1985FC Air pressure loss
01-27-2007, 09:44
When i take off the parking brake the air pressure drops from 125psi to
below 75. If i put the parking brake back on the pressure will build back up. Any ideas what is wrong? Dan Williams 85FC35 Jackson, MS |
01-27-2007, 09:50
Dan:
Have some one release the spring break while you listen for air escaping at the rear of the Coach just behind the drive tires. Sounds like you have a ruptured spring break air chamber. Also is air escaping at the spring break release valve on the dash? Ralph Safe travels, Ralph and Charolette Fullenwider 84FC35 Ralph's RV Solutions, Duncan, Oklahoma At 09:44 PM 1/27/2007 +0000, you wrote: >When i take off the parking brake the air pressure drops from 125psi to >below 75. If i put the parking brake back on the pressure will build >back up. Any ideas what is wrong? > >Dan Williams >85FC35 >Jackson, MS > > |
01-27-2007, 10:17
Sounds like a park brake switch or more likely a rear spring brake
canister, Do not try to take that spring apart. It may hurt ya. BIll 88 FC --- In WanderlodgeForum@yahoogroups.com, "maureyroad" wrote: > > When i take off the parking brake the air pressure drops from 125psi to > below 75. If i put the parking brake back on the pressure will build > back up. Any ideas what is wrong? > > Dan Williams > 85FC35 > Jackson, MS > |
