hydrogen in tires
01-10-2007, 03:39
hydrogen in tires
Pete,
If you're going to quote Wikipedia verbatim, at least credit the source.
David Brady
'02 LXi, Smoke
NC
Pete Masterson wrote:
> From Wikipedia:
> Nitrogen is a nonmetal, with an electronegativity of 3.0. It has five
> electrons in its outer shell and is therefore trivalent in most
> compounds. The triple bond in molecular nitrogen (N2) is the
> strongest in nature. The resulting difficulty of converting (N2) into
> other compounds, and the ease (and associated high energy release) of
> converting nitrogen compounds into elemental N2, have dominated the
> role of nitrogen in both nature and human economic activities. [In
> other words, many nitrogen compounds are quite explosive, but
> elemental nitrogen is quite stable.]
01-10-2007, 04:42
hydrogen in tires
My humblest apologies Pete. I'm now removing foot firmly wedged
in mouth. I must be blind, I truly didn't see your Wikipedia credit.
Again, my mistake.
David Brady
'02 LXi, Smoke
NC
Promise to lighten up in the future...
David Brady wrote:
> Pete,
> David Brady
> '02 LXi, Smoke
> NC
>> From Wikipedia:
> Yahoo! Groups Links
01-11-2007, 06:43
hydrogen in tires
I thought the nitrogen article was in FMCA. I just did a serch at FMCA
and my memory failed me again. Where ever it was, the article focused on
carrying a small tank of N to top off the tires to the correct pressure.
I have found a tire dealer in Harlingen, Tx that will fill my 8 tires
with N for $100. The big "gas" company will sell me a tank and regulator
for $250. The tank will have 2,200psi
and 100's of cubic feet of N. I am thinking it might be worth it.
Jack in Mich.
05 450Lxi
--- In WanderlodgeForum@yahoogroups.com, "Gardner Yeaw"
> There are at least two advantages to nitrogen.
> The first is that it should have little or no moisture because it is
> produced at a specialized facility where there should be certain
> levels of quality control. Compressed air from in-house compressors
> contains water, the amount depends on the current humidity.
> Second, nitrogen is an inert gas, that is to say it does not
> react chemicaly with anything. Oxygen, as you know, reacts with most
> everything. So filling with nitrogen will prevent oxidation of the
> inner tire as well as the rim.
> Is it worth the extra cost, if any? I don't know. But if you
> decide to go that way you need to continue to use it wen you adjust
> tire pressure or you will end up contaminating the atmosphere inside
> the tire. So carry a tank of nitrogen or seek out local suppliers.
> Gardner
> 78FC33
> --- In WanderlodgeForum@yahoogroups.com, krminyl@ wrote:
> > I think the main advantage of nitrogen vs. compressed air is that
> the
> > nitrogen is dry, and has no moisture in it, which is bad for
> tires. Costco, who is
> > now becoming one of the nation's largest passenger car and light
> truck tire
> > retailers, now use nitrogen when installing their new tires.
> that's what
> > they told me anyway...FWIW....
> > Kevin
> > Yorba Linda, CA
> > 1986 38' PT
01-12-2007, 00:58
hydrogen in tires
Clearly too much time on your hands, looking at the length of this
thread.
Jim
--- In WanderlodgeForum@yahoogroups.com, David Brady
> Again, my mistake.
> David Brady
> '02 LXi, Smoke
> NC
> David Brady wrote:
> > Pete,
source.
> > David Brady
> > '02 LXi, Smoke
> > NC
> >> From Wikipedia:
five
into
release) of
[In
> > Yahoo! Groups Links
