Tooo much voltage!
02-25-2007, 14:26
Tooo much voltage!
About two years ago, my 82 35 FC began cooking my batteries with over
16 volts. I removed the alternator and regulator and the alternator shop bench tested both and found no problem. After reinstalling, still over 16 volts. I bought a programable Xantrex regulator and everything worked fine for two years, now nothing. I plugged the wiring to the origiinal regulator back in and the old problem is back, 16.1 volts. Any thoughts? Andy Clayton '82 35FC |
02-25-2007, 14:40
Tooo much voltage!
Does this coach have the remote regulator or alternator with internal
regulator? If remote, I'd suggest replacing it with internally regulated. It can be fixed as-is, but an open circuit between the regulator and the coach can cause the regulator to see no voltage and go to full output. - Jeff Miller in Holland, MI --- In WanderlodgeForum@yahoogroups.com, "webdarn" > > About two years ago, my 82 35 FC began cooking my batteries with over > 16 volts. I removed the alternator and regulator and the alternator > shop bench tested both and found no problem. After reinstalling, > still over 16 volts. > I bought a programable Xantrex regulator and everything worked fine > for two years, now nothing. I plugged the wiring to the origiinal > regulator back in and the old problem is back, 16.1 volts. > Any thoughts? > > Andy Clayton > '82 35FC > |
02-25-2007, 15:03
Tooo much voltage!
Andy, are you saying you didn't use your alternator
for 2 years? The regulator for an alternator is a small black pack that fits in the alternator. It's what I have heard termed as "self excited" meaning it doesn't neet a battery voltage for voltage or load control. Sounds like you Xantrex has failed you too somehow. Grounds, check you grounds too. bob janes, 87fc35, greenville, sc --- In WanderlodgeForum@yahoogroups.com, "webdarn" > > About two years ago, my 82 35 FC began cooking my batteries with over > 16 volts. I removed the alternator and regulator and the alternator > shop bench tested both and found no problem. After reinstalling, > still over 16 volts. > I bought a programable Xantrex regulator and everything worked fine > for two years, now nothing. I plugged the wiring to the origiinal > regulator back in and the old problem is back, 16.1 volts. > Any thoughts? > > Andy Clayton > '82 35FC > |
02-26-2007, 01:11
Tooo much voltage!
My alternator has an external voltage regulator that is mounted above the
batteries and has a small harness connecting it to the alternator. I unplugged the original two years ago and installed the Xantrax regulator. It worked fine for two years, now nothing. Andy Clayton '82 35FC _________________________________________________________________ Refi Now: Rates near 39yr lows! $430,000 Mortgage for $1,399/mo - Calculate new payment http://www.lowermybills.com/lre/index.js...&moid=7581 |
02-26-2007, 04:02
Tooo much voltage!
Jeff: Not sure that I agree with you on internal. I have lost 2
regulators recently and it is a royal pain in the *&%$ to get to under the bedroom floor. I think I'm going to explore external regulators that are convenient to replace. R.E. (Ron) Marabito, Dallas, TX 92WB40 --- In WanderlodgeForum@yahoogroups.com, "Jeff Miller" wrote: > > Does this coach have the remote regulator or alternator with internal > regulator? > > If remote, I'd suggest replacing it with internally regulated. It can > be fixed as-is, but an open circuit between the regulator and the > coach can cause the regulator to see no voltage and go to full output. > > - Jeff Miller > in Holland, MI > > > --- In WanderlodgeForum@yahoogroups.com, "webdarn" > > > > About two years ago, my 82 35 FC began cooking my batteries with > over > > 16 volts. I removed the alternator and regulator and the alternator > > shop bench tested both and found no problem. After reinstalling, > > still over 16 volts. > > I bought a programable Xantrex regulator and everything worked fine > > for two years, now nothing. I plugged the wiring to the origiinal > > regulator back in and the old problem is back, 16.1 volts. > > Any thoughts? > > > > Andy Clayton > > '82 35FC > > > |
02-26-2007, 06:32
Tooo much voltage!
Ron, I've had good luck with these on boat and bus..
http://www.amplepower.com/products/ns2/index.html<http://www.amplepower.com/prod\ ucts/ns2/index.html> Dick Hayden - '87 PT 38 - Lake Stevens, WA ----- Original Message ----- From: ronmarabito2002 To: WanderlodgeForum@yahoogroups.com Sent: Monday, February 26, 2007 8:02 AM Subject: [WanderlodgeForum] Re: Tooo much voltage! Jeff: Not sure that I agree with you on internal. I have lost 2 regulators recently and it is a royal pain in the *&%$ to get to under the bedroom floor. I think I'm going to explore external regulators that are convenient to replace. R.E. (Ron) Marabito, Dallas, TX 92WB40 --- In WanderlodgeForum@yahoogroups.com Miller" wrote: > > Does this coach have the remote regulator or alternator with internal > regulator? > > If remote, I'd suggest replacing it with internally regulated. It can > be fixed as-is, but an open circuit between the regulator and the > coach can cause the regulator to see no voltage and go to full output. > > - Jeff Miller > in Holland, MI > > > --- In WanderlodgeForum@yahoogroups.com "webdarn" > > > > About two years ago, my 82 35 FC began cooking my batteries with > over > > 16 volts. I removed the alternator and regulator and the alternator > > shop bench tested both and found no problem. After reinstalling, > > still over 16 volts. > > I bought a programable Xantrex regulator and everything worked fine > > for two years, now nothing. I plugged the wiring to the origiinal > > regulator back in and the old problem is back, 16.1 volts. > > Any thoughts? > > > > Andy Clayton > > '82 35FC > > > [Non-text portions of this message have been removed] |
02-26-2007, 10:14
Tooo much voltage!
Thanks Dick: Can you use the same alternators and simply remove the
built-in regulator? R.E. (Ron) Marabito, Dallas, TX 92WB40 --- In WanderlodgeForum@yahoogroups.com, "Richard Hayden" > > Ron, I've had good luck with these on boat and bus.. > > http://www.amplepower.com/products/ns2/index.html<http://www.amplepower.com/prod\ ucts/ns2/index.html> > > > Dick Hayden - '87 PT 38 - Lake Stevens, WA > > ----- Original Message ----- > From: ronmarabito2002 > To: WanderlodgeForum@yahoogroups.com > Sent: Monday, February 26, 2007 8:02 AM > Subject: [WanderlodgeForum] Re: Tooo much voltage! > > > Jeff: Not sure that I agree with you on internal. I have lost 2 > regulators recently and it is a royal pain in the *&%$ to get to under > the bedroom floor. I think I'm going to explore external regulators > that are convenient to replace. > > R.E. (Ron) Marabito, Dallas, TX 92WB40 > > --- In WanderlodgeForum@yahoogroups.com "Jeff Miller" > wrote: > > > > Does this coach have the remote regulator or alternator with internal > > regulator? > > > > If remote, I'd suggest replacing it with internally regulated. It can > > be fixed as-is, but an open circuit between the regulator and the > > coach can cause the regulator to see no voltage and go to full output. > > > > - Jeff Miller > > in Holland, MI > > > > > > --- In WanderlodgeForum@yahoogroups.com "webdarn" > > > > > > About two years ago, my 82 35 FC began cooking my batteries with > > over > > > 16 volts. I removed the alternator and regulator and the alternator > > > shop bench tested both and found no problem. After reinstalling, > > > still over 16 volts. > > > I bought a programable Xantrex regulator and everything worked fine > > > for two years, now nothing. I plugged the wiring to the origiinal > > > regulator back in and the old problem is back, 16.1 volts. > > > Any thoughts? > > > > > > Andy Clayton > > > '82 35FC > > > > > > > > > > > [Non-text portions of this message have been removed] > |
02-26-2007, 12:34
Tooo much voltage!
--- In WanderlodgeForum@yahoogroups.com, "Andy Clayton"
wrote: >My local heavy duty alternator dealer suggested to replace the old alternator and external regulator (both obsolete) with a new Leece- Neville 160 amp. Cost over the counter is $375.00 plus tax. Does this sound about par? Andy Clayton '82 35 FC > My alternator has an external voltage regulator that is mounted above the > batteries and has a small harness connecting it to the alternator. I > unplugged the original two years ago and installed the Xantrax regulator. > It worked fine for two years, now nothing. > > Andy Clayton > '82 35FC > > _________________________________________________________________ > Refi Now: Rates near 39yr lows! $430,000 Mortgage for $1,399/mo - Calculate > new payment > http://www.lowermybills.com/lre/index.js...=lmb-9632- 17727&moid=7581 > |
02-26-2007, 12:41
Tooo much voltage!
Hi all:
If the internal regulator is blowing, or whatever, what is causing this to happen. Now that you have had the same experience with the external regulator, I would certainly look deeper as to the root of the problem. Internal regulators are good quality. Bill 84 FC 35 SB "$quanderlodge" Terrace, B.C. Canada ----- Original Message ---- From: ronmarabito2002 To: WanderlodgeForum@yahoogroups.com Sent: Monday, February 26, 2007 2:14:10 PM Subject: [WanderlodgeForum] Re: Tooo much voltage! Thanks Dick: Can you use the same alternators and simply remove the built-in regulator? R.E. (Ron) Marabito, Dallas, TX 92WB40 --- In WanderlodgeForum@ yahoogroups. com, "Richard Hayden" > > Ron, I've had good luck with these on boat and bus.. > > http://www.amplepow er.com/products/ ns2/index. html<http://www.amplepow er.com/products/ ns2/index. html> > > > Dick Hayden - '87 PT 38 - Lake Stevens, WA > > ----- Original Message ----- > From: ronmarabito2002< mailto:remarabit o@...> > To: WanderlodgeForum@ yahoogroups. com > Sent: Monday, February 26, 2007 8:02 AM > Subject: [WanderlodgeForum] Re: Tooo much voltage! > > > Jeff: Not sure that I agree with you on internal. I have lost 2 > regulators recently and it is a royal pain in the *&%$ to get to under > the bedroom floor. I think I'm going to explore external regulators > that are convenient to replace. > > R.E. (Ron) Marabito, Dallas, TX 92WB40 > > --- In WanderlodgeForum@ yahoogroups. com "Jeff Miller" > wrote: > > > > Does this coach have the remote regulator or alternator with internal > > regulator? > > > > If remote, I'd suggest replacing it with internally regulated. It can > > be fixed as-is, but an open circuit between the regulator and the > > coach can cause the regulator to see no voltage and go to full output. > > > > - Jeff Miller > > in Holland, MI > > > > > > --- In WanderlodgeForum@ yahoogroups. com "webdarn" > > > > > > About two years ago, my 82 35 FC began cooking my batteries with > > over > > > 16 volts. I removed the alternator and regulator and the alternator > > > shop bench tested both and found no problem. After reinstalling, > > > still over 16 volts. > > > I bought a programable Xantrex regulator and everything worked fine > > > for two years, now nothing. I plugged the wiring to the origiinal > > > regulator back in and the old problem is back, 16.1 volts. > > > Any thoughts? > > > > > > Andy Clayton > > > '82 35FC > > > > > > > > > > > [Non-text portions of this message have been removed] > <!-- #ygrp-mlmsg {font-size:13px;font-family:arial,helvetica,clean,sans-serif;} #ygrp-mlmsg table {font-size:inherit;font:100%;} #ygrp-mlmsg select, input, textarea {font:99% arial,helvetica,clean,sans-serif;} #ygrp-mlmsg pre, code {font:115% monospace;} #ygrp-mlmsg * {line-height:1.22em;} #ygrp-text{ font-family:Georgia; } #ygrp-text p{ margin:0 0 1em 0; } #ygrp-tpmsgs{ font-family:Arial; clear:both; } #ygrp-vitnav{ padding-top:10px; font-family:Verdana; font-size:77%; margin:0; } #ygrp-vitnav a{ padding:0 1px; } #ygrp-actbar{ clear:both; margin:25px 0; white-space:nowrap; color:#666; text-align:right; } #ygrp-actbar .left{ float:left; white-space:nowrap; } .bld{font-weight:bold;} #ygrp-grft{ font-family:Verdana; font-size:77%; padding:15px 0; } #ygrp-ft{ font-family:verdana; font-size:77%; border-top:1px solid #666; padding:5px 0; } #ygrp-mlmsg #logo{ padding-bottom:10px; } #ygrp-vital{ background-color:#e0ecee; margin-bottom:20px; padding:2px 0 8px 8px; } #ygrp-vital #vithd{ font-size:77%; font-family:Verdana; font-weight:bold; color:#333; text-transform:uppercase; } #ygrp-vital ul{ padding:0; margin:2px 0; } #ygrp-vital ul li{ list-style-type:none; clear:both; border:1px solid #e0ecee; } #ygrp-vital ul li .ct{ font-weight:bold; color:#ff7900; float:right; width:2em; text-align:right; padding-right:.5em; } #ygrp-vital ul li .cat{ font-weight:bold; } #ygrp-vital a { text-decoration:none; } #ygrp-vital a:hover{ text-decoration:underline; } #ygrp-sponsor #hd{ color:#999; font-size:77%; } #ygrp-sponsor #ov{ padding:6px 13px; background-color:#e0ecee; margin-bottom:20px; } #ygrp-sponsor #ov ul{ padding:0 0 0 8px; margin:0; } #ygrp-sponsor #ov li{ list-style-type:square; padding:6px 0; font-size:77%; } #ygrp-sponsor #ov li a{ text-decoration:none; font-size:130%; } #ygrp-sponsor #nc { background-color:#eee; margin-bottom:20px; padding:0 8px; } #ygrp-sponsor .ad{ padding:8px 0; } #ygrp-sponsor .ad #hd1{ font-family:Arial; font-weight:bold; color:#628c2a; font-size:100%; line-height:122%; } #ygrp-sponsor .ad a{ text-decoration:none; } #ygrp-sponsor .ad a:hover{ text-decoration:underline; } #ygrp-sponsor .ad p{ margin:0; } o {font-size:0;} .MsoNormal { margin:0 0 0 0; } #ygrp-text tt{ font-size:120%; } blockquote{margin:0 0 0 4px;} .replbq {margin:4;} --> __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com [Non-text portions of this message have been removed] |
02-26-2007, 13:32
Tooo much voltage!
Yes sir, that is in line for a 160amp. That is what I paid.
Leroy Eckert 1990 WB-40"Smoke N Mirrors" Niceville, FL ----- Original Message ----- From: williama_clayton To: WanderlodgeForum@yahoogroups.com Sent: Monday, February 26, 2007 6:34 PM Subject: [WanderlodgeForum] Re: Tooo much voltage! --- In WanderlodgeForum@yahoogroups.com, "Andy Clayton" wrote: >My local heavy duty alternator dealer suggested to replace the old alternator and external regulator (both obsolete) with a new Leece- Neville 160 amp. Cost over the counter is $375.00 plus tax. Does this sound about par? Andy Clayton '82 35 FC > My alternator has an external voltage regulator that is mounted above the > batteries and has a small harness connecting it to the alternator. I > unplugged the original two years ago and installed the Xantrax regulator. > It worked fine for two years, now nothing. > > Andy Clayton > '82 35FC > > __________________________________________________________ > Refi Now: Rates near 39yr lows! $430,000 Mortgage for $1,399/mo - Calculate > new payment > http://www.lowermybills.com/lre/index.js...=lmb-9632- 17727&moid=7581 > [Non-text portions of this message have been removed] |
