Leveling jacks system resevoir
02-28-2007, 10:42
Would anyone be able to tell me where the fill point is for the
leveling jacks on the 84FCSB?
Thanks, Keith
02-28-2007, 10:50
On My 87FC, it is under the entry step. Take a look, you'll see how to
get to it under the carpet.
Robert Britton
87FC
Hollister, California
--- In WanderlodgeForum@yahoogroups.com, "Keith Strehle"
> Thanks, Keith
02-28-2007, 10:56
Okay, that's what the metal plate is for. I'm thinking that's why
I'm getting the dash alarm on the jacks? Low fluid maybe? Do you
have those alarms on your bus?
--- In WanderlodgeForum@yahoogroups.com, "Robert Britton"
to
> Robert Britton
> 87FC
> > Thanks, Keith
02-28-2007, 11:33
Make sure the springs are pulling the jack all the way up into it's
stored position. If not , then you may get an alarm.
Robert Britton
87FC
how
> to
> > Robert Britton
> > 87FC
> > > Thanks, Keith
02-28-2007, 11:43
They're going all the way up. The problem is getting them down.
That's whay I think it may be a fluid level problem. Seems like the
first one goes down fine. Then the alarms start? If I get time I'll
check the level tonight. Is the fluid Dextron?
> Robert Britton
> 87FC
why
you
> how
> > to
> > > Robert Britton
> > > 87FC
> > > > Thanks, Keith
02-28-2007, 12:04
Keith, The dash alarm goes off on Pokey regularly. I have to get out and help
the jacks to the rest position or the alarm won't go off.
Doug Engel, Gunnison, CO, 1981 FC35SB, "Pokey"
to
> Robert Britton
> 87FC
> > Thanks, Keith
Never Miss an Email
Stay connected with Yahoo! Mail on your mobile. Get started!
02-28-2007, 12:10
That kinda makes sense. Mine aren't going down. So they must be
getting into the alarm area but not going past it? Hopefully when I
add fluid they will go down all the way.
--- In WanderlodgeForum@yahoogroups.com, Doug Engel
out and help the jacks to the rest position or the alarm won't go
off.
that's why
how
> to
> > Robert Britton
> > 87FC
> > > Thanks, Keith
> Never Miss an Email
02-28-2007, 12:26
A-firm on the Dextron!
Robert Britton
87FC
I'll
it's
> > Robert Britton
> > 87FC
> why
> you
see
> > how
> > > to
> > > > Robert Britton
> > > > 87FC
> the
> > > > > Thanks, Keith
02-28-2007, 12:29
The alarm is telling you that the jacks are down(or part way down) and
the ignition switch is on so you don't drive off with the jacks down.
David Hollis 84FC35 Springfield,IL
03-01-2007, 05:52
That makes sense. Can you tell me where the fluid level should be in
the tank? There doesen't seem to be a dipstick or any way to tell
other than to top it off. (In the up position)
--- In WanderlodgeForum@yahoogroups.com, "dthollis1961"
down.
when I
