Looking to purchase used 1992 WB40
03-06-2007, 10:48
I am looking at purchasing a used 1992 WB40, I was wanting to know
what things to look out for on this year model. I was told by the current owner that one of the Primus heaters is a little flaky, and as I understand by reading at various places that this should be of concern since there is only one place to get parts. He said he did not know what the issue was as it works sometimes, and does not others, but the other unit works all the time. New fridge. Cooktop and washer/dryer have not been used during the current owners 10 year term. What other items should I look for while inspecting a coach of this year model that might be a big ticket items? Coach has ~140K miles ~3000 hours on 8V92, 4 years on tires (kept inside), 4 years on GEL cells (low batt charger plugged in while in storage). Thanks, Michael |
03-06-2007, 12:19
There is a fairly comprehensive check list on http://www.vintagebirds.com. Perhaps
there is a forum member near you or the Bird that could help. There are forum members that will do an inspection for a fee. What is your location? As for the flaky Primus, Stephen Birtles http://www.capeinnovation.com can help you there. I had a flaky Primus and converted to Wabasto diesel fired hydronic heat. It's a little pricey but I am very happy with the system. Now I use LP gas for the outside grill, refer(while in transit) and cooktop. I don't get overly concerned with LP leaks because the tank is off most of the time. I haven't filled the LP tank in two years. Leroy Eckert 1990 WB-40"Smoke N Mirrors" Niceville, FL ----- Original Message ----- From: mbrund To: WanderlodgeForum@yahoogroups.com Sent: Tuesday, March 06, 2007 4:48 PM Subject: [WanderlodgeForum] Looking to purchase used 1992 WB40 I am looking at purchasing a used 1992 WB40, I was wanting to know what things to look out for on this year model. I was told by the current owner that one of the Primus heaters is a little flaky, and as I understand by reading at various places that this should be of concern since there is only one place to get parts. He said he did not know what the issue was as it works sometimes, and does not others, but the other unit works all the time. New fridge. Cooktop and washer/dryer have not been used during the current owners 10 year term. What other items should I look for while inspecting a coach of this year model that might be a big ticket items? Coach has ~140K miles ~3000 hours on 8V92, 4 years on tires (kept inside), 4 years on GEL cells (low batt charger plugged in while in storage). Thanks, Michael [Non-text portions of this message have been removed] |
03-06-2007, 15:22
The bird is located in Pine Bluff, Arkansas
--- In WanderlodgeForum@yahoogroups.com, "Leroy Eckert" > > There is a fairly comprehensive check list on http://www.vintagebirds.com. Perhaps there is a forum member near you or the Bird that could help. There are forum members that will do an inspection for a fee. What is your location? > As for the flaky Primus, Stephen Birtles http://www.capeinnovation.com can help you there. I had a flaky Primus and converted to Wabasto diesel fired hydronic heat. It's a little pricey but I am very happy with the system. > Now I use LP gas for the outside grill, refer(while in transit) and cooktop. I don't get overly concerned with LP leaks because the tank is off most of the time. I haven't filled the LP tank in two years. > > Leroy Eckert > 1990 WB-40"Smoke N Mirrors" > Niceville, FL > > > > > > ----- Original Message ----- > From: mbrund > To: WanderlodgeForum@yahoogroups.com > Sent: Tuesday, March 06, 2007 4:48 PM > Subject: [WanderlodgeForum] Looking to purchase used 1992 WB40 > > > > I am looking at purchasing a used 1992 WB40, I was wanting to know > what things to look out for on this year model. I was told by the > current owner that one of the Primus heaters is a little flaky, and as > I understand by reading at various places that this should be of > concern since there is only one place to get parts. He said he did > not know what the issue was as it works sometimes, and does not > others, but the other unit works all the time. New fridge. Cooktop > and washer/dryer have not been used during the current owners 10 year > term. > > What other items should I look for while inspecting a coach of this > year model that might be a big ticket items? > > Coach has ~140K miles ~3000 hours on 8V92, 4 years on tires (kept > inside), 4 years on GEL cells (low batt charger plugged in while in > storage). > > Thanks, > Michael > > > > > > [Non-text portions of this message have been removed] > |
03-06-2007, 15:30
Leroy,
Thanks for the pointer to the list at vintagebirds, I had forgotten about that one. I picked up a PDI list from ChanginGears that I am modifing to add the extra stuff the bird has I am aware of. The bird I am looking at is this one: http://www.birdconnection.com/showroom/d...hp?v_id=72 It is located in Pine Bluff, Arkansas. So if there is anyone in that area that could assist I would greatly appreciate it. I am a current Fleetwood owner, and happy to say not for much longer As for the Primus, I doubt we would ever need so much heat in the unit that we would have to run two Primus heaters (live in Austin Texas), but if I ever did I guess I would need to decide do I want to go hydronic or stay with propane fired Primus and get it fixed. I like the newer AquaHot type systems since they do more than just heat the interior (domestic hot water, pre-heat engine, etc.), and may decide to go that route in the future, so would be interested in what the cost is to convert over to such a system. --- In WanderlodgeForum@yahoogroups.com, "Leroy Eckert" > > There is a fairly comprehensive check list on http://www.vintagebirds.com. Perhaps there is a forum member near you or the Bird that could help. There are forum members that will do an inspection for a fee. What is your location? > As for the flaky Primus, Stephen Birtles http://www.capeinnovation.com can help you there. I had a flaky Primus and converted to Wabasto diesel fired hydronic heat. It's a little pricey but I am very happy with the system. > Now I use LP gas for the outside grill, refer(while in transit) and cooktop. I don't get overly concerned with LP leaks because the tank is off most of the time. I haven't filled the LP tank in two years. > > Leroy Eckert > 1990 WB-40"Smoke N Mirrors" > Niceville, FL > > > > > > ----- Original Message ----- > From: mbrund > To: WanderlodgeForum@yahoogroups.com > Sent: Tuesday, March 06, 2007 4:48 PM > Subject: [WanderlodgeForum] Looking to purchase used 1992 WB40 > > > > I am looking at purchasing a used 1992 WB40, I was wanting to know > what things to look out for on this year model. I was told by the > current owner that one of the Primus heaters is a little flaky, and as > I understand by reading at various places that this should be of > concern since there is only one place to get parts. He said he did > not know what the issue was as it works sometimes, and does not > others, but the other unit works all the time. New fridge. Cooktop > and washer/dryer have not been used during the current owners 10 year > term. > > What other items should I look for while inspecting a coach of this > year model that might be a big ticket items? > > Coach has ~140K miles ~3000 hours on 8V92, 4 years on tires (kept > inside), 4 years on GEL cells (low batt charger plugged in while in > storage). > > Thanks, > Michael > > > > > > [Non-text portions of this message have been removed] > |
03-06-2007, 23:46
I am throwing in the towel on my Flakey Primus next week, replacing with
Webasto Scholastic Heater, see http://www.webasto.us/am/en/am_busses_heaters_2780.html . The install will be done by Coachcraft in Columbus GA. Talk to Kenny Rodgers if you want an idea of cost etc for this conversion, as Leroy says not cheap. Kenny told me that if you use this unit it will fit on the existing tray the Primus is on and the bulk oil fill will not have to be removed. If you replace with a larger AQUA HOT in the same position the bulk oil fill needs to go. If you want to keep the Primus units Stephen Birtles is the person to talk to! NO FINANCIAL ITEREST here. Steve Quandt FREEZING in Iron Mountain, MI But heading south next week!! -8 degrees!! _____ From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of mbrund Sent: Tuesday, March 06, 2007 4:48 PM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Looking to purchase used 1992 WB40 I am looking at purchasing a used 1992 WB40, I was wanting to know what things to look out for on this year model. I was told by the current owner that one of the Primus heaters is a little flaky, and as I understand by reading at various places that this should be of concern since there is only one place to get parts. He said he did not know what the issue was as it works sometimes, and does not others, but the other unit works all the time. New fridge. Cooktop and washer/dryer have not been used during the current owners 10 year term. What other items should I look for while inspecting a coach of this year model that might be a big ticket items? Coach has ~140K miles ~3000 hours on 8V92, 4 years on tires (kept inside), 4 years on GEL cells (low batt charger plugged in while in storage). Thanks, Michael [Non-text portions of this message have been removed] |
03-06-2007, 23:52
Webasto has a unit and instructions to replace the Primus boilers,
which then provides the same functions as the Primus, heating the interior, bays, hot water, engine pre-heat option, etc. Two years ago the Webasto unit was $2600 if I remember correctly. Installaton extra. Roger Webb 91WLWB Cedar Rapids, IA |
03-07-2007, 02:31
Steve: You are doing the correct thing. Coachcraft does a fine job. The
Wabasto Scholastic went into the area where the two Primus boilers were. I now have a single loop, single thermostat hydronic system the works very well. There is a side benefit. The gas feed line to the Primus can be used to feed an outside grill and bean pot. What ever the Primus did the Wabasto does far better. Leroy Eckert 1990 WB-40"Smoke N Mirrors" Niceville, FL ----- Original Message ----- From: smquandt To: WanderlodgeForum@yahoogroups.com Sent: Wednesday, March 07, 2007 5:46 AM Subject: RE: [WanderlodgeForum] Looking to purchase used 1992 WB40 I am throwing in the towel on my Flakey Primus next week, replacing with Webasto Scholastic Heater, see http://www.webasto.us/am/en/am_busses_heaters_2780.html . The install will be done by Coachcraft in Columbus GA. Talk to Kenny Rodgers if you want an idea of cost etc for this conversion, as Leroy says not cheap. Kenny told me that if you use this unit it will fit on the existing tray the Primus is on and the bulk oil fill will not have to be removed. If you replace with a larger AQUA HOT in the same position the bulk oil fill needs to go. If you want to keep the Primus units Stephen Birtles is the person to talk to! NO FINANCIAL ITEREST here. Steve Quandt FREEZING in Iron Mountain, MI But heading south next week!! -8 degrees!! _____ From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of mbrund Sent: Tuesday, March 06, 2007 4:48 PM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Looking to purchase used 1992 WB40 I am looking at purchasing a used 1992 WB40, I was wanting to know what things to look out for on this year model. I was told by the current owner that one of the Primus heaters is a little flaky, and as I understand by reading at various places that this should be of concern since there is only one place to get parts. He said he did not know what the issue was as it works sometimes, and does not others, but the other unit works all the time. New fridge. Cooktop and washer/dryer have not been used during the current owners 10 year term. What other items should I look for while inspecting a coach of this year model that might be a big ticket items? Coach has ~140K miles ~3000 hours on 8V92, 4 years on tires (kept inside), 4 years on GEL cells (low batt charger plugged in while in storage). Thanks, Michael [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] |
03-07-2007, 06:40
It's a good looking coach ... had it been available when I was
looking it would have been high on my list of units to consider. With the new paint job, you'll find that hardly anybody (outside the BB community) will believe that it's a 15 year old RV. (My coach is quite similar, though a couple of years newer and with the Series 60 engine.) The Primus heat is a concern ... but parts are available, even if single-sourced. A steel bodied RV does need a bit more heat (when it's cold) than, perhaps, a plastic model. (One of the trade-offs, but I still much prefer the strength of steel.) The main concern is vehicle mechanical condition and the wear and tear on the various systems. If the engine hasn't been mistreated, it is certainly good for a lot of miles beyond the 144,000 lsited. The miles divided by the engine hours equals an average movement speed of 50 mph -- that suggest that the coach was a fair number of freeway miles. I would plan a fairly complete servicing including oil change and brake inspection early on. One "watch for" is the condition of the radiator. DD engines are not forgiving of overheating. It is common for the radiator to become partially clogged with oily-dirt. The tendency of DD engines to spray a bit of oil through the breather tubes makes the problem worse as the fan often sucks the oil mist back through the radiator mixing with dust that kicks up. This should be something that you carefully monitor and try to clean out the radiator if it shows any blockage. (It was very difficult to examine on my coach as it sits behind the air-charge radiator (that cools air from the turbo charger), but perhaps the DD 8v92 configuration allows easier viewing of the radiator.) Simply pulling the radiator is a $2000+ job. The complete replacement of the core may run as much as $3000+. (I also had work done on my chassis AC -- so my tab came to about $4000 for core replacement and the other services performed by a professional heavy duty radiator service. Costs for work done outside California may be more reasonable.) Other expenses you might plan for would include new tires in a year or two. (8 times $350~450) Also, the gel batteries have a life expectancy of up to about 7 years... but if they've been mistreated, they may also be next to go. I'm shopping for batteries now ... looks like about $2100 for six size 4D AGM house batteries. I haven't priced engine batteries (mine seem OK), but my coach has 3 AGM class 37s -- about $160 each . Of some concern would be the refrigerator. While home refrigerators used to run for 25-30 years, since the 80s, they've been manufactured to only last about 10-12 years or so. It's hard to guess how long an RV refrigerator might last -- it depends on brand, type (RV with gas & electric option or regular home-type), and use. In particular, if gas operated, the burner and venting is subject to corrosion. Not as difficult, but still a modest headache would be the microwave/ convection oven ... at 15 years, it, too, may be near it's expected life span -- or not -- again depending on use, etc. Pete Masterson aeonix1@... '95 Blue Bird Wanderlodge WBDA 42' El Sobrante, CA On Mar 6, 2007, at 7:30 PM, mbrund wrote: > Leroy, > > Thanks for the pointer to the list at vintagebirds, I had forgotten > about that one. I picked up a PDI list from ChanginGears that I am > modifing to add the extra stuff the bird has I am aware of. > > The bird I am looking at is this one: > http://www.birdconnection.com/showroom/d...hp?v_id=72 > It is located in Pine Bluff, Arkansas. So if there is anyone in > that area that could assist I would greatly appreciate it. I am a > current Fleetwood owner, and happy to say not for much longer > > As for the Primus, I doubt we would ever need so much heat in the > unit that we would have to run two Primus heaters (live in Austin > Texas), but if I ever did I guess I would need to decide do I want > to go hydronic or stay with propane fired Primus and get it fixed. > I like the newer AquaHot type systems since they do more than just > heat the interior (domestic hot water, pre-heat engine, etc.), and > may decide to go that route in the future, so would be interested in > what the cost is to convert over to such a system. > > > --- In WanderlodgeForum@yahoogroups.com, "Leroy Eckert" > >> >> There is a fairly comprehensive check list on > http://www.vintagebirds.com. Perhaps there is a forum member near you or > the Bird that could help. There are forum members that will do an > inspection for a fee. What is your location? >> As for the flaky Primus, Stephen Birtles http://www.capeinnovation.com > can help you there. I had a flaky Primus and converted to Wabasto > diesel fired hydronic heat. It's a little pricey but I am very > happy with the system. >> Now I use LP gas for the outside grill, refer(while in transit) > and cooktop. I don't get overly concerned with LP leaks because the > tank is off most of the time. I haven't filled the LP tank in two > years. >> >> Leroy Eckert >> 1990 WB-40"Smoke N Mirrors" >> Niceville, FL >> >> >> >> >> >> ----- Original Message ----- >> From: mbrund >> To: WanderlodgeForum@yahoogroups.com >> Sent: Tuesday, March 06, 2007 4:48 PM >> Subject: [WanderlodgeForum] Looking to purchase used 1992 WB40 >> >> >> >> I am looking at purchasing a used 1992 WB40, I was wanting to > know >> what things to look out for on this year model. I was told by the >> current owner that one of the Primus heaters is a little flaky, > and as >> I understand by reading at various places that this should be of >> concern since there is only one place to get parts. He said he > did >> not know what the issue was as it works sometimes, and does not >> others, but the other unit works all the time. New fridge. > Cooktop >> and washer/dryer have not been used during the current owners 10 > year >> term. >> >> What other items should I look for while inspecting a coach of > this >> year model that might be a big ticket items? >> >> Coach has ~140K miles ~3000 hours on 8V92, 4 years on tires (kept >> inside), 4 years on GEL cells (low batt charger plugged in while > in >> storage). >> >> Thanks, >> Michael >> >> [Non-text portions of this message have been removed] |
03-07-2007, 08:34
Pete,
Thanks for the feedback. The batteries and tires where one of the items on my list of concern knowing that they will require replacing at some point in the near future and than tab would be around $5K (was told it has GEL know, but plan to go AGM if I purchased and had to replace them). The tires are 5 years old, but the coach has spent its life inside when not being used. Depending on if they have ever been curbed or run low on air, they can be extended to 9 years if not dry rotted or thread wear, I will have to look at them close. The fridge was replaced in the last 12 months or so, so should be no concern there. The cooktop and washer per the current owner have not been used since they owned it. So they need to be checked out well, especially the washer to make sure the seals are good. I would prefer a newer model, say '94 or so, but I have a budget and most are asking more than I want to spend at this time. Seems many people are trying to get retail prices for private sales, which means they will be sitting on their units for sometime to come with the turn down in the RV market as it is. The paint is not new, the coach was sent from BB in primer state when the coach was new to be custom painted. So the paint shows it age (14 years: cracked around the wheel wells, some rivets, door panels, some rock dings, etc.). --- In WanderlodgeForum@yahoogroups.com, Pete Masterson wrote: > > It's a good looking coach ... had it been available when I was > looking it would have been high on my list of units to consider. With > the new paint job, you'll find that hardly anybody (outside the BB > community) will believe that it's a 15 year old RV. (My coach is > quite similar, though a couple of years newer and with the Series 60 > engine.) > > The Primus heat is a concern ... but parts are available, even if > single-sourced. A steel bodied RV does need a bit more heat (when > it's cold) than, perhaps, a plastic model. (One of the trade-offs, > but I still much prefer the strength of steel.) > > The main concern is vehicle mechanical condition and the wear and > tear on the various systems. If the engine hasn't been mistreated, it > is certainly good for a lot of miles beyond the 144,000 lsited. The > miles divided by the engine hours equals an average movement speed of > 50 mph -- that suggest that the coach was a fair number of freeway > miles. I would plan a fairly complete servicing including oil change > and brake inspection early on. > > One "watch for" is the condition of the radiator. DD engines are not > forgiving of overheating. It is common for the radiator to become > partially clogged with oily-dirt. The tendency of DD engines to spray > a bit of oil through the breather tubes makes the problem worse as > the fan often sucks the oil mist back through the radiator mixing > with dust that kicks up. This should be something that you carefully > monitor and try to clean out the radiator if it shows any blockage. > (It was very difficult to examine on my coach as it sits behind the > air-charge radiator (that cools air from the turbo charger), but > perhaps the DD 8v92 configuration allows easier viewing of the > radiator.) Simply pulling the radiator is a $2000+ job. The complete > replacement of the core may run as much as $3000+. (I also had work > done on my chassis AC -- so my tab came to about $4000 for core > replacement and the other services performed by a professional heavy > duty radiator service. Costs for work done outside California may be > more reasonable.) > > Other expenses you might plan for would include new tires in a year > or two. (8 times $350~450) Also, the gel batteries have a life > expectancy of up to about 7 years... but if they've been mistreated, > they may also be next to go. I'm shopping for batteries now ... looks > like about $2100 for six size 4D AGM house batteries. I haven't > priced engine batteries (mine seem OK), but my coach has 3 AGM class > 37s -- about $160 each . > > Of some concern would be the refrigerator. While home refrigerators > used to run for 25-30 years, since the 80s, they've been manufactured > to only last about 10-12 years or so. It's hard to guess how long an > RV refrigerator might last -- it depends on brand, type (RV with gas > & electric option or regular home-type), and use. In particular, if > gas operated, the burner and venting is subject to corrosion. > > Not as difficult, but still a modest headache would be the microwave/ > convection oven ... at 15 years, it, too, may be near it's expected > life span -- or not -- again depending on use, etc. > > Pete Masterson > aeonix1@... > '95 Blue Bird Wanderlodge WBDA 42' > El Sobrante, CA > > > > > On Mar 6, 2007, at 7:30 PM, mbrund wrote: > > > Leroy, > > > > Thanks for the pointer to the list at vintagebirds, I had forgotten > > about that one. I picked up a PDI list from ChanginGears that I am > > modifing to add the extra stuff the bird has I am aware of. > > > > The bird I am looking at is this one: > > http://www.birdconnection.com/showroom/d...hp?v_id=72 > > It is located in Pine Bluff, Arkansas. So if there is anyone in > > that area that could assist I would greatly appreciate it. I am a > > current Fleetwood owner, and happy to say not for much longer > > > > As for the Primus, I doubt we would ever need so much heat in the > > unit that we would have to run two Primus heaters (live in Austin > > Texas), but if I ever did I guess I would need to decide do I want > > to go hydronic or stay with propane fired Primus and get it fixed. > > I like the newer AquaHot type systems since they do more than just > > heat the interior (domestic hot water, pre-heat engine, etc.), and > > may decide to go that route in the future, so would be interested in > > what the cost is to convert over to such a system. > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Leroy Eckert" > > > >> > >> There is a fairly comprehensive check list on > > http://www.vintagebirds.com. Perhaps there is a forum member near you or > > the Bird that could help. There are forum members that will do an > > inspection for a fee. What is your location? > >> As for the flaky Primus, Stephen Birtles http://www.capeinnovation.com > > can help you there. I had a flaky Primus and converted to Wabasto > > diesel fired hydronic heat. It's a little pricey but I am very > > happy with the system. > >> Now I use LP gas for the outside grill, refer(while in transit) > > and cooktop. I don't get overly concerned with LP leaks because the > > tank is off most of the time. I haven't filled the LP tank in two > > years. > >> > >> Leroy Eckert > >> 1990 WB-40"Smoke N Mirrors" > >> Niceville, FL > >> > >> > >> > >> > >> > >> ----- Original Message ----- > >> From: mbrund > >> To: WanderlodgeForum@yahoogroups.com > >> Sent: Tuesday, March 06, 2007 4:48 PM > >> Subject: [WanderlodgeForum] Looking to purchase used 1992 WB40 > >> > >> > >> > >> I am looking at purchasing a used 1992 WB40, I was wanting to > > know > >> what things to look out for on this year model. I was told by the > >> current owner that one of the Primus heaters is a little flaky, > > and as > >> I understand by reading at various places that this should be of > >> concern since there is only one place to get parts. He said he > > did > >> not know what the issue was as it works sometimes, and does not > >> others, but the other unit works all the time. New fridge. > > Cooktop > >> and washer/dryer have not been used during the current owners 10 > > year > >> term. > >> > >> What other items should I look for while inspecting a coach of > > this > >> year model that might be a big ticket items? > >> > >> Coach has ~140K miles ~3000 hours on 8V92, 4 years on tires (kept > >> inside), 4 years on GEL cells (low batt charger plugged in while > > in > >> storage). > >> > >> Thanks, > >> Michael > >> > >> > > > > [Non-text portions of this message have been removed] > |
03-07-2007, 11:06
Hey my neck of the woods
Im on tdy in fla right now but will be back over the weekend I will ck this out for you if need be WOODY 2 bird club for sale 81 fc rb 90sp keeper today --- In WanderlodgeForum@yahoogroups.com, "mbrund" <mbrund@...> wrote: > > Leroy, > > Thanks for the pointer to the list at vintagebirds, I had forgotten > about that one. I picked up a PDI list from ChanginGears that I am > modifing to add the extra stuff the bird has I am aware of. > > The bird I am looking at is this one: > http://www.birdconnection.com/showroom/d...hp?v_id=72 > It is located in Pine Bluff, Arkansas. So if there is anyone in > that area that could assist I would greatly appreciate it. I am a > current Fleetwood owner, and happy to say not for much longer > > As for the Primus, I doubt we would ever need so much heat in the > unit that we would have to run two Primus heaters (live in Austin > Texas), but if I ever did I guess I would need to decide do I want > to go hydronic or stay with propane fired Primus and get it fixed. > I like the newer AquaHot type systems since they do more than just > heat the interior (domestic hot water, pre-heat engine, etc.), and > may decide to go that route in the future, so would be interested in > what the cost is to convert over to such a system. > > > --- In WanderlodgeForum@yahoogroups.com, "Leroy Eckert" > > > > > There is a fairly comprehensive check list on > http://www.vintagebirds.com. Perhaps there is a forum member near you or > the Bird that could help. There are forum members that will do an > inspection for a fee. What is your location? > > As for the flaky Primus, Stephen Birtles http://www.capeinnovation.com > can help you there. I had a flaky Primus and converted to Wabasto > diesel fired hydronic heat. It's a little pricey but I am very > happy with the system. > > Now I use LP gas for the outside grill, refer(while in transit) > and cooktop. I don't get overly concerned with LP leaks because the > tank is off most of the time. I haven't filled the LP tank in two > years. > > > > Leroy Eckert > > 1990 WB-40"Smoke N Mirrors" > > Niceville, FL > > > > > > > > > > > > ----- Original Message ----- > > From: mbrund > > To: WanderlodgeForum@yahoogroups.com > > Sent: Tuesday, March 06, 2007 4:48 PM > > Subject: [WanderlodgeForum] Looking to purchase used 1992 WB40 > > > > > > > > I am looking at purchasing a used 1992 WB40, I was wanting to > know > > what things to look out for on this year model. I was told by the > > current owner that one of the Primus heaters is a little flaky, > and as > > I understand by reading at various places that this should be of > > concern since there is only one place to get parts. He said he > did > > not know what the issue was as it works sometimes, and does not > > others, but the other unit works all the time. New fridge. > Cooktop > > and washer/dryer have not been used during the current owners 10 > year > > term. > > > > What other items should I look for while inspecting a coach of > this > > year model that might be a big ticket items? > > > > Coach has ~140K miles ~3000 hours on 8V92, 4 years on tires (kept > > inside), 4 years on GEL cells (low batt charger plugged in while > in > > storage). > > > > Thanks, > > Michael > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > |
