Camera
02-11-2007, 06:23
Camera
My camera is intermittant. When it works it has a shape picture. I
believe the potentiometer is going in the tank. I have contacted Tim at RVcams and am awaiting a response. Info: Camera is Sanyo CCD Computar Wide Attack, Model VDC 3800 Tube is Clinton Tiawan Corp Potentiometer is A-B Mod Pot PN 26M955. Cannot locate one even at a guitar parts house to see if it is the problem- I'm told they are unavailable. I'm about to give up and retrofit. I saw a post where someone retrofitted a system without rewiring the bus. Any info would help. Good or Bad. Thanks. Leroy Eckert 1990 WB-40 "Smoke N Mirrors" Niceville, FL |
02-11-2007, 06:40
Camera
--- In WanderlodgeForum@yahoogroups.com, "jwasnewski"
> > My camera is intermittant. When it works it has a shape picture. I > believe the potentiometer is going in the tank. I have contacted Tim > at RVcams and am awaiting a response. > > Info: > > Camera is Sanyo CCD Computar Wide Attack, Model VDC 3800 > Tube is Clinton Tiawan Corp > Potentiometer is A-B Mod Pot PN 26M955. Cannot locate one even at a > guitar parts house to see if it is the problem- I'm told they are > unavailable. I'm about to give up and retrofit. > > I saw a post where someone retrofitted a system without rewiring the > bus. Any info would help. Good or Bad. Thanks. > > Leroy Eckert > 1990 WB-40 "Smoke N Mirrors" > Niceville, FL > |
02-11-2007, 06:40
Camera
02-11-2007, 06:49
Camera
Sorry, I hit the wrong "thingie"
Leroy, Since you do have a good picture when it is working you might try replacing the potentiometer if it is the one overhead apart from the TV. Pot is an abreviation for the word potentiometer. 3 terminals, one in the center is a wiper and gets a glaze from use. Sometimes a spray into the opening will clear it up. Two major concerns on replacement are resistance value and wattage, along with shaft configuration. Disconnected, measure the resistance between the outer terminals, this will determine resistance value. Physical size will determine wattage. Even if the part number doesn't match you can replace from an electronics shop of the web. bob janes, 87fc35, greenville, sc --- In WanderlodgeForum@yahoogroups.com, "jwasnewski" > > My camera is intermittant. When it works it has a shape picture. I > believe the potentiometer is going in the tank. I have contacted Tim > at RVcams and am awaiting a response. > > Info: > > Camera is Sanyo CCD Computar Wide Attack, Model VDC 3800 > Tube is Clinton Tiawan Corp > Potentiometer is A-B Mod Pot PN 26M955. Cannot locate one even at a > guitar parts house to see if it is the problem- I'm told they are > unavailable. I'm about to give up and retrofit. > > I saw a post where someone retrofitted a system without rewiring the > bus. Any info would help. Good or Bad. Thanks. > > Leroy Eckert > 1990 WB-40 "Smoke N Mirrors" > Niceville, FL > |
02-11-2007, 07:07
Camera
Thanks Bob:
I think mine is called a concentric potentiometer, I am not certain, it appears to be a sealed version, has two dials one on top of the other similar to the old volume, bass controls on a car radio and it says it is 100/500K. I think it has 6 small wires. It is used for contrast and brightness on the tube. I went to the web on a guitar site and see some similar but the ratings are different. Then I have to do something with the knobs. Thanks in advance for your help. Leroy Eckert 1990 WB-40"smoke N Mirrors" Niceville,FL ----- Original Message ----- From: one_dusty_hoot To: WanderlodgeForum@yahoogroups.com Sent: Sunday, February 11, 2007 12:49 PM Subject: [WanderlodgeForum] Re: Camera Sorry, I hit the wrong "thingie" Leroy, Since you do have a good picture when it is working you might try replacing the potentiometer if it is the one overhead apart from the TV. Pot is an abreviation for the word potentiometer. 3 terminals, one in the center is a wiper and gets a glaze from use. Sometimes a spray into the opening will clear it up. Two major concerns on replacement are resistance value and wattage, along with shaft configuration. Disconnected, measure the resistance between the outer terminals, this will determine resistance value. Physical size will determine wattage. Even if the part number doesn't match you can replace from an electronics shop of the web. bob janes, 87fc35, greenville, sc --- In WanderlodgeForum@yahoogroups.com, "jwasnewski" > > My camera is intermittant. When it works it has a shape picture. I > believe the potentiometer is going in the tank. I have contacted Tim > at RVcams and am awaiting a response. > > Info: > > Camera is Sanyo CCD Computar Wide Attack, Model VDC 3800 > Tube is Clinton Tiawan Corp > Potentiometer is A-B Mod Pot PN 26M955. Cannot locate one even at a > guitar parts house to see if it is the problem- I'm told they are > unavailable. I'm about to give up and retrofit. > > I saw a post where someone retrofitted a system without rewiring the > bus. Any info would help. Good or Bad. Thanks. > > Leroy Eckert > 1990 WB-40 "Smoke N Mirrors" > Niceville, FL > [Non-text portions of this message have been removed] |
02-11-2007, 07:37
Camera
Leroy,
I sent to you the information that I recorded when doing our backup camera and LCD project. Hope it helps. Good luck. Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, Calif. Leroy Eckert wrote: > Thanks Bob: > I think mine is called a concentric potentiometer, I am not certain, > it appears to be a sealed version, has two dials one on top of the > other similar to the old volume, bass controls on a car radio and it > says it is 100/500K. I think it has 6 small wires. It is used for > contrast and brightness on the tube. I went to the web on a guitar > site and see some similar but the ratings are different. Then I have > to do something with the knobs. Thanks in advance for your help. > > Leroy Eckert > 1990 WB-40"smoke N Mirrors" > Niceville,FL > > ----- Original Message ----- > From: one_dusty_hoot > To: WanderlodgeForum@yahoogroups.com > > Sent: Sunday, February 11, 2007 12:49 PM > Subject: [WanderlodgeForum] Re: Camera > > Sorry, I hit the wrong "thingie" > > Leroy, > Since you do have a good picture when it is > working you might try replacing the potentiometer > if it is the one overhead apart from the TV. > > Pot is an abreviation for the word potentiometer. > 3 terminals, one in the center is a wiper and > gets a glaze from use. Sometimes a spray into the > opening will clear it up. > > Two major concerns on replacement are resistance > value and wattage, along with shaft configuration. > Disconnected, measure the resistance between the > outer terminals, this will determine resistance value. > Physical size will determine wattage. Even if the > part number doesn't match you can replace from an > electronics shop of the web. > > bob janes, 87fc35, greenville, sc > > --- In WanderlodgeForum@yahoogroups.com > > > > > > My camera is intermittant. When it works it has a shape picture. > I > > believe the potentiometer is going in the tank. I have contacted > Tim > > at RVcams and am awaiting a response. > > > > Info: > > > > Camera is Sanyo CCD Computar Wide Attack, Model VDC 3800 > > Tube is Clinton Tiawan Corp > > Potentiometer is A-B Mod Pot PN 26M955. Cannot locate one even at a > > guitar parts house to see if it is the problem- I'm told they are > > unavailable. I'm about to give up and retrofit. > > > > I saw a post where someone retrofitted a system without rewiring > the > > bus. Any info would help. Good or Bad. Thanks. > > > > Leroy Eckert > > 1990 WB-40 "Smoke N Mirrors" > > Niceville, FL > > > > [Non-text portions of this message have been removed] > > |
02-11-2007, 07:55
Camera
Thank you.
Leroy Eckert 1990 WB-40"Smoke N Mirrors" Niceville, FL ----- Original Message ----- From: Curt Sprenger To: WanderlodgeForum@yahoogroups.com Sent: Sunday, February 11, 2007 1:37 PM Subject: Re: [WanderlodgeForum] Re: Camera Leroy, I sent to you the information that I recorded when doing our backup camera and LCD project. Hope it helps. Good luck. Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, Calif. Leroy Eckert wrote: > Thanks Bob: > I think mine is called a concentric potentiometer, I am not certain, > it appears to be a sealed version, has two dials one on top of the > other similar to the old volume, bass controls on a car radio and it > says it is 100/500K. I think it has 6 small wires. It is used for > contrast and brightness on the tube. I went to the web on a guitar > site and see some similar but the ratings are different. Then I have > to do something with the knobs. Thanks in advance for your help. > > Leroy Eckert > 1990 WB-40"smoke N Mirrors" > Niceville,FL > > ----- Original Message ----- > From: one_dusty_hoot > To: WanderlodgeForum@yahoogroups.com > > Sent: Sunday, February 11, 2007 12:49 PM > Subject: [WanderlodgeForum] Re: Camera > > Sorry, I hit the wrong "thingie" > > Leroy, > Since you do have a good picture when it is > working you might try replacing the potentiometer > if it is the one overhead apart from the TV. > > Pot is an abreviation for the word potentiometer. > 3 terminals, one in the center is a wiper and > gets a glaze from use. Sometimes a spray into the > opening will clear it up. > > Two major concerns on replacement are resistance > value and wattage, along with shaft configuration. > Disconnected, measure the resistance between the > outer terminals, this will determine resistance value. > Physical size will determine wattage. Even if the > part number doesn't match you can replace from an > electronics shop of the web. > > bob janes, 87fc35, greenville, sc > > --- In WanderlodgeForum@yahoogroups.com > > > > > > My camera is intermittant. When it works it has a shape picture. > I > > believe the potentiometer is going in the tank. I have contacted > Tim > > at RVcams and am awaiting a response. > > > > Info: > > > > Camera is Sanyo CCD Computar Wide Attack, Model VDC 3800 > > Tube is Clinton Tiawan Corp > > Potentiometer is A-B Mod Pot PN 26M955. Cannot locate one even at a > > guitar parts house to see if it is the problem- I'm told they are > > unavailable. I'm about to give up and retrofit. > > > > I saw a post where someone retrofitted a system without rewiring > the > > bus. Any info would help. Good or Bad. Thanks. > > > > Leroy Eckert > > 1990 WB-40 "Smoke N Mirrors" > > Niceville, FL > > > > [Non-text portions of this message have been removed] > > [Non-text portions of this message have been removed] |
02-11-2007, 08:19
Camera
Hi Leroy, Like Curt I also revamped my back-up camera system. I bought from
Tim at http://www.rvcams.com . I used existing coax cable with a radio shack S to Coax cable conversion. Sorry can't remember the part number. On 11/02/07, jwasnewski > > My camera is intermittant. When it works it has a shape picture. I > believe the potentiometer is going in the tank. I have contacted Tim > at RVcams and am awaiting a response. > > Info: > > Camera is Sanyo CCD Computar Wide Attack, Model VDC 3800 > Tube is Clinton Tiawan Corp > Potentiometer is A-B Mod Pot PN 26M955. Cannot locate one even at a > guitar parts house to see if it is the problem- I'm told they are > unavailable. I'm about to give up and retrofit. > > I saw a post where someone retrofitted a system without rewiring the > bus. Any info would help. Good or Bad. Thanks. > > Leroy Eckert > 1990 WB-40 "Smoke N Mirrors" > Niceville, FL > > > -- Rob, Sue & Merlin Robinson 94 WLWB [Non-text portions of this message have been removed] |
02-11-2007, 08:27
Camera
Thanks for the info. I'm about ready to junk the old one and update. By the
time I fix the old one I still have an old one. Leroy Eckert 1990 WB-40"Smoke N Mirrors" Niceville, FL ----- Original Message ----- From: Rob Robinson To: WanderlodgeForum@yahoogroups.com Sent: Sunday, February 11, 2007 2:19 PM Subject: Re: [WanderlodgeForum] Camera Hi Leroy, Like Curt I also revamped my back-up camera system. I bought from Tim at http://www.rvcams.com . I used existing coax cable with a radio shack S to Coax cable conversion. Sorry can't remember the part number. On 11/02/07, jwasnewski > > My camera is intermittant. When it works it has a shape picture. I > believe the potentiometer is going in the tank. I have contacted Tim > at RVcams and am awaiting a response. > > Info: > > Camera is Sanyo CCD Computar Wide Attack, Model VDC 3800 > Tube is Clinton Tiawan Corp > Potentiometer is A-B Mod Pot PN 26M955. Cannot locate one even at a > guitar parts house to see if it is the problem- I'm told they are > unavailable. I'm about to give up and retrofit. > > I saw a post where someone retrofitted a system without rewiring the > bus. Any info would help. Good or Bad. Thanks. > > Leroy Eckert > 1990 WB-40 "Smoke N Mirrors" > Niceville, FL > > > -- Rob, Sue & Merlin Robinson 94 WLWB [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] |
02-11-2007, 11:41
Camera
Leroy, I dont know what part in the Backup camera does the image
reversing but that is important to match if your replacement part holds that obligation. GregoryO'Connor 94ptRomolandCa --- In WanderlodgeForum@yahoogroups.com, "Leroy Eckert" > > Thanks for the info. I'm about ready to junk the old one and update. By the time I fix the old one I still have an old one. > > Leroy Eckert > 1990 WB-40"Smoke N Mirrors" > Niceville, FL > > > > ----- Original Message ----- > From: Rob Robinson > To: WanderlodgeForum@yahoogroups.com > Sent: Sunday, February 11, 2007 2:19 PM > Subject: Re: [WanderlodgeForum] Camera > > > Hi Leroy, Like Curt I also revamped my back-up camera system. I bought from > Tim at http://www.rvcams.com . I used existing coax cable with a radio shack S to > Coax cable conversion. Sorry can't remember the part number. > > On 11/02/07, jwasnewski > > > > My camera is intermittant. When it works it has a shape picture. I > > believe the potentiometer is going in the tank. I have contacted Tim > > at RVcams and am awaiting a response. > > > > Info: > > > > Camera is Sanyo CCD Computar Wide Attack, Model VDC 3800 > > Tube is Clinton Tiawan Corp > > Potentiometer is A-B Mod Pot PN 26M955. Cannot locate one even at a > > guitar parts house to see if it is the problem- I'm told they are > > unavailable. I'm about to give up and retrofit. > > > > I saw a post where someone retrofitted a system without rewiring the > > bus. Any info would help. Good or Bad. Thanks. > > > > Leroy Eckert > > 1990 WB-40 "Smoke N Mirrors" > > Niceville, FL > > > > > > > > -- > Rob, Sue & Merlin Robinson > 94 WLWB > > [Non-text portions of this message have been removed] > > > > > > [Non-text portions of this message have been removed] > |
