Aqua Hot Circulation Pump Motor
02-05-2007, 14:14
Anyone know of a good source for an Aqua Hot circulation pump motor?
The part number is 2310122 made by RAE Corporation. Thanks, Ivan |
02-05-2007, 16:28
Since you have the part # I guess you have the manual. I have a Wabasto
interestingly enough with Aqua Hot filter. I have to order the filter from Aqua Hot. You may have to do the same for the pump. I may have the same pump. Don't know, since the manual is in the bus. If you would like I will check. Leroy Eckert 1990 WB-40 "Smoke N Mirrors" Niceville, FL ----- Original Message ----- From: manitowoc21000 To: WanderlodgeForum@yahoogroups.com Sent: Monday, February 05, 2007 8:14 PM Subject: [WanderlodgeForum] Aqua Hot Circulation Pump Motor Anyone know of a good source for an Aqua Hot circulation pump motor? The part number is 2310122 made by RAE Corporation. Thanks, Ivan [Non-text portions of this message have been removed] |
