Towing a Honda CRT/Pilot
04-29-2005, 22:19
Hi Jon,
I tow an '04 Honda Pilot. Most Honda's with AWD/4WD have to be towed with all four wheels down. Before towing, you have to start the toad, then the routine in my manual goes as such: 1. Apply emergency brake 2. Move shifter through all positions slowly 3. Return shifter to "neutral" position 4. Allow toad to idle for 3 minutes in neutral. (usually a good time to go out and hook up to the hitch/towbar) 5. Release emergency brake 6. Shut off engine on toad and leave key in position "I" so that steering wheel does not lock. 7. If towing for extended periods, repeat this procedure every 8 hours. Shane Fedeli 85PT40 Hershey, PA --- In WanderlodgeForum@yahoogroups.com, "Jon" > I found out that my 2003 Honda can be towed without any special gear > to > seperate the automatic transmission from the drive line. I had been > under the impression that all the automatic cars made today had to > have > a seperate device to allow the transmission to not opperate while > being > towed. I do know that their are a few vehicles out their that have a > unit after the automatic to seperate the trans from the drive train. > So > oft to the an RV shop to have the proper tow gear installed on the > big > surprise. Jon(life is good) > Jon Lechich > 1978 Wanderlodge > Bremerton Washington |
04-30-2005, 01:04
My Honda is a CVCC but it should be the same as your Pilot. But befor I get to
the point of towing it I will really do alot of reseach on this subject as like someone said you don't want to fry your transmission and I certainly do not want to do that. Jon Jon Lechich 1978 Wanderlodge sfedeli3 <sfedeli3@...> wrote: Hi Jon, I tow an '04 Honda Pilot. Most Honda's with AWD/4WD have to be towed with all four wheels down. Before towing, you have to start the toad, then the routine in my manual goes as such: 1. Apply emergency brake 2. Move shifter through all positions slowly 3. Return shifter to "neutral" position 4. Allow toad to idle for 3 minutes in neutral. (usually a good time to go out and hook up to the hitch/towbar) 5. Release emergency brake 6. Shut off engine on toad and leave key in position "I" so that steering wheel does not lock. 7. If towing for extended periods, repeat this procedure every 8 hours. Shane Fedeli 85PT40 Hershey, PA --- In WanderlodgeForum@yahoogroups.com, "Jon" > I found out that my 2003 Honda can be towed without any special gear > to > seperate the automatic transmission from the drive line. I had been > under the impression that all the automatic cars made today had to > have > a seperate device to allow the transmission to not opperate while > being > towed. I do know that their are a few vehicles out their that have a > unit after the automatic to seperate the trans from the drive train. > So > oft to the an RV shop to have the proper tow gear installed on the > big > surprise. Jon(life is good) > Jon Lechich > 1978 Wanderlodge > Bremerton Washington --------------------------------- Yahoo! Groups Links To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. One of my favorite sayings goes! "You never own anything, everything owns you!" __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com [Non-text portions of this message have been removed] |
04-30-2005, 11:03
There is a VERY important addition to steps 2 and 3 below: Honda
automatics MUST be shifted from drive into neutral prior to towing. Shifting to neutral from reverse will leave internal parts engaged in such a way that transmission damage will result. As far as I know, this appies to all Honda automatics, all years. Bob Griesel --- In WanderlodgeForum@yahoogroups.com, "sfedeli3" <sfedeli3@c...> wrote: > Hi Jon, > > I tow an '04 Honda Pilot. Most Honda's with AWD/4WD have to be towed > with all four wheels down. Before towing, you have to start the > toad, > then the routine in my manual goes as such: > > 1. Apply emergency brake > 2. Move shifter through all positions slowly > 3. Return shifter to "neutral" position > 4. Allow toad to idle for 3 minutes in neutral. (usually a good time > to go out and hook up to the hitch/towbar) > 5. Release emergency brake > 6. Shut off engine on toad and leave key in position "I" so that > steering wheel does not lock. > 7. If towing for extended periods, repeat this procedure every 8 > hours. > > Shane Fedeli > 85PT40 > Hershey, PA > > --- In WanderlodgeForum@yahoogroups.com, "Jon" > > > > > I found out that my 2003 Honda can be towed without any special > gear > > to > > seperate the automatic transmission from the drive line. I had > been > > under the impression that all the automatic cars made today had to > > have > > a seperate device to allow the transmission to not opperate while > > being > > towed. I do know that their are a few vehicles out their that have > a > > unit after the automatic to seperate the trans from the drive > train. > > So > > oft to the an RV shop to have the proper tow gear installed on the > > big > > surprise. Jon(life is good) > > Jon Lechich > > 1978 Wanderlodge > > Bremerton Washington |
