Removing old vinyl trim
02-18-2007, 11:35
Gardner, I doubt that the vinyl trim will come off without serious damage to
the paint. The trim is available at most RV stores and at West Marine.
Probably other marine stores too.
Steve Anderson
79 FC 35
Poulsbo Wa
02-18-2007, 13:10
The vinyl trim on my '78 is way past end of life. Is there a
preferred method for removing it? I have a heat gun if that will work,
but I don't want to damage the paint. I am looking into re-painting,
but I don't have that on the imediate list, so I want to keep things
looking as good as I can till then. The vinyl trim on the roof looks
like dried cracked desert mud. The trim on the sides looks better
since I used shoe polish to brighten it up.
Another item I am looking for is the rubber insert for the trim
arroud the headlight and grille area. The old stuff id dry and has
shrunk a bit.
Gardner
78FC33
02-18-2007, 14:25
Gardner You can get the rubber trim from most RV supplers
Don 89SP 36' Butler, PA In Zefphyrhills, FL
shrunk a bit.
Gardner
78FC33
________________________________________________________________________
Check out the new AOL. Most comprehensive set of free safety and security
tools, free access to millions of high-quality videos from across the web, free
AOL Mail and more.
02-18-2007, 14:28
Gardner,
The stickers, well not too sure.. lots of scraping, and then repaint any
damaged areas..??
The front trim is easy. I replaced mine- got it at Toms RV in Brandon, Fl.
$5.00 for full roll(I had quite a bit left over) Also saw it at Camping
world, different colors. White, Brown, Black, ect..
Stephen
81FC-33SB
Plant City, FL
_____
[mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Gardner Yeaw
Sent: Sunday, February 18, 2007 8:11 PM
Subject: [WanderlodgeForum] Removing old vinyl trim
shrunk a bit.
Gardner
78FC33
02-18-2007, 15:18
Gardner
On my coach Icovered the wood trim with a vinyl from a sign shop
looked good from a distance and covered up the faded portions till I
removed it all and repainted the coach
Total cost 100.00 installation included to cover it all
Worked for 2 years until remaoval and covered some pretty crappy stuff
Stephen 77fc35 no more woodgrain
--- In WanderlodgeForum@yahoogroups.com, "Gardner Yeaw"
> shrunk a bit.
> Gardner
> 78FC33
02-18-2007, 16:12
You can get a vinyl eraser from almost any sign shop or from body
shop. It is a soft rubber disk that you use with an electric drill.
It will remove vinyl without damaging paint. Hope this helps!
02-19-2007, 11:45
Thanks again for the responses. It looks like the 3M vinyl trim
remover is the weapon of choice. I will give it a try.
Gardner
78FC33
work,
painting,
things
looks
> shrunk a bit.
> Gardner
> 78FC33
