Changing A/F in a 3208
03-03-2007, 12:18
I am going to change the A/F in our 88FC. The Blue Box
says the capacity with the heaters is 85 quarts. I was going to use A/F
that meets the basic Cat standard plus the additive. Is there any
trick to emptying the whole system. I was considering some low PSI air
pressure. What have others used for a/f and how did you empty the
cooling system?
Bruce
1988 FC35
03-04-2007, 01:47
Bruce, I've used Cat prediluted antifreeze since I bought the coach in 2000.
Cat says their
product has a usable life of 600,000 miles/6,000 hours/6 years but you must add
their
extended life additive package at 300,000 miles/3,000 hours/3 years to use it
this long.
Cat shops charge about $10/gallon bottle. I'll be changing out the system this
year.
Biggest problem I've had in the past is finding someone that will take the spent
antifreeze.
When I drain the system, I close the block valves on the circulation system and
drain the
radiator and engine block only. Volume comes to about 12-15 gallons. I figure
circulation system volume is negligible and don't try to drain it. I'm sure you
could blow
out the circ system with compressed air but I just haven't considered it worth
the effort.
Eric in San Antonio
84FC35SBWL2
> cooling system?
> Bruce
> 1988 FC35
03-04-2007, 03:38
--- I use the CAT predeluted stuff too on my 90SP36....costs $12/gal
in Vegas........red in color, supposed to last 600,000 miles or at
least for a while...make sure you follow instructions and drain all
the old stuff in the system..LOL
Hank Hannigan
90SP36
In WanderlodgeForum@yahoogroups.com, "Eric Johnson"
coach in 2000. Cat says their
you must add their
years to use it this long.
the system this year.
take the spent antifreeze.
circulation system and drain the
gallons. I figure the
it. I'm sure you could blow
considered it worth the effort.
> Eric in San Antonio
> 84FC35SBWL2
use A/F
PSI air
> > cooling system?
> > Bruce
> > 1988 FC35
03-04-2007, 04:25
Hank, noticed in your signiature line only 1 bird listed. You finally outta the
2 bird club?
83PT40
Livingston,Montana
"POO-DOO-EXPRESS"
Sent: Sunday, March 04, 2007 8:38 AM
Subject: [WanderlodgeForum] Re: Changing A/F in a 3208
Hank Hannigan
90SP36
you must add their
> Eric in San Antonio
> 84FC35SBWL2
use A/F
PSI air
> > cooling system?
> > Bruce
> > 1988 FC35
03-04-2007, 07:30
Eric: Thank you for that reply. I have done a lot of reading on A/F.
Used to be easy when you just went and bought a few gallons
of "Prestone". My BB Blue Box says that the cooling system capacity
is 61 quarts for the engine and 85 quarts if you include all the
heaters. That means there is 24 quarts in the heaters. Are you saying
you can buy Cat ELC A/F for a mere $10.00 a gallon?? Seems very
inexpensive. That is a word Cat does not understand. In the files
section in one of the Forums there is a Cat document that covers oils
and A/F. They say you can use any of 5 different coolants:
Non Cat ELC 3 years
Cat ELC 6 years
Cat Deac 3 years needs SCA
ASTM 6210 2 years needs SCA
ASTM 4985 1 year needs SCA
They all require Cat SOS testing at half life.
You CANNOT mix Extended life coolants (ELC) with other A/F. So if you
used the long life Cat and did not drain the heaters and flush you
could have a problem. I remember reading about certain mixtures of
A/F turning into a gel. A PHD in chemistry is needed to understand
all of this. Has anyone in this forum tried Final Charge??
Bruce
1988 FC35
03-04-2007, 09:27
Bruce,
I buy it a case at a time from Cat dealers for a "mere" $10-$12/gallon. Cat
stuff is not
cheap but afterall it is prediluted with 50% water and I don't think they use
Perrier for
diluent. It is Cat ELC. I've had no gelling or other problems. Just dumb
luck I guess as I
never got past a B.S. in ChE.
Eric in San Antonio
84FC35SBWL2
> Non Cat ELC 3 years
> Cat ELC 6 years
> Bruce
> 1988 FC35
03-04-2007, 12:53
Ya know, the coolant test strips are available at Cat or Napa, not expensive.
The coolant treatment is a little costly but I use recycled green in my rigs and
haven't had a cooling system failure in over 100k miles of operation. The
notion of extended life anything in a motor home makes no sense unless it is
used daily and covers lots of miles. Cheaper to the change the product, oil or
coolant frequently.
That strategy will achieve the same goal, extended service life of the engine.
There is no cheap way to get there.
MH
Sent: Sunday, March 04, 2007 1:30 PM
Non Cat ELC 3 years
Cat ELC 6 years
Bruce
1988 FC35
03-04-2007, 15:34
Yes sir, I do the same as you do. Mine is green, so far so good. It's like
in-flight insurance on my airplane, if I ever need that I will not be around to
collect it, you know! So why have it?
Leroy Eckert
1990 WB-40"Smoke N Mirrors"
Niceville, FL
Sent: Sunday, March 04, 2007 6:53 PM
Subject: Re: [WanderlodgeForum] Re: Changing A/F in a 3208
haven't had a cooling system failure in over 100k miles of operation. The notion
of extended life anything in a motor home makes no sense unless it is used daily
and covers lots of miles. Cheaper to the change the product, oil or coolant
frequently.
MH
Non Cat ELC 3 years
Cat ELC 6 years
Bruce
1988 FC35
03-04-2007, 17:01
---Yeh Ernie: no longer two bird club rep...delivered 80FC to
Alabama a couple weeks ago....It was a good bird.....we love our 90
SP36 and plan to keep it..LOL
Hank
90SP36 in VEGAS
finally outta the 2 bird club?
> Ernie Ekberg
> 83PT40
> Livingston,Montana
> "POO-DOO-EXPRESS"
> From: Henry Jay Hannigan
$12/gal
at
all
> Hank Hannigan
> 90SP36
but
> you must add their
will
> > Eric in San Antonio
> > 84FC35SBWL2
to
> use A/F
there any
low
> PSI air
empty the
> > > cooling system?
> > > Bruce
> > > 1988 FC35
