84 FC35SB, yikes!!!
02-27-2007, 07:16
84 FC35SB, yikes!!!
This bus is in surprisingly good shape, but is fraught with little
problems from being stored outside. I actually found acorns stored in
the sewer hose!!!!!
The next item on the list is the dump valves. Now the questions: They
are the twist lock type and appear to be original equipment. The look
just like the Dupree valves? Are there knockoffs out there? Are the
valve bodies glued in? If they are Dupree valves, should I rebuild or
replace the gate assembly?
Thanks, Keith
And oh yeah, I decided to name the bus, "The Dreamer," or in
Spanish, "El Soñador"
I'll explain later. Or if you've seen the movie "The Astronaut
Farmer," you'll see the insanity link!
Thanks
