High Idle Issue
02-26-2007, 09:49
High Idle Issue
Greetings All,
Today I started the coach and kicked on the high idle which I typically do while the coach is airing up. The engine RPM went to 1200 which is typical for high idle for my coach and everything appeared to be okay. I got up from the driver's seat in route to the kitchen area and then I hear the engine RPM drop off and go back to high idle a couple of times in rapid succession and then the high idle stopped working. I know that the coach must be in neutral and the parking brake set for the high idle to function base case. After the air pressure had built up, I stopped the engine and released and reset the parking brake. When I restarted the engine the high idle would still not function. If anyone has experience on a good place to start troubleshooting, I would appreciate your input. David Hanvy 89 WB PT40 Crosby, TX |
