50AMP pdf file
03-02-2007, 02:58
50AMP pdf file
Good morning everyone:
I have added a new folder in the files section on the Forum. It shows and explains in some detail, about 50 AMP service. How to check it, how to wire it and some of the terminology. This came up on another TECH Forum I am on, and thought it would be a good addition for our Birds. Hope it helps explain how it works. Safe travels, Ralph and Charolette Fullenwider 84FC35 Ralph's RV Solutions, Duncan, Oklahoma |
03-02-2007, 05:47
50AMP pdf file
I reviewed your file on the 50 Amp plug. The last diagram shows 120
Volt reading between the red and black feeds. This will be 240 volt not 120 volt. Peter 78 FC --- In WanderlodgeForum@yahoogroups.com, "Ralph L. Fullenwider" > > Good morning everyone: > > I have added a new folder in the files section on the Forum. It shows and > explains in some detail, about 50 AMP service. How to check it, how to wire > it and some of the terminology. > > This came up on another TECH Forum I am on, and thought it would be a good > addition for our Birds. > > Hope it helps explain how it works. > > Safe travels, > > Ralph and Charolette Fullenwider > 84FC35 > Ralph's RV Solutions, Duncan, Oklahoma > |
03-02-2007, 06:24
50AMP pdf file
Thank you, your right, I forgot to change the drawing when I did a copy and
paste. Will change it. Safe travels, Ralph and Charolette Fullenwider '84 FC35 Duncan, Oklahoma Ralph's RV Solutions At 05:47 PM 3/2/2007 +0000, you wrote: >I reviewed your file on the 50 Amp plug. The last diagram shows 120 >Volt reading between the red and black feeds. This will be 240 volt not >120 volt. > >Peter > >78 FC > > |
