propane fill
03-02-2007, 10:50
propane fill
On my way up north last month, had my propane tank filled. I have been
using one furnace since I left- the kitchen furnace puts out fumes, that one is off. So for about 30 days have been running the front furnace and checking my gauge. Last nite- furnace was putting out cold air and gauge was down to zero- thats what it looked like. Added more propane but it would only take 25 gallons. Wonder why it wouldn't take more? Ernie-83PT40 in Montana- 2.59 a gallon here today- last month in colorado-1.59 |
03-03-2007, 00:17
propane fill
--- In WanderlodgeForum@yahoogroups.com,
Hi Ernie, I have run ours down to all sorts of low and have never been able to get more than 25 gallons in it. Crit Bliss '80FC33 Chatham,Ma. "Ernest Ekberg" > > On my way up north last month, had my propane tank filled. I have been > using one furnace since I left- the kitchen furnace puts out fumes, > that one is off. So for about 30 days have been running the front > furnace and checking my gauge. Last nite- furnace was putting out cold > air and gauge was down to zero- thats what it looked like. Added more > propane but it would only take 25 gallons. Wonder why it wouldn't take > more? Ernie-83PT40 in Montana- 2.59 a gallon here today- last month in > colorado-1.59 > |
03-03-2007, 02:38
propane fill
Maybe thats the point where it will only accept 25 gallons. Looks like my 1
furnace consumes a gallon per day. Ernie Ekberg 83PT40 Livingston,Montana ----- Original Message ----- From: crittenden_bliss To: WanderlodgeForum@yahoogroups.com Sent: Saturday, March 03, 2007 5:17 AM Subject: [WanderlodgeForum] Re: propane fill --- In WanderlodgeForum@yahoogroups.com, Hi Ernie, I have run ours down to all sorts of low and have never been able to get more than 25 gallons in it. Crit Bliss '80FC33 Chatham,Ma. "Ernest Ekberg" > > On my way up north last month, had my propane tank filled. I have been > using one furnace since I left- the kitchen furnace puts out fumes, > that one is off. So for about 30 days have been running the front > furnace and checking my gauge. Last nite- furnace was putting out cold > air and gauge was down to zero- thats what it looked like. Added more > propane but it would only take 25 gallons. Wonder why it wouldn't take > more? Ernie-83PT40 in Montana- 2.59 a gallon here today- last month in > colorado-1.59 > [Non-text portions of this message have been removed] |
03-03-2007, 08:51
propane fill
Hi Ernie,
Try having your tank "Purged" before you get it filled next time. It is my understanding that the tanks get residual air in them over time and will not accept enough LP when you fill up. The other problem could be a sticking float on your OPD. You can easily remove the repair the contraption when the tank is empty next time. Another test that you should run is to turn off the gas at the tank and also at the master valve in the refrigerator compartment. Then, a day later, turn the gas valve back on at the tank and listen to see if any gas is flowing back into the hose. If you hear a rush of gas, there is probably a leak somewhere. Good Luck! Shane Fedeli 85PT40 Hershey, PA --- In WanderlodgeForum@yahoogroups.com, > > Maybe thats the point where it will only accept 25 gallons. Looks like my 1 furnace consumes a gallon per day. > Ernie Ekberg > 83PT40 > Livingston,Montana > ----- Original Message ----- > From: crittenden_bliss > To: WanderlodgeForum@yahoogroups.com > Sent: Saturday, March 03, 2007 5:17 AM > Subject: [WanderlodgeForum] Re: propane fill > > > --- In WanderlodgeForum@yahoogroups.com, > > Hi Ernie, I have run ours down to all sorts of low and have never been > able to get more than 25 gallons in it. > Crit Bliss '80FC33 Chatham,Ma. > > "Ernest Ekberg" > > > > On my way up north last month, had my propane tank filled. I have been > > using one furnace since I left- the kitchen furnace puts out fumes, > > that one is off. So for about 30 days have been running the front > > furnace and checking my gauge. Last nite- furnace was putting out cold > > air and gauge was down to zero- thats what it looked like. Added more > > propane but it would only take 25 gallons. Wonder why it wouldn't take > > more? Ernie-83PT40 in Montana- 2.59 a gallon here today- last month in > > colorado-1.59 > > > > > > > > [Non-text portions of this message have been removed] > |
03-03-2007, 09:18
propane fill
Shane,
Do you know how to burp the tank??? Bill 88 FC --- In WanderlodgeForum@yahoogroups.com, "sfedeli3" <sfedeli3@...> wrote: > > Hi Ernie, > > Try having your tank "Purged" before you get it filled next time. > It is my understanding that the tanks get residual air in them over > time and will not accept enough LP when you fill up. The other > problem could be a sticking float on your OPD. You can easily remove > the repair the contraption when the tank is empty next time. > > Another test that you should run is to turn off the gas at the > tank and also at the master valve in the refrigerator compartment. > Then, a day later, turn the gas valve back on at the tank and listen > to see if any gas is flowing back into the hose. If you hear a rush > of gas, there is probably a leak somewhere. Good Luck! > > Shane Fedeli > 85PT40 > Hershey, PA > > > --- In WanderlodgeForum@yahoogroups.com, > > > > Maybe thats the point where it will only accept 25 gallons. Looks > like my 1 furnace consumes a gallon per day. > > Ernie Ekberg > > 83PT40 > > Livingston,Montana > > ----- Original Message ----- > > From: crittenden_bliss > > To: WanderlodgeForum@yahoogroups.com > > Sent: Saturday, March 03, 2007 5:17 AM > > Subject: [WanderlodgeForum] Re: propane fill > > > > > > --- In WanderlodgeForum@yahoogroups.com, > > > > Hi Ernie, I have run ours down to all sorts of low and have > never been > > able to get more than 25 gallons in it. > > Crit Bliss '80FC33 Chatham,Ma. > > > > "Ernest Ekberg" > > > > > > On my way up north last month, had my propane tank filled. I > have been > > > using one furnace since I left- the kitchen furnace puts out > fumes, > > > that one is off. So for about 30 days have been running the > front > > > furnace and checking my gauge. Last nite- furnace was putting > out cold > > > air and gauge was down to zero- thats what it looked like. > Added more > > > propane but it would only take 25 gallons. Wonder why it > wouldn't take > > > more? Ernie-83PT40 in Montana- 2.59 a gallon here today- last > month in > > > colorado-1.59 > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > |
03-03-2007, 09:49
propane fill
the tanks on a bird are full at 80% capacity or volume of tank there
needs to be room for the liquid to vaporize to a gas Burping should not be necessary there is a vent that should be opened when filling Stephen 77fc35 --- In WanderlodgeForum@yahoogroups.com, "pattypape" wrote: > > > Shane, > > Do you know how to burp the tank??? > > Bill 88 FC > > > --- In WanderlodgeForum@yahoogroups.com, "sfedeli3" <sfedeli3@> > wrote: > > > > Hi Ernie, > > > > Try having your tank "Purged" before you get it filled next time. > > It is my understanding that the tanks get residual air in them over > > time and will not accept enough LP when you fill up. The other > > problem could be a sticking float on your OPD. You can easily > remove > > the repair the contraption when the tank is empty next time. > > > > Another test that you should run is to turn off the gas at the > > tank and also at the master valve in the refrigerator compartment. > > Then, a day later, turn the gas valve back on at the tank and > listen > > to see if any gas is flowing back into the hose. If you hear a rush > > of gas, there is probably a leak somewhere. Good Luck! > > > > Shane Fedeli > > 85PT40 > > Hershey, PA > > > > > > --- In WanderlodgeForum@yahoogroups.com, > > > > > > Maybe thats the point where it will only accept 25 gallons. Looks > > like my 1 furnace consumes a gallon per day. > > > Ernie Ekberg > > > 83PT40 > > > Livingston,Montana > > > ----- Original Message ----- > > > From: crittenden_bliss > > > To: WanderlodgeForum@yahoogroups.com > > > Sent: Saturday, March 03, 2007 5:17 AM > > > Subject: [WanderlodgeForum] Re: propane fill > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, > > > > > > Hi Ernie, I have run ours down to all sorts of low and have > > never been > > > able to get more than 25 gallons in it. > > > Crit Bliss '80FC33 Chatham,Ma. > > > > > > "Ernest Ekberg" > > > > > > > > On my way up north last month, had my propane tank filled. I > > have been > > > > using one furnace since I left- the kitchen furnace puts out > > fumes, > > > > that one is off. So for about 30 days have been running the > > front > > > > furnace and checking my gauge. Last nite- furnace was putting > > out cold > > > > air and gauge was down to zero- thats what it looked like. > > Added more > > > > propane but it would only take 25 gallons. Wonder why it > > wouldn't take > > > > more? Ernie-83PT40 in Montana- 2.59 a gallon here today- last > > month in > > > > colorado-1.59 > > > > > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > |
03-03-2007, 09:49
propane fill
Hi Shane, how would you go about purging the tank? Ralph suggested a trouble
lite in that compartment. I'm also at 4500 feet above sea level. Ernie Ekberg 83PT40 Livingston,Montana "POO-DOO-EXPRESS" ----- Original Message ----- From: sfedeli3 To: WanderlodgeForum@yahoogroups.com Sent: Saturday, March 03, 2007 1:51 PM Subject: [WanderlodgeForum] Re: propane fill Hi Ernie, Try having your tank "Purged" before you get it filled next time. It is my understanding that the tanks get residual air in them over time and will not accept enough LP when you fill up. The other problem could be a sticking float on your OPD. You can easily remove the repair the contraption when the tank is empty next time. Another test that you should run is to turn off the gas at the tank and also at the master valve in the refrigerator compartment. Then, a day later, turn the gas valve back on at the tank and listen to see if any gas is flowing back into the hose. If you hear a rush of gas, there is probably a leak somewhere. Good Luck! Shane Fedeli 85PT40 Hershey, PA --- In WanderlodgeForum@yahoogroups.com, > > Maybe thats the point where it will only accept 25 gallons. Looks like my 1 furnace consumes a gallon per day. > Ernie Ekberg > 83PT40 > Livingston,Montana > ----- Original Message ----- > From: crittenden_bliss > To: WanderlodgeForum@yahoogroups.com > Sent: Saturday, March 03, 2007 5:17 AM > Subject: [WanderlodgeForum] Re: propane fill > > > --- In WanderlodgeForum@yahoogroups.com, > > Hi Ernie, I have run ours down to all sorts of low and have never been > able to get more than 25 gallons in it. > Crit Bliss '80FC33 Chatham,Ma. > > "Ernest Ekberg" > > > > On my way up north last month, had my propane tank filled. I have been > > using one furnace since I left- the kitchen furnace puts out fumes, > > that one is off. So for about 30 days have been running the front > > furnace and checking my gauge. Last nite- furnace was putting out cold > > air and gauge was down to zero- thats what it looked like. Added more > > propane but it would only take 25 gallons. Wonder why it wouldn't take > > more? Ernie-83PT40 in Montana- 2.59 a gallon here today- last month in > > colorado-1.59 > > > > > > > > [Non-text portions of this message have been removed] > [Non-text portions of this message have been removed] |
03-03-2007, 15:11
propane fill
Hi Ernie,
The last few times that I stopped at the Flying Hook for LP, they said that they no longer were opening the small valve to let air escape as the tank gets filled. You should be able to go to any propane dealer that fills tanks. They can purge (pull a vacuum) on the tank and get most of the residual air removed. You could also do it yourself if/when the tank is completely empty if you have access to a machine that can evacuate an A/C system. You would just need to get or make an adapter that would screw into the propane fill valve to pull the vacuum. Shane Fedeli 85PT40 Hershey, PA (In Jupiter FL for now) --- In WanderlodgeForum@yahoogroups.com, > > Hi Shane, how would you go about purging the tank? Ralph suggested a trouble lite in that compartment. I'm also at 4500 feet above sea level. > Ernie Ekberg > 83PT40 > Livingston,Montana > "POO-DOO-EXPRESS" > ----- Original Message ----- > From: sfedeli3 > To: WanderlodgeForum@yahoogroups.com > Sent: Saturday, March 03, 2007 1:51 PM > Subject: [WanderlodgeForum] Re: propane fill > > > Hi Ernie, > > Try having your tank "Purged" before you get it filled next time. > It is my understanding that the tanks get residual air in them over > time and will not accept enough LP when you fill up. The other > problem could be a sticking float on your OPD. You can easily remove > the repair the contraption when the tank is empty next time. > > Another test that you should run is to turn off the gas at the > tank and also at the master valve in the refrigerator compartment. > Then, a day later, turn the gas valve back on at the tank and listen > to see if any gas is flowing back into the hose. If you hear a rush > of gas, there is probably a leak somewhere. Good Luck! > > Shane Fedeli > 85PT40 > Hershey, PA > > --- In WanderlodgeForum@yahoogroups.com, > > > > Maybe thats the point where it will only accept 25 gallons. Looks > like my 1 furnace consumes a gallon per day. > > Ernie Ekberg > > 83PT40 > > Livingston,Montana > > ----- Original Message ----- > > From: crittenden_bliss > > To: WanderlodgeForum@yahoogroups.com > > Sent: Saturday, March 03, 2007 5:17 AM > > Subject: [WanderlodgeForum] Re: propane fill > > > > > > --- In WanderlodgeForum@yahoogroups.com, > > > > Hi Ernie, I have run ours down to all sorts of low and have > never been > > able to get more than 25 gallons in it. > > Crit Bliss '80FC33 Chatham,Ma. > > > > "Ernest Ekberg" > > > > > > On my way up north last month, had my propane tank filled. I > have been > > > using one furnace since I left- the kitchen furnace puts out > fumes, > > > that one is off. So for about 30 days have been running the > front > > > furnace and checking my gauge. Last nite- furnace was putting > out cold > > > air and gauge was down to zero- thats what it looked like. > Added more > > > propane but it would only take 25 gallons. Wonder why it > wouldn't take > > > more? Ernie-83PT40 in Montana- 2.59 a gallon here today- last > month in > > > colorado-1.59 > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > [Non-text portions of this message have been removed] > |
03-03-2007, 15:17
propane fill
They seem to be inconsistent. The Flying J in North Platt does not open the
valve, Oklahoma City does, El Paso does not, and Eloy does. Last time I was in North Platt a couple of weeks ago they said they would not fill the tank because of it's age until it was inspected. Went on down the road and filled it in Oklahoma City. Any one else run into this? - Chuck Wheeler - 82 FC 31 SB Fort Worth, TX _____ From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of sfedeli3 Sent: Saturday, March 03, 2007 9:12 PM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Re: propane fill Hi Ernie, The last few times that I stopped at the Flying Hook for LP, they said that they no longer were opening the small valve to let air escape as the tank gets filled. You should be able to go to any propane dealer that fills tanks. They can purge (pull a vacuum) on the tank and get most of the residual air removed. You could also do it yourself if/when the tank is completely empty if you have access to a machine that can evacuate an A/C system. You would just need to get or make an adapter that would screw into the propane fill valve to pull the vacuum. Shane Fedeli 85PT40 Hershey, PA (In Jupiter FL for now) --- In WanderlodgeForum@ yahoogroups.com, > > Hi Shane, how would you go about purging the tank? Ralph suggested a trouble lite in that compartment. I'm also at 4500 feet above sea level. > Ernie Ekberg > 83PT40 > Livingston,Montana > "POO-DOO-EXPRESS" > ----- Original Message ----- > From: sfedeli3 > To: WanderlodgeForum@ yahoogroups.com > Sent: Saturday, March 03, 2007 1:51 PM > Subject: [WanderlodgeForum] Re: propane fill > > > Hi Ernie, > > Try having your tank "Purged" before you get it filled next time. > It is my understanding that the tanks get residual air in them over > time and will not accept enough LP when you fill up. The other > problem could be a sticking float on your OPD. You can easily remove > the repair the contraption when the tank is empty next time. > > Another test that you should run is to turn off the gas at the > tank and also at the master valve in the refrigerator compartment. > Then, a day later, turn the gas valve back on at the tank and listen > to see if any gas is flowing back into the hose. If you hear a rush > of gas, there is probably a leak somewhere. Good Luck! > > Shane Fedeli > 85PT40 > Hershey, PA > > --- In WanderlodgeForum@ yahoogroups.com, > > > > Maybe thats the point where it will only accept 25 gallons. Looks > like my 1 furnace consumes a gallon per day. > > Ernie Ekberg > > 83PT40 > > Livingston,Montana > > ----- Original Message ----- > > From: crittenden_bliss > > To: WanderlodgeForum@ yahoogroups.com > > Sent: Saturday, March 03, 2007 5:17 AM > > Subject: [WanderlodgeForum] Re: propane fill > > > > > > --- In WanderlodgeForum@ yahoogroups.com, > > > > Hi Ernie, I have run ours down to all sorts of low and have > never been > > able to get more than 25 gallons in it. > > Crit Bliss '80FC33 Chatham,Ma. > > > > "Ernest Ekberg" > > > > > > On my way up north last month, had my propane tank filled. I > have been > > > using one furnace since I left- the kitchen furnace puts out > fumes, > > > that one is off. So for about 30 days have been running the > front > > > furnace and checking my gauge. Last nite- furnace was putting > out cold > > > air and gauge was down to zero- thats what it looked like. > Added more > > > propane but it would only take 25 gallons. Wonder why it > wouldn't take > > > more? Ernie-83PT40 in Montana- 2.59 a gallon here today- last > month in > > > colorado-1.59 > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > [Non-text portions of this message have been removed] > [Non-text portions of this message have been removed] |
03-03-2007, 15:53
propane fill
Some filler folks get confused between up-right tanks and lay-down
tanks. My understanding is the lay-down (horizontal) tank does not need the inspection. Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, Calif. Chuck Wheeler wrote: > They seem to be inconsistent. The Flying J in North Platt does not > open the > valve, Oklahoma City does, El Paso does not, and Eloy does. Last time > I was > in North Platt a couple of weeks ago they said they would not fill the > tank > because of it's age until it was inspected. Went on down the road and > filled it in Oklahoma City. Any one else run into this? > > - Chuck Wheeler - > 82 FC 31 SB > Fort Worth, TX > > > _____ > > From: WanderlodgeForum@yahoogroups.com > > [mailto:WanderlodgeForum@yahoogroups.com > > Sent: Saturday, March 03, 2007 9:12 PM > To: WanderlodgeForum@yahoogroups.com > > Subject: [WanderlodgeForum] Re: propane fill > > Hi Ernie, > > The last few times that I stopped at the Flying Hook for LP, > they said that they no longer were opening the small valve to let > air escape as the tank gets filled. You should be able to go to any > propane dealer that fills tanks. They can purge (pull a vacuum) on > the tank and get most of the residual air removed. You could also do > it yourself if/when the tank is completely empty if you have access > to a machine that can evacuate an A/C system. You would just need to > get or make an adapter that would screw into the propane fill valve > to pull the vacuum. > > Shane Fedeli > 85PT40 > Hershey, PA > (In Jupiter FL for now) > > --- In WanderlodgeForum@ > yahoogroups.com, > > > > Hi Shane, how would you go about purging the tank? Ralph suggested > a trouble lite in that compartment. I'm also at 4500 feet above sea > level. > > Ernie Ekberg > > 83PT40 > > Livingston,Montana > > "POO-DOO-EXPRESS" > > ----- Original Message ----- > > From: sfedeli3 > > To: WanderlodgeForum@ > yahoogroups.com > > Sent: Saturday, March 03, 2007 1:51 PM > > Subject: [WanderlodgeForum] Re: propane fill > > > > > > Hi Ernie, > > > > Try having your tank "Purged" before you get it filled next > time. > > It is my understanding that the tanks get residual air in them > over > > time and will not accept enough LP when you fill up. The other > > problem could be a sticking float on your OPD. You can easily > remove > > the repair the contraption when the tank is empty next time. > > > > Another test that you should run is to turn off the gas at the > > tank and also at the master valve in the refrigerator > compartment. > > Then, a day later, turn the gas valve back on at the tank and > listen > > to see if any gas is flowing back into the hose. If you hear a > rush > > of gas, there is probably a leak somewhere. Good Luck! > > > > Shane Fedeli > > 85PT40 > > Hershey, PA > > > > --- In WanderlodgeForum@ > yahoogroups.com, > > > > > > Maybe thats the point where it will only accept 25 gallons. > Looks > > like my 1 furnace consumes a gallon per day. > > > Ernie Ekberg > > > 83PT40 > > > Livingston,Montana > > > ----- Original Message ----- > > > From: crittenden_bliss > > > To: WanderlodgeForum@ > yahoogroups.com > > > Sent: Saturday, March 03, 2007 5:17 AM > > > Subject: [WanderlodgeForum] Re: propane fill > > > > > > > > > --- In WanderlodgeForum@ > yahoogroups.com, > > > > > > Hi Ernie, I have run ours down to all sorts of low and have > > never been > > > able to get more than 25 gallons in it. > > > Crit Bliss '80FC33 Chatham,Ma. > > > > > > "Ernest Ekberg" > > > > > > > > On my way up north last month, had my propane tank filled. I > > have been > > > > using one furnace since I left- the kitchen furnace puts out > > fumes, > > > > that one is off. So for about 30 days have been running the > > front > > > > furnace and checking my gauge. Last nite- furnace was > putting > > out cold > > > > air and gauge was down to zero- thats what it looked like. > > Added more > > > > propane but it would only take 25 gallons. Wonder why it > > wouldn't take > > > > more? Ernie-83PT40 in Montana- 2.59 a gallon here today- > last > > month in > > > > colorado-1.59 > > > > > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > [Non-text portions of this message have been removed] > > |
