LX DIAGNOSTIC PORT
05-29-2007, 00:04
LX DIAGNOSTIC PORT
Is there a Cummins diesel diagnostic connection in the front of the
1998 LX 40 and if so what data can be read . Is there a Silver Leaf constant readout unit available and or similar device? Donald Brown, Palmetto FL looking at a new to me LX |
05-29-2007, 00:50
LX DIAGNOSTIC PORT
I have a Silverleaf VMSpc plugged into my DDL. It gives me most information on
the engine, an 8v92. I would think VMSpc is available for the Cummins and the DDL must be somewhere in the area of the Pilots left knee. That is where mine is located. Mine is a twelve pin plug. Yours may be 9 pin. You could go on line at http://www.silverleafelectronics.com and contact them for more specific information. I imagine you will get more information than I do including transmission info because your coach is a later model. I went into my engine data base and there are several Cummins engines listed. For info, I get most data off of my DDEC II but not oil temperature. Things like battery voltage, engine load, water temperature, low fluid level, oil pressure, fuel temperature, rpm, mph, throttle position, boost, gallons per hour, torque, cruise set speed, HP, engine hours etc. It will also read diagnostic codes if they occur. Leroy Eckert 1990WB-40"Smoke N Mirrors" Niceville, FL ----- Original Message ----- From: rvdependent To: WanderlodgeForum@yahoogroups.com Sent: Tuesday, May 29, 2007 7:04 AM Subject: [WanderlodgeForum] LX DIAGNOSTIC PORT Is there a Cummins diesel diagnostic connection in the front of the 1998 LX 40 and if so what data can be read . Is there a Silver Leaf constant readout unit available and or similar device? Donald Brown, Palmetto FL looking at a new to me LX [Non-text portions of this message have been removed] |
