Freeze protection heaters
02-01-2007, 08:45
While I was stopped due to the bad weather, I was doing a check on my
heaters. The kitchen heater was running but putting out no heat. I
took one of Brenda's hair dryers and put it in that compartment. Works
like a charm.
My rear heater by the hot water heater, the fan was barely moving.
Don't know why- these things are just 24 years old. Took the partition
out of that compartment and added a ceramic heater to that area.
Perhaps this was the problem I was having last year. Time to look for
new heaters. Anyone know where we can find small, compact heaters like
came in our coaches? Ernie-83PT40 in Buffalo, Wy, for a short time, I
hope
02-01-2007, 09:22
you talking electric or chassis units?
MH
Sent: Thursday, February 01, 2007 2:45 PM
Subject: [WanderlodgeForum] Freeze protection heaters
like a charm.
hope
02-01-2007, 09:27
The little heaters behind the kitchen cabinets. Those worked really well, 20
years ago. Ernie-83PT40, 8 degrees outside wind from north 35-45-- like its
cold, man!
Sent: Thursday, February 01, 2007 2:22 PM
Subject: Re: [WanderlodgeForum] Freeze protection heaters
MH
like a charm.
hope
02-01-2007, 11:05
I'm not sure what heaters you're wanting... the newer coaches use
"Perfectoe" electric heaters in the bathroom and under the kitchen
cabinets. See <http://www.electricsuppliesonline.com/pelhe.html> for
a description. These are available in 120 or 208/240V models. The
120V model is used in my coach.
For the hot-water radiator-type heat, (hydronic heating system) the
fans used are simple "pancake" fans available in 120V and 12V ratings
at places like Radio Shack. (Check to see what voltage is used on the
one you're replacing.) If the radiators aren't getting hot, then you
may have a valve set wrong, a blocked water line, or another problem.
Perhaps someone with a closer aged coach can make some suggestions.
Pete Masterson
aeonix1@...
El Sobrante, CA
> like a charm.
> hope
02-01-2007, 11:10
These are the freeze protection heaters that are located in the hot water tank
area, under the kitchen sink, and in the fresh water compartment. Since my coach
is old, i was asking if anyone repleced these with newer more efficient models.
These are electric. Ernie-83PT40 in Wyoming
Sent: Thursday, February 01, 2007 4:05 PM
Pete Masterson
aeonix1@...
El Sobrante, CA
> like a charm.
> hope
02-01-2007, 13:36
Ernie & Group,
My 82 PT doesn't have any of the heaters that you describe. Wish that
it did. All I have are some old Frostex heat tapes. Plugged one in a
while back & it immediately burned the plug off the end of the tape. No
heat tapes plugged in anymore.
Terry Neal
Bozeman, MT
82PT40
74FC34
> water tank area, under the kitchen sink, and in the fresh water
> compartment. Since my coach is old, i was asking if anyone repleced
> these with newer more efficient models. These are electric.
> From: Pete Masterson
> <http://www.electricsuppliesonline.com/pelhe.html>> for
> Pete Masterson
> aeonix1@...
> El Sobrante, CA
> > like a charm.
> > hope
02-01-2007, 13:43
I took those little heaters apart and fixed them. One had burned the
wire leading to the heater elememt, and the other just needed a
little cleaning and oil. They both run great now.
Gardner
78FC33
really well, 20 years ago. Ernie-83PT40, 8 degrees outside wind from
north 35-45-- like its cold, man!
> From: Mike Hohnstein
> MH
> From: Ernest Ekberg
on my
I
Works
> like a charm.
moving.
partition
look for
heaters like
time, I
> hope
02-01-2007, 13:50
terry- is that the light blue color plugs and wires that run who knows where?
Both my birds had those and I was afraid to plug those in because, 1- didn't
know if they worked, 2- did previous owners cut those somewhere, and 3- after 24
years- deterioration of those wires could possibly start a fire. So- I have
removed most of those wires when I was adding my pex tubing last summer.
Ernie-83PT40 in -4 Wyoming
Sent: Thursday, February 01, 2007 6:36 PM
Ernie & Group,
Terry Neal
Bozeman, MT
82PT40
74FC34
> Pete Masterson
> aeonix1@...
> El Sobrante, CA
> > like a charm.
> > hope
02-01-2007, 13:58
Yep, those are the wires for the heat tapes. I plugged the one in the
bathroom into it's outlet & it fried the plug right off in my hand.
They will all come out when I replace the water lines too. With the
PEX, you shouldn't really need them as long as you can maintain some
degree of heat tin the spaces where the water lines are located.
Terry Neal
Bozeman, MT
82PT40
74FC34
> where? Both my birds had those and I was afraid to plug those in
> because, 1- didn't know if they worked, 2- did previous owners cut
> those somewhere, and 3- after 24 years- deterioration of those wires
> could possibly start a fire. So- I have removed most of those wires
> when I was adding my pex tubing last summer. Ernie-83PT40 in -4 Wyoming
> From: Terry Neal
> Ernie & Group,
> Terry Neal
> Bozeman, MT
> 82PT40
> 74FC34
> <http://www.electricsuppliesonline.com/pelhe.html>>> for
> > Pete Masterson
> > aeonix1@...
> > El Sobrante, CA
> > > like a charm.
> > > hope
02-01-2007, 13:59
Hi Gardner- I have operated on those heaters and have come to the conclusion
that they are terminal. the housings will not hold the small squirrel cage and
the wiring is toast. One of the squirrel cages is so far out of round that when
we had a guest stay in the coach, he said he would get a motel instead of
staying "in that coach, again" Yea- WE know who you are~ Ernie -83PT40 in
Wyoming
Sent: Thursday, February 01, 2007 6:43 PM
Subject: [WanderlodgeForum] Re: Freeze protection heaters
Gardner
78FC33
> MH
> From: Ernest Ekberg
on my
I
Works
> like a charm.
moving.
partition
look for
heaters like
time, I
> hope
