City water regulator
02-05-2007, 02:56
Has anyone replaced a city water regulator on a 89 36SP?
How to you gain access to the back of the regulator?
02-05-2007, 04:23
If the regulator has 2 small holes on each side of the water hose
connector, you get a new one from BB, then simply unscrew the center part
out of the existing housing with either needle nose pliers or if large
enough a set of snap ring pliers, se the old parts aside. Remove the new
regulator parts form the new one and install in the original housing. About
a 10 minute job. If not this style then you in for a cramped job getting to
the back of that one via a small space in the same area as the water heater
or just toward the front from there.
Safe travels,
84FC35
