Zip Dee Window Awnings
02-22-2007, 05:48
I have my work cut out for me this weekend. (Thanks Ralph!) But in
the mean time I need to get some info on Zip Dee awnings. One of the small window awnings is broken. As in, it won't roll up on it's own. There are no levers or anything so I assume it is a preset function. Half of the rod that goes through the middle of the tube came out the right side. Is it supposed to be one piece? And how do I rewind/re- tension it? Thanks |
02-22-2007, 05:58
Try the Zip Dee website http://www.zipdeeinc.com/
Then click on Maintenance. The is a pretty hefty loaded spring in the tube. They are very helpful on the telephone. Bill 88 FC --- In WanderlodgeForum@yahoogroups.com, "Keith Strehle" > > I have my work cut out for me this weekend. (Thanks Ralph!) But in > the mean time I need to get some info on Zip Dee awnings. One of the > small window awnings is broken. As in, it won't roll up on it's own. > There are no levers or anything so I assume it is a preset function. > Half of the rod that goes through the middle of the tube came out the > right side. Is it supposed to be one piece? And how do I rewind/re- > tension it? > > Thanks > |
02-22-2007, 06:19
Yeah, there is a lot of stored energy in them rascals. Tread real soft when
working with them, scary as a overhead garage door spring. I damn near broke my arm once being careless with my awning. MH ----- Original Message ----- From: pattypape To: WanderlodgeForum@yahoogroups.com Sent: Thursday, February 22, 2007 11:58 AM Subject: [WanderlodgeForum] Re: Zip Dee Window Awnings Try the Zip Dee website http://www.zipdeeinc.com/ Then click on Maintenance. The is a pretty hefty loaded spring in the tube. They are very helpful on the telephone. Bill 88 FC --- In WanderlodgeForum@yahoogroups.com, "Keith Strehle" > > I have my work cut out for me this weekend. (Thanks Ralph!) But in > the mean time I need to get some info on Zip Dee awnings. One of the > small window awnings is broken. As in, it won't roll up on it's own. > There are no levers or anything so I assume it is a preset function. > Half of the rod that goes through the middle of the tube came out the > right side. Is it supposed to be one piece? And how do I rewind/re- > tension it? > > Thanks > [Non-text portions of this message have been removed] |
02-22-2007, 07:09
Thanks for the advice. Provided the spring is not broken, is there a
process for re-winding them? --- In WanderlodgeForum@yahoogroups.com, "Mike Hohnstein" <MHOHNSTEIN@...> wrote: > > Yeah, there is a lot of stored energy in them rascals. Tread real soft when working with them, scary as a overhead garage door spring. I damn near broke my arm once being careless with my awning. > MH > ----- Original Message ----- > From: pattypape > To: WanderlodgeForum@yahoogroups.com > Sent: Thursday, February 22, 2007 11:58 AM > Subject: [WanderlodgeForum] Re: Zip Dee Window Awnings > > > Try the Zip Dee website http://www.zipdeeinc.com/ > Then click on Maintenance. > The is a pretty hefty loaded spring in the tube. > > They are very helpful on the telephone. > > Bill 88 FC > > --- In WanderlodgeForum@yahoogroups.com, "Keith Strehle" > > > > > I have my work cut out for me this weekend. (Thanks Ralph!) But > in > > the mean time I need to get some info on Zip Dee awnings. One of > the > > small window awnings is broken. As in, it won't roll up on it's > own. > > There are no levers or anything so I assume it is a preset > function. > > Half of the rod that goes through the middle of the tube came out > the > > right side. Is it supposed to be one piece? And how do I > rewind/re- > > tension it? > > > > Thanks > > > > > > > > [Non-text portions of this message have been removed] > |
02-22-2007, 07:16
Keith, the spring is broken. Not a hard job. You will need to use pop
rivets and instructions will come with new sprint. Bruce in Raleigh, NC WL 83 FC35RB WOO Webmaster |
02-22-2007, 07:25
You need to replace the guts, a spring wrapped around the rod with caps on each
end . Contact Zip Dee they will ship the parts assembled in a tube. Parts cost $50 from Zip Dee and takes about 1 hour to fix. 1) Remove awning from coach 2) Drill out 3 rivets 3) Remove the guts 4) Slide in the new piece, rod and end caps are assembled when they ship 5) Attach awning to tube with new rivets provided in kit 6) Attach awning and 1 arm to coach 7) Wind up spring and attach arm, mine took 3 turns Troy ----- Original Message ----- From: Keith Strehle To: WanderlodgeForum@yahoogroups.com Sent: Thursday, February 22, 2007 11:48 AM Subject: [WanderlodgeForum] Zip Dee Window Awnings I have my work cut out for me this weekend. (Thanks Ralph!) But in the mean time I need to get some info on Zip Dee awnings. One of the small window awnings is broken. As in, it won't roll up on it's own. There are no levers or anything so I assume it is a preset function. Half of the rod that goes through the middle of the tube came out the right side. Is it supposed to be one piece? And how do I rewind/re- tension it? Thanks [Non-text portions of this message have been removed] |
02-22-2007, 07:36
Something like 30 turns. The left arm, facing the awing is the energized
component. You turn the square solid portion of the arm, might be 33 turns, I forget. Zipdee has good customer service and I have been satisfied with them. After my sad experiencel, Zipdee sent me Ehrhardts RV, http://www.etstrailers.com they did a good job and the cost was reasonable. Mike Hohnstein Germantown, WI 83FC35 ----- Original Message ----- From: Keith Strehle To: WanderlodgeForum@yahoogroups.com Sent: Thursday, February 22, 2007 1:09 PM Subject: [WanderlodgeForum] Re: Zip Dee Window Awnings Thanks for the advice. Provided the spring is not broken, is there a process for re-winding them? --- In WanderlodgeForum@yahoogroups.com, "Mike Hohnstein" <MHOHNSTEIN@...> wrote: > > Yeah, there is a lot of stored energy in them rascals. Tread real soft when working with them, scary as a overhead garage door spring. I damn near broke my arm once being careless with my awning. > MH > ----- Original Message ----- > From: pattypape > To: WanderlodgeForum@yahoogroups.com > Sent: Thursday, February 22, 2007 11:58 AM > Subject: [WanderlodgeForum] Re: Zip Dee Window Awnings > > > Try the Zip Dee website http://www.zipdeeinc.com/ > Then click on Maintenance. > The is a pretty hefty loaded spring in the tube. > > They are very helpful on the telephone. > > Bill 88 FC > > --- In WanderlodgeForum@yahoogroups.com, "Keith Strehle" > > > > > I have my work cut out for me this weekend. (Thanks Ralph!) But > in > > the mean time I need to get some info on Zip Dee awnings. One of > the > > small window awnings is broken. As in, it won't roll up on it's > own. > > There are no levers or anything so I assume it is a preset > function. > > Half of the rod that goes through the middle of the tube came out > the > > right side. Is it supposed to be one piece? And how do I > rewind/re- > > tension it? > > > > Thanks > > > > > > > > [Non-text portions of this message have been removed] > [Non-text portions of this message have been removed] |
02-22-2007, 08:54
Thanks Bruce, I'm one of those "If I can't fix it, it ain't broke."
kind of guys... And I'm a cheapskate! But it looks like I'll have to fork out the $50 and let this one go.... Thanks for the info... --- In WanderlodgeForum@yahoogroups.com, Bruce Morris <bamnc@...> wrote: > > Keith, the spring is broken. Not a hard job. You will need to use pop > rivets and instructions will come with new sprint. > > Bruce in Raleigh, NC > WL 83 FC35RB > WOO Webmaster > |
02-22-2007, 09:43
Rule of thumb for Zip Dee awnings is: 1 turn per linear foot plus 5 turns
Safe travels, Ralph and Charolette Fullenwider 84FC35 Ralph's RV Solutions, Duncan, Oklahoma At 01:36 PM 2/22/2007 -0600, you wrote: >Something like 30 turns. The left arm, facing the awing is the energized >component. You turn the square solid portion of the arm, might be 33 >turns, I forget. Zipdee has good customer service and I have been >satisfied with them. >After my sad experiencel, Zipdee sent me Ehrhardts RV, http://www.etstrailers.com >they did a good job and the cost was reasonable. >Mike Hohnstein >Germantown, WI >83FC35 > ----- Original Message ----- > From: Keith Strehle > To: WanderlodgeForum@yahoogroups.com > Sent: Thursday, February 22, 2007 1:09 PM > Subject: [WanderlodgeForum] Re: Zip Dee Window Awnings > > > Thanks for the advice. Provided the spring is not broken, is there a > process for re-winding them? > > |
02-22-2007, 12:08
The front left awning has one of the springs either broken or disconnected.
Has anyone every had one of the mechanisms apart? How? - Chuck Wheeler - 82 FC 31 SB Fort Worth, TX _____ From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Ralph L. Fullenwider Sent: Thursday, February 22, 2007 3:44 PM To: WanderlodgeForum@yahoogroups.com Subject: Re: [WanderlodgeForum] Re: Zip Dee Window Awnings Rule of thumb for Zip Dee awnings is: 1 turn per linear foot plus 5 turns Safe travels, Ralph and Charolette Fullenwider 84FC35 Ralph's RV Solutions, Duncan, Oklahoma At 01:36 PM 2/22/2007 -0600, you wrote: >Something like 30 turns. The left arm, facing the awing is the energized >component. You turn the square solid portion of the arm, might be 33 >turns, I forget. Zipdee has good customer service and I have been >satisfied with them. >After my sad experiencel, Zipdee sent me Ehrhardts RV, http://www.etstrailers.com >they did a good job and the cost was reasonable. >Mike Hohnstein >Germantown, WI >83FC35 > ----- Original Message ----- > From: Keith Strehle > To: WanderlodgeForum@ yahoogroups.com > Sent: Thursday, February 22, 2007 1:09 PM > Subject: [WanderlodgeForum] Re: Zip Dee Window Awnings > > > Thanks for the advice. Provided the spring is not broken, is there a > process for re-winding them? > > [Non-text portions of this message have been removed] |
