Dump Valve Rebuild?
02-27-2007, 09:16
Dump Valve Rebuild?
The next item on the list is the dump valves. They are the twist lock
type and appear to be original equipment. The look just like the Dupree valves? Are there knockoffs out there? Are the valve bodies glued in? If they are Dupree valves, should I rebuild or replace the gate assembly? Thanks, Keith |
02-27-2007, 09:34
Dump Valve Rebuild?
Keith, you should contact Jeff Miller at Dupree Products
(616.355.9811). He owns Dupree now & has the valves in stock as well as all the rebuild parts. Also,. you can upgrade to air valves if that interests you? The bodies are glued into the tank adapter. If you get lucky, the adapter that screws into the tank will turn out easily. If not, you have the cut the fitting out of the tank & glue a new one in. Terry Neal Bozeman, MT 82PT40 6V92TA 74FC34 6V53T Keith Strehle wrote: > The next item on the list is the dump valves. They are the twist lock > type and appear to be original equipment. The look just like the Dupree > valves? Are there knockoffs out there? Are the valve bodies glued in? > If they are Dupree valves, should I rebuild or replace the gate > assembly? > > Thanks, Keith > > [Non-text portions of this message have been removed] |
02-27-2007, 09:48
Dump Valve Rebuild?
Will the adapter turn independent of the valve and piping? Like a
pipe union fitting? --- In WanderlodgeForum@yahoogroups.com, Terry Neal > > Keith, you should contact Jeff Miller at Dupree Products > (616.355.9811). He owns Dupree now & has the valves in stock as well as > all the rebuild parts. Also,. you can upgrade to air valves if that > interests you? The bodies are glued into the tank adapter. If you get > lucky, the adapter that screws into the tank will turn out easily. If > not, you have the cut the fitting out of the tank & glue a new one in. > > Terry Neal > Bozeman, MT > 82PT40 6V92TA > 74FC34 6V53T > > > Keith Strehle wrote: > > > The next item on the list is the dump valves. They are the twist lock > > type and appear to be original equipment. The look just like the Dupree > > valves? Are there knockoffs out there? Are the valve bodies glued in? > > If they are Dupree valves, should I rebuild or replace the gate > > assembly? > > > > Thanks, Keith > > > > > > > > [Non-text portions of this message have been removed] > |
02-27-2007, 10:33
Dump Valve Rebuild?
Only after you cut the output pipe, downstream from the valve. Your
valve should be glued into the tank adapter. Mine was. Jeff covered how to get it out with a cutting bit on a Dremel tool. Terry Neal Bozeman, MT 82PT40 6V92TA 74FC34 6V53T Keith Strehle wrote: > Will the adapter turn independent of the valve and piping? Like a > pipe union fitting? > > --- In WanderlodgeForum@yahoogroups.com > > > > > Keith, you should contact Jeff Miller at Dupree Products > > (616.355.9811). He owns Dupree now & has the valves in stock as > well as > > all the rebuild parts. Also,. you can upgrade to air valves if > that > > interests you? The bodies are glued into the tank adapter. If you > get > > lucky, the adapter that screws into the tank will turn out easily. > If > > not, you have the cut the fitting out of the tank & glue a new one > in. > > > > Terry Neal > > Bozeman, MT > > 82PT40 6V92TA > > 74FC34 6V53T > > > > > > Keith Strehle wrote: > > > > > The next item on the list is the dump valves. They are the twist > lock > > > type and appear to be original equipment. The look just like the > Dupree > > > valves? Are there knockoffs out there? Are the valve bodies glued > in? > > > If they are Dupree valves, should I rebuild or replace the gate > > > assembly? > > > > > > Thanks, Keith > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > [Non-text portions of this message have been removed] |
02-27-2007, 12:42
Dump Valve Rebuild?
Now that there is a discussion of dump valves ... and you mention the
&^%^&% air valves ... I really hate having to 'air up' the coach just to dump, especially when I'm in an RV park for a week or so. It seems so silly to run a 500 hp engine just to get the air pressure to dump the sewage. So, does anybody know if 1. is it practical to re-route the air valve source to the auxiliary compressor (used to provide air to the Microphor toilet) -- and will that compressor be able to provide enough air to efficiently operate the air valves without stressing the compressor, or 2. what are some of the alternatives (and costs + ease of installation). Are electric valves a good idea? I certainly don't really want to hassle with manual valves... the switches are close enough to the sewage as it is... When in an RV park, I usually go 3 days between dumps or I dump on the day we leave... It's not like I do it all the time, but I have noticed a few strange looks from neighbors after I've 'aired up' to do a dump. Pete Masterson aeonix1@... '95 Blue Bird Wanderlodge WBDA 42' El Sobrante, CA On Feb 27, 2007, at 1:34 PM, Terry Neal wrote: > Keith, you should contact Jeff Miller at Dupree Products > (616.355.9811). He owns Dupree now & has the valves in stock as > well as > all the rebuild parts. Also,. you can upgrade to air valves if that > interests you? The bodies are glued into the tank adapter. If you > get > lucky, the adapter that screws into the tank will turn out easily. If > not, you have the cut the fitting out of the tank & glue a new one in. > > Terry Neal > Bozeman, MT > 82PT40 6V92TA > 74FC34 6V53T > > > Keith Strehle wrote: > >> The next item on the list is the dump valves. They are the twist lock >> type and appear to be original equipment. The look just like the >> Dupree >> valves? Are there knockoffs out there? Are the valve bodies glued in? >> If they are Dupree valves, should I rebuild or replace the gate >> assembly? >> >> Thanks, Keith >> [Non-text portions of this message have been removed] |
02-27-2007, 13:07
Dump Valve Rebuild?
So your auxilliary pump only does the Microphor? Mine will fill
anything/everything, including air bags. It cuts out at 90PSI. I like being able to have full-usable air before the engine is even started. The 8V92 doesn't need a long warmup (my opinion, anyway), so I can roll soon after startup. On 2/27/2007 at 4:42 PM Pete Masterson wrote: >Now that there is a discussion of dump valves ... and you mention the >&^%^&% air valves ... > >I really hate having to 'air up' the coach just to dump, especially >when I'm in an RV park for a week or so. It seems so silly to run a >500 hp engine just to get the air pressure to dump the sewage. > >So, does anybody know if >1. is it practical to re-route the air valve source to the auxiliary >compressor (used to provide air to the Microphor toilet) -- and will >that compressor be able to provide enough air to efficiently operate >the air valves without stressing the compressor, or >2. what are some of the alternatives (and costs + ease of >installation). Are electric valves a good idea? I certainly don't >really want to hassle with manual valves... the switches are close >enough to the sewage as it is... > >When in an RV park, I usually go 3 days between dumps or I dump on >the day we leave... It's not like I do it all the time, but I have >noticed a few strange looks from neighbors after I've 'aired up' to >do a dump. Don Bradner 90 PT40 "Blue Thunder" Eureka, CA |
02-27-2007, 13:12
Dump Valve Rebuild?
OK, I'll bite. You don't have an aux air compressor that pre-loads
your chassis air tanks, which is then used to power the dump valves? That's the way my 91 works. I thought all the late 80s and up had that?? Mike Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX --- In WanderlodgeForum@yahoogroups.com, Pete Masterson wrote: > > Now that there is a discussion of dump valves ... and you mention the > &^%^&% air valves ... > > I really hate having to 'air up' the coach just to dump, especially > when I'm in an RV park for a week or so. It seems so silly to run a > 500 hp engine just to get the air pressure to dump the sewage. > > So, does anybody know if > 1. is it practical to re-route the air valve source to the auxiliary > compressor (used to provide air to the Microphor toilet) -- and will > that compressor be able to provide enough air to efficiently operate > the air valves without stressing the compressor, or > 2. what are some of the alternatives (and costs + ease of > installation). Are electric valves a good idea? I certainly don't > really want to hassle with manual valves... the switches are close > enough to the sewage as it is... > > When in an RV park, I usually go 3 days between dumps or I dump on > the day we leave... It's not like I do it all the time, but I have > noticed a few strange looks from neighbors after I've 'aired up' to > do a dump. > > Pete Masterson > aeonix1@... > '95 Blue Bird Wanderlodge WBDA 42' > El Sobrante, CA > > > > > On Feb 27, 2007, at 1:34 PM, Terry Neal wrote: > > > Keith, you should contact Jeff Miller at Dupree Products > > (616.355.9811). He owns Dupree now & has the valves in stock as > > well as > > all the rebuild parts. Also,. you can upgrade to air valves if that > > interests you? The bodies are glued into the tank adapter. If you > > get > > lucky, the adapter that screws into the tank will turn out easily. If > > not, you have the cut the fitting out of the tank & glue a new one in. > > > > Terry Neal > > Bozeman, MT > > 82PT40 6V92TA > > 74FC34 6V53T > > > > > > Keith Strehle wrote: > > > >> The next item on the list is the dump valves. They are the twist lock > >> type and appear to be original equipment. The look just like the > >> Dupree > >> valves? Are there knockoffs out there? Are the valve bodies glued in? > >> If they are Dupree valves, should I rebuild or replace the gate > >> assembly? > >> > >> Thanks, Keith > >> > > > > [Non-text portions of this message have been removed] > |
02-27-2007, 13:15
Dump Valve Rebuild?
I don't have air valves Pete. I just mentioned them so Keith could
consider them as an option. I know there are electric valves out there too. Believe they are 12 volt. I don't see why you can't power your waste valves from your aux air system if your aux compressor is plumbed into your coach air system? Should be an easy modification for your coach I think. That's what most people are doing with an aux compressor anyway so you don't have to fire up that big diesel to have air to leave a campground or to dump your holding tanks. I have an aux compressor that I will plumb into my coach air system so I won't kill any neighbors on a cold Detroit start up. Terry Neal Bozeman, MT 82PT40 6V92TA 74FC34 6V53T Pete Masterson wrote: > Now that there is a discussion of dump valves ... and you mention the > &^%^&% air valves ... > > I really hate having to 'air up' the coach just to dump, especially > when I'm in an RV park for a week or so. It seems so silly to run a > 500 hp engine just to get the air pressure to dump the sewage. > > So, does anybody know if > 1. is it practical to re-route the air valve source to the auxiliary > compressor (used to provide air to the Microphor toilet) -- and will > that compressor be able to provide enough air to efficiently operate > the air valves without stressing the compressor, or > 2. what are some of the alternatives (and costs + ease of > installation). Are electric valves a good idea? I certainly don't > really want to hassle with manual valves... the switches are close > enough to the sewage as it is... > > When in an RV park, I usually go 3 days between dumps or I dump on > the day we leave... It's not like I do it all the time, but I have > noticed a few strange looks from neighbors after I've 'aired up' to > do a dump. > > Pete Masterson > aeonix1@... > '95 Blue Bird Wanderlodge WBDA 42' > El Sobrante, CA > > On Feb 27, 2007, at 1:34 PM, Terry Neal wrote: > > > Keith, you should contact Jeff Miller at Dupree Products > > (616.355.9811). He owns Dupree now & has the valves in stock as > > well as > > all the rebuild parts. Also,. you can upgrade to air valves if that > > interests you? The bodies are glued into the tank adapter. If you > > get > > lucky, the adapter that screws into the tank will turn out easily. If > > not, you have the cut the fitting out of the tank & glue a new one in. > > > > Terry Neal > > Bozeman, MT > > 82PT40 6V92TA > > 74FC34 6V53T > > > > > > Keith Strehle wrote: > > > >> The next item on the list is the dump valves. They are the twist lock > >> type and appear to be original equipment. The look just like the > >> Dupree > >> valves? Are there knockoffs out there? Are the valve bodies glued in? > >> If they are Dupree valves, should I rebuild or replace the gate > >> assembly? > >> > >> Thanks, Keith > >> > > [Non-text portions of this message have been removed] > > [Non-text portions of this message have been removed] |
02-27-2007, 13:27
Dump Valve Rebuild?
As things are currently arranged, the auxiliary compressor only does
the toilet. It cuts in around 65# and cuts out at 90PSI. I'd be happy if it did the dump valves. The suspension/brakes -- well, I'd just as soon leave those alone. Anyway, I don't mind waiting for the air for a departure ... the series 60 doesn't take all that long to pressurize the system --- I usually run it to air up while I'm raising the HWH jacks anyway, so it doesn't delay a departure much. (I still go and visually check the HWH jacks to make sure they're up.) Pete Masterson aeonix1@... '95 Blue Bird Wanderlodge WBDA 42' El Sobrante, CA On Feb 27, 2007, at 5:07 PM, Don Bradner wrote: > So your auxilliary pump only does the Microphor? Mine will fill > anything/everything, including air bags. It cuts out at 90PSI. > > I like being able to have full-usable air before the engine is even > started. The 8V92 doesn't need a long warmup (my opinion, anyway), > so I can roll soon after startup. > > On 2/27/2007 at 4:42 PM Pete Masterson wrote: > >> Now that there is a discussion of dump valves ... and you mention the >> &^%^&% air valves ... >> >> I really hate having to 'air up' the coach just to dump, especially >> when I'm in an RV park for a week or so. It seems so silly to run a >> 500 hp engine just to get the air pressure to dump the sewage. >> >> So, does anybody know if >> 1. is it practical to re-route the air valve source to the auxiliary >> compressor (used to provide air to the Microphor toilet) -- and will >> that compressor be able to provide enough air to efficiently operate >> the air valves without stressing the compressor, or >> 2. what are some of the alternatives (and costs + ease of >> installation). Are electric valves a good idea? I certainly don't >> really want to hassle with manual valves... the switches are close >> enough to the sewage as it is... >> >> When in an RV park, I usually go 3 days between dumps or I dump on >> the day we leave... It's not like I do it all the time, but I have >> noticed a few strange looks from neighbors after I've 'aired up' to >> do a dump. > > > Don Bradner > 90 PT40 "Blue Thunder" > Eureka, CA > > > > ------------------------ Yahoo! Groups Sponsor -------------------- > ~--> > Check out the new improvements in Yahoo! Groups email. > http://us.click.yahoo.com/4It09A/fOaOAA/.../pkiolB/TM > -------------------------------------------------------------------- > ~-> > > > Yahoo! Groups Links > > > [Non-text portions of this message have been removed] |
02-27-2007, 13:44
Dump Valve Rebuild?
Pete:
I am going to put in an auxiliary compressor just to do that, I hate starting up the engine just to dump as well. Bill 84 FC 35 SB "$quanderlodge" Terrace, B.C. Canada ----- Original Message ---- From: Pete Masterson To: WanderlodgeForum@yahoogroups.com Sent: Tuesday, February 27, 2007 4:42:13 PM Subject: Re: [WanderlodgeForum] Dump Valve Rebuild? Now that there is a discussion of dump valves ... and you mention the &^%^&% air valves ... I really hate having to 'air up' the coach just to dump, especially when I'm in an RV park for a week or so. It seems so silly to run a 500 hp engine just to get the air pressure to dump the sewage. So, does anybody know if 1. is it practical to re-route the air valve source to the auxiliary compressor (used to provide air to the Microphor toilet) -- and will that compressor be able to provide enough air to efficiently operate the air valves without stressing the compressor, or 2. what are some of the alternatives (and costs + ease of installation) . Are electric valves a good idea? I certainly don't really want to hassle with manual valves... the switches are close enough to the sewage as it is... When in an RV park, I usually go 3 days between dumps or I dump on the day we leave... It's not like I do it all the time, but I have noticed a few strange looks from neighbors after I've 'aired up' to do a dump. Pete Masterson aeonix1@mac. com '95 Blue Bird Wanderlodge WBDA 42' El Sobrante, CA On Feb 27, 2007, at 1:34 PM, Terry Neal wrote: > Keith, you should contact Jeff Miller at Dupree Products > (616.355.9811) . He owns Dupree now & has the valves in stock as > well as > all the rebuild parts. Also,. you can upgrade to air valves if that > interests you? The bodies are glued into the tank adapter. If you > get > lucky, the adapter that screws into the tank will turn out easily. If > not, you have the cut the fitting out of the tank & glue a new one in. > > Terry Neal > Bozeman, MT > 82PT40 6V92TA > 74FC34 6V53T > > > Keith Strehle wrote: > >> The next item on the list is the dump valves. They are the twist lock >> type and appear to be original equipment. The look just like the >> Dupree >> valves? Are there knockoffs out there? Are the valve bodies glued in? >> If they are Dupree valves, should I rebuild or replace the gate >> assembly? >> >> Thanks, Keith >> [Non-text portions of this message have been removed] <!-- #ygrp-mlmsg {font-size:13px;font-family:arial,helvetica,clean,sans-serif;} #ygrp-mlmsg table {font-size:inherit;font:100%;} #ygrp-mlmsg select, input, textarea {font:99% arial,helvetica,clean,sans-serif;} #ygrp-mlmsg pre, code {font:115% monospace;} #ygrp-mlmsg * {line-height:1.22em;} #ygrp-text{ font-family:Georgia; } #ygrp-text p{ margin:0 0 1em 0; } #ygrp-tpmsgs{ font-family:Arial; clear:both; } #ygrp-vitnav{ padding-top:10px; font-family:Verdana; font-size:77%; margin:0; } #ygrp-vitnav a{ padding:0 1px; } #ygrp-actbar{ clear:both; margin:25px 0; white-space:nowrap; color:#666; text-align:right; } #ygrp-actbar .left{ float:left; white-space:nowrap; } .bld{font-weight:bold;} #ygrp-grft{ font-family:Verdana; font-size:77%; padding:15px 0; } #ygrp-ft{ font-family:verdana; font-size:77%; border-top:1px solid #666; padding:5px 0; } #ygrp-mlmsg #logo{ padding-bottom:10px; } #ygrp-vital{ background-color:#e0ecee; margin-bottom:20px; padding:2px 0 8px 8px; } #ygrp-vital #vithd{ font-size:77%; font-family:Verdana; font-weight:bold; color:#333; text-transform:uppercase; } #ygrp-vital ul{ padding:0; margin:2px 0; } #ygrp-vital ul li{ list-style-type:none; clear:both; border:1px solid #e0ecee; } #ygrp-vital ul li .ct{ font-weight:bold; color:#ff7900; float:right; width:2em; text-align:right; padding-right:.5em; } #ygrp-vital ul li .cat{ font-weight:bold; } #ygrp-vital a { text-decoration:none; } #ygrp-vital a:hover{ text-decoration:underline; } #ygrp-sponsor #hd{ color:#999; font-size:77%; } #ygrp-sponsor #ov{ padding:6px 13px; background-color:#e0ecee; margin-bottom:20px; } #ygrp-sponsor #ov ul{ padding:0 0 0 8px; margin:0; } #ygrp-sponsor #ov li{ list-style-type:square; padding:6px 0; font-size:77%; } #ygrp-sponsor #ov li a{ text-decoration:none; font-size:130%; } #ygrp-sponsor #nc { background-color:#eee; margin-bottom:20px; padding:0 8px; } #ygrp-sponsor .ad{ padding:8px 0; } #ygrp-sponsor .ad #hd1{ font-family:Arial; font-weight:bold; color:#628c2a; font-size:100%; line-height:122%; } #ygrp-sponsor .ad a{ text-decoration:none; } #ygrp-sponsor .ad a:hover{ text-decoration:underline; } #ygrp-sponsor .ad p{ margin:0; } o {font-size:0;} .MsoNormal { margin:0 0 0 0; } #ygrp-text tt{ font-size:120%; } blockquote{margin:0 0 0 4px;} .replbq {margin:4;} --> __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com [Non-text portions of this message have been removed] |
