Hose R&R...Making Progress
03-02-2007, 14:23
Progress...
Today I got back to R&Ring more hose, specifically the engine air compressor coolant hose from the engine block (above the starter) to the froward end of the engine driven air compressor. To loosen up the compressor forward coolant hose fitting, I made up an extended 7/8" open ended wrench. Using a Harbor Freight 7/8" B/O end wrench, I welded the box end to a 1" pipe. This is about 27" total length. Why did I do this? I needed to crack (loosen) the hose connection at the front of the air compressor. I'm not skinny enough to slither up beside anything to get to that fitting. The tool worked great, laying on my creeper and working from the passenger side of the transmission. Once the hose connection was cracked, I could reach in from the drivers side over top of the engine and finish removing that hose connection. The good thing is the radiator is out of the bus giving me that reach in and finish removing that fitting. I could not get the leverage need to reach in with a wrench and loosen that fitting. Randy, your worker must be really really really really skinny, really really small, to get up in that area to R&R that compressor hose. I'll post more as progress is made. Maybe I'll write up a project procedure for changing thermostats, change fuel & coolant hoses, an all in one procedure. This is truly fun... -- Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, Calif. |
03-03-2007, 04:56
Curt,
That would be really really really great to get a write-up on these projects. Did you take any pictures to go with the write-up? Dick Hayden - '87 PT 38 - Lake Stevens, WA ----- Original Message ----- From: Curt Sprenger To: WanderlodgeForum@yahoogroups.com ; wanderlodge@yahoogroups.com Sent: Friday, March 02, 2007 6:23 PM Subject: [WanderlodgeForum] Hose R&R...Making Progress Progress... Today I got back to R&Ring more hose, specifically the engine air compressor coolant hose from the engine block (above the starter) to the froward end of the engine driven air compressor. To loosen up the compressor forward coolant hose fitting, I made up an extended 7/8" open ended wrench. Using a Harbor Freight 7/8" B/O end wrench, I welded the box end to a 1" pipe. This is about 27" total length. Why did I do this? I needed to crack (loosen) the hose connection at the front of the air compressor. I'm not skinny enough to slither up beside anything to get to that fitting. The tool worked great, laying on my creeper and working from the passenger side of the transmission. Once the hose connection was cracked, I could reach in from the drivers side over top of the engine and finish removing that hose connection. The good thing is the radiator is out of the bus giving me that reach in and finish removing that fitting. I could not get the leverage need to reach in with a wrench and loosen that fitting. Randy, your worker must be really really really really skinny, really really small, to get up in that area to R&R that compressor hose. I'll post more as progress is made. Maybe I'll write up a project procedure for changing thermostats, change fuel & coolant hoses, an all in one procedure. This is truly fun... -- Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, Calif. [Non-text portions of this message have been removed] |
