Differential Type and Fluid for 79 FC 35
01-19-2007, 22:44
What type, brand, model, etc., of differential would I likely have on my
79 BB? It has a 4 speed forward, including drive, automatic transmission and a 3208 NA engine. Thanks. Henry Claeys, 1979 FC 35, McAllen, Tx. 1.888.745.1439 and at henry@... |
01-20-2007, 08:42
Henry - Not knowing what I had in the diff, I asked my shop to do it
and let me know what they found. There was synthetic diff lube in the housing and they replaced it with the same. It probably didn't need to be changed. The only benefits are that I now know the lube was clean and how long its been in there. Bob Griesel '84 FC31 WLII WA > > What type, brand, model, etc., of differential would I likely have on my > 79 BB? It has a 4 speed forward, including drive, automatic > transmission and a 3208 NA engine. Thanks. Henry Claeys, 1979 FC 35, > McAllen, Tx. 1.888.745.1439 and at henry@... > |
01-20-2007, 09:52
Henry - Just realized I didn't answer the question you asked. Telma
wanted that same info when I bought the retarder. I could not determine the make and model then, but have since heard it is a Rockwell. Bob. > > Henry - Not knowing what I had in the diff, I asked my shop to do it > and let me know what they found. There was synthetic diff lube in the > housing and they replaced it with the same. It probably didn't need to > be changed. The only benefits are that I now know the lube was clean > and how long its been in there. > > Bob Griesel '84 FC31 WLII WA > > > > > What type, brand, model, etc., of differential would I likely have on > my > > 79 BB? It has a 4 speed forward, including drive, automatic > > transmission and a 3208 NA engine. Thanks. Henry Claeys, 1979 FC > 35, > > McAllen, Tx. 1.888.745.1439 and at henry@ > > > |
