power problem on 88 pt 40
02-09-2007, 13:30
we just returned to our bus and there is a problem with the power.
seems that all the electrical in the front of the bus is off. the
lights and heater work in the bathroom the water heater works and some
of the lights in the bedroom work, also it sounds like the battery
charger is on. the lights at the shore power connector are normal. any
ideas on what i need to check? i checked the breaker box and they
seemed fine. thanks
Robert Rahn
88 pt 40
Kalispell, Mt.
02-09-2007, 13:42
we have just returned to our bus and there is a problem with the power.
none of the electrical things seem to be working at the front of the
bus. the lights and electric heater work in the bathroom and the
battery charger and water heater are working. the gauge at the front of
the bus shows leg one amp at zero. I checked the breakers and they seem
normal. the lights at the shore power connector are normal. any ideas
where i should look? thank you
Robert Rahn
88 pt 40
Kalispell, Mt.
02-09-2007, 13:46
AT switch on the Dash???
Greg
--- In WanderlodgeForum@yahoogroups.com, "Robert & Teri Rahn"
some
any
> seemed fine. thanks
> Robert Rahn
> 88 pt 40
> Kalispell, Mt.
02-09-2007, 13:53
Do you have the inverter off? it may have to do with the inverter power
switch that keeps two sources from powering one thing????
94pt
power.
of
seem
> Robert Rahn
> 88 pt 40
> Kalispell, Mt.
02-09-2007, 13:58
I would check the power source first to see if two legs have power.
Leroy Eckert
1990 WB-40"Smoke N Mirrors"
Niceville, FL
Sent: Friday, February 09, 2007 7:42 PM
Subject: [WanderlodgeForum] power problem on 88 pt 40
Robert Rahn
88 pt 40
Kalispell, Mt.
02-09-2007, 13:58
Terry- I wonder if one of the legs to your power cord is bad?
Do you have power to both legs?
83PT40
Livingston,Montana
Sent: Friday, February 09, 2007 6:46 PM
Subject: [WanderlodgeForum] Re: power problem on 88 pt 40
Greg
some
any
> seemed fine. thanks
> Robert Rahn
> 88 pt 40
> Kalispell, Mt.
02-09-2007, 13:58
Robert, sounds like one of your main breakers has tripped yet you don't
see that at the breaker panel. Try turning off all of the breakers &
then turning them on, one at a time.
Also, you could have a loose connection in your shore power plug or the
inlet wiring into the coach? Has it been plugged in all the time? If
you show -0- amps on one leg, you are only getting 120 volts into the
coach system, not 240. This assumes you are plugged into a 240 volt 50
amp service? If you are plugged into 120 volt 30 amp service, you have
a problem in your plug or in the main breaker box. Try turning off the
"Main" breakers & then turn them back on to see if that solves your problem.
Terry Neal
Bozeman, MT
82PT40
74FC34
> Robert Rahn
> 88 pt 40
> Kalispell, Mt.
02-09-2007, 13:59
Robert, Like LeRoy said, you may have some LED lights where you stow
the cord. My 94 has one green for each leg , I think it says
Polarity?? if only one is on, unplug the bus and shut down the park
50 amp service then switch it back on, and plug in again.
Greg
> Leroy Eckert
> Niceville, FL
> From: Robert & Teri Rahn
power.
front of
they seem
ideas
> Robert Rahn
> 88 pt 40
> Kalispell, Mt.
02-09-2007, 14:00
I have had a breaker go off, and in my closet, its hard to see. But I manually
trip those breakers and reset them
83PT40
Livingston,Montana
Sent: Friday, February 09, 2007 6:30 PM
seemed fine. thanks
Robert Rahn
88 pt 40
Kalispell, Mt.
02-09-2007, 14:11
For a night time fix, I would just shut down all the brakers except the
on that runs the hotwater and the battery chargers then turn on the
inverter. If it is a loose wire in a cord or park box, it may be best
to find it in the light of Day.
GregoryO'Connor
94ptRomolandCa
