Smokey > NC > |
01-08-2007, 10:20
multiple inverters
Thanks Rich,
I'm not at the coach so I can't check things out first hand. I have the same set up you have. 2 Xantrex 3KW inverters, 6 Gel Cell batteries. Both inverter control panels show that the both charge. It's kind of strange that both would charge in parallel. It's more likely that one charges 3 batteries and the other charges 3, but I'm not sure. David Brady '02 LXi, Smoke NC g_man1146 wrote: > Hi David, > > My '99 may be different; I have two 3K inverters, two controllers and > both inverters show that they are charging the batteries. One shuts > down to "Float" ahead of the other. I'll check my box for wiring > diagrams next tie out. > Rich D. '99LXi43' CT > > --- In WanderlodgeForum@yahoogroups.com, David Brady > >> I have 2 trace 3KW inverters. How are they wired? I have >> 6 deep discharge batteries. Only one inverter is wired with >> a shunt. I'm guessing that both inverters connect to the full >> array of 6 batteries (wired in parallel) for inverting, and that >> only one inverter charges the batteries. Is this correct? >> >> Thanks, >> David Brady >> '02 LXi, Smokey >> NC >> >> > > |
