84 FC35SB, yikes!!!
02-27-2007, 07:16
84 FC35SB, yikes!!!
This bus is in surprisingly good shape, but is fraught with little
problems from being stored outside. I actually found acorns stored in the sewer hose!!!!! The next item on the list is the dump valves. Now the questions: They are the twist lock type and appear to be original equipment. The look just like the Dupree valves? Are there knockoffs out there? Are the valve bodies glued in? If they are Dupree valves, should I rebuild or replace the gate assembly? Thanks, Keith And oh yeah, I decided to name the bus, "The Dreamer," or in Spanish, "El Soñador" I'll explain later. Or if you've seen the movie "The Astronaut Farmer," you'll see the insanity link! Thanks |
