Putting in a Fantastic Fan in the kitchen
01-19-2007, 13:24
Hi group,
I have a roof vent in the kitchen that isn't motorized and I want to
change it to a Fantastic fan.
Problem is there is no 12v close by. I have a ceiling light by the
sink, but since it is controlled by a switch at the sink, it doesn't
seem to me right to tap into the wires at the light. I would have to
leave the light on all the time.
The only other think I can think of is to take a plumbers tape and go
across to the back of the fridge and poke a hole in the ceiling panel
and get power that way.
Anybody do this mod and get power some other way?
Bob Lawrence
84 PT 36
Tacoma, Wa. (with 8 months left before we fulltime outta here)
01-19-2007, 14:23
This may be a long shot.
Is it possible to disconnect the hot wire at the light fixture, attach .032
safety wire to it and pull it back to the light switch. Attach a second wire to
the .032 safety wire and pull both wires back to the light fixture.( Tape the
end before pulling) Connect the fan wire to the constant hot side of the light
switch. Reconnect the light fixture wire. Find a place in the fixture or the
fan housing to fuse the fan line per manufactures spec's. Then you need the
ground.
I have used this procedure to pull wires with excellent results.
Your post indicates the light is 12v, I hope. I have ignored the possible need
for a relay.
Leroy Eckert
1990 WB-40"Smoke N Mirrors
Niceville, FL
Sent: Friday, January 19, 2007 7:24 PM
Subject: [WanderlodgeForum] Putting in a Fantastic Fan in the kitchen
Hi group,
Bob Lawrence
84 PT 36
01-19-2007, 16:52
Thanks, Leroy,
That might be possible...thanks again.
Bob
attach .032 safety wire to it and pull it back to the light switch.
Attach a second wire to the .032 safety wire and pull both wires back
to the light fixture.( Tape the end before pulling) Connect the fan
wire to the constant hot side of the light switch. Reconnect the
light fixture wire. Find a place in the fixture or the fan housing
ground.
possible need for a relay.
> Leroy Eckert
> Niceville, FL
> From: Bob Lawrence
kitchen
> Hi group,
to
doesn't
to
and go
panel
> Bob Lawrence
> 84 PT 36
01-19-2007, 18:13
Bob,
When you take the old vent out probe around a little. There is a lot of
wiring that crosses over next to the ceiling ribs. Some of it is AC and some
DC but in my coach the AC is in ROMAX. If you find DC check to which
circuit it is, you may find you have power right there.
- Chuck Wheeler -
82 FC 31 SB
Fort Worth, TX
_____
[mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Bob Lawrence
Sent: Friday, January 19, 2007 10:52 PM
Subject: [WanderlodgeForum] Re: Putting in a Fantastic Fan in the kitchen
Thanks, Leroy,
Bob
ground.
> Leroy Eckert
> Niceville, FL
> From: Bob Lawrence
yahoogroups.com
kitchen
> Hi group,
to
doesn't
to
and go
panel
> Bob Lawrence
> 84 PT 36
01-19-2007, 18:53
Right Check. I believe BB originally wired the area with 12V. Maybe
someone modified that area, but the 12V should still be there. Pull down
the vent and check. I'd be surprised if you do not find 12V wiring in
that area.
Curt Sprenger
Anaheim Hills, Calif.
Chuck Wheeler wrote:
> Bob,
> and some
> - Chuck Wheeler -
> 82 FC 31 SB
> Fort Worth, TX
> _____
> Thanks, Leroy,
> Bob
> ground.
> > Leroy Eckert
> > Niceville, FL
> > From: Bob Lawrence
> yahoogroups.com
> kitchen
> > Hi group,
> to
> the
> doesn't
> to
> and go
> panel
> > Bob Lawrence
> > 84 PT 36
01-19-2007, 23:32
Hey Bob , You could check to see if the switch switches the positive or the
ground. It could be that the 12 V is at the light full time and the light
switch completes the circuit to ground.
Steve
In a message dated 1/19/2007 5:28:25 PM Pacific Standard Time,
bobandarlene@... writes:
Hi group,
Bob Lawrence
84 PT 36
01-20-2007, 06:07
Thanks Curt,
I'll check this first.
Bob
down
in
> that area.
> Curt Sprenger
> > Bob,
lot of
AC
> > and some
which
> > - Chuck Wheeler -
> > 82 FC 31 SB
> > Fort Worth, TX
01-20-2007, 06:09
Thanks Steve,
I'll put a meter on the wires and see.
Bob
or the
light
> Steve
01-20-2007, 08:35
Hi Bob - I recently pulled a bunch of cable and air hose all over the
ceiling of our rig (Solar battery system and new air horns). I can
help you if you aren't done by the next time we get together. Once you
get to the raceways behind the overheads there is always a way to get
power, including establishing a new branch circuit if needed. Piece of
cake!
Bob Griesel '84 FC31 WLII WA
> Hi group,
> Bob Lawrence
> 84 PT 36
01-20-2007, 13:59
Curt,
Found 12 volts stuffed up behind the vent. Looks like this was done
at the factory. Tied off and not used. Had 12v there. Will be a
simple job to add the fan now....thanks again...saved me $ and time.
Bob Lawrence
84 PT36
Tacky Tacoma Wa. (actually Lakewood, where that 9 yr old kid stole a
car and got on 2 planes to fly to Texas because he didn't want to
live next door to a molester..lot of them here)
--- In WanderlodgeForum@yahoogroups.com, "Bob Lawrence"
> Thanks Curt,
> Bob
Maybe
Pull
> down
wiring
> in
> > that area.
> > Curt Sprenger
> > > Bob,
a
> lot of
is
> AC
> > > and some
> which
> > > - Chuck Wheeler -
> > > 82 FC 31 SB
> > > Fort Worth, TX
