ultra low sulfur diesel
02-26-2007, 11:16
I'm confused. Do I need an additive in my 6v92?
Ernie-83PT40 in snowy Montana
02-26-2007, 13:55
I dump a quart or two of cheap ATF in the tank when refueling, you can't add too
much.
MH
Sent: Monday, February 26, 2007 5:16 PM
Subject: [WanderlodgeForum] ultra low sulfur diesel
02-27-2007, 01:15
Thanks, Mike- good alternative to the government taking "care" of us.
83PT40
Livingston,Montana
Sent: Monday, February 26, 2007 6:55 PM
Subject: Re: [WanderlodgeForum] ultra low sulfur diesel
too much.
MH
02-27-2007, 18:54
Mike, Hope you don,t think that I'm stepping on your toes here, as you have
helped me out recently, but I must pass on to Ernie what I have learned from my
past. Ernie, I don't know what Cat recommends as a additive for its engines, as
I have noted a lot of FC's have these. I see that you have a 6V92. I do know
this, Detroit Diesel does not recommend any additive to fuel for its 2 stroke
engines. There will be a lighter mix of no.1 and no.2 fuel where you are at now,
to deter gelling.The colder the climate the more they add. In Alaska, its much
thinner than in Tx. or N.C. for instance. They also do not recommend muti-wgt
oils for 2 strokes. I have a 8V71 and use straight 40 wgt here in N.C. As you
are now in a colder climate, you should use straight 30 wgt., which is what we
used in all DD's while I was stationed in Mass. You can google the DD site, and
wade thru all the info., to learn more about these fine old engines. Stay Warm.
George Burke 1977 FC31 Charlotte
Sent: Tuesday, February 27, 2007 8:15 AM
83PT40
Livingston,Montana
too much.
MH
02-28-2007, 01:06
Thanks, George
83PT40
Livingston,Montana-grew up in mass.
Sent: Tuesday, February 27, 2007 11:54 PM
83PT40
Livingston,Montana
too much.
MH
