Coolant Pressure Control Cap
03-03-2007, 16:20
Coolant Pressure Control Cap...the 92 series manual recommends all
series 92 on-highway vehicle engines use a minimum 9 psi control cap.
My radiator cap is a 7 psi. Is this a Bluebird change? What are others
using? Should I be concerned? The engine temperature runs at about 185
to 195.
Curt Sprenger
Anaheim Hills, Calif.
03-03-2007, 16:43
Curt:
My cap is 13psi, was on the coach when I purchased it and it's still there. I
changed my fan control alarmstat to 190 degrees and my temperature range now in
winter is 180-190. I expect 190 constant with the chassis a/c on in summer. We
will see when it gets hot.
Leroy Eckert
1990 WB-40"Smoke N Mirrors"
Niceville, FL
To: WanderlodgeForum@yahoogroups.com ; wanderlodge@yahoogroups.com
Sent: Saturday, March 03, 2007 10:20 PM
Subject: [WanderlodgeForum] Coolant Pressure Control Cap
to 195.
Curt Sprenger
03-04-2007, 00:31
Curt,
The discrepancy between the manual and what BB does came up
previously. Due to the application being a motorhome, BB engineers
may (may) have determined the 7PSI is correct. Seems most folks have
a 7PSI cap on a 92. We have 7PSI, and temps run 190 – 195, and is
acceptable. I'd say your temps seem to be right on.
Ron, No. California
85PT36
> cap. My radiator cap is a 7 psi.
> Curt Sprenger
03-04-2007, 01:49
Leroy i also would like to change my fan switch to a 190,i changed
mine two years ago to a 195 its all i could find.If you have a part
number or the source it would be good. Thanks
Jack Jones
87 Pt 40
East Tn 27 and snowing
03-04-2007, 05:44
My theory about the 7 lb. cap is the coach heating system is tied into the
cooling system and Blue Bird has used that pressure to protect the other systems
in the coach,let alone miles of heater hose!
Fred & Jeanne Hulse
Morristown Arizona
1997 Wanderlodge WLWB41
03-04-2007, 14:09
Your theory may be totally correct.
My understand of cap pressure values, the higher the pressure, the higher the
boiling point. Assuming BB used top quality hoses and I believe they did I have
some trouble differentiating between the bus and my Cummins SLT 3/4 ton PU, when
it comes to cap pressure. My diesel truck heating system is tied to the cooling
system and it has a factory 15psi cap. My bus has a 13psi cap that I did not
install and over the past 3 years all has been good. The DD service manual says
7-9 psi. I give up, maybe.
Over the past few months I have been making small changes to the cooling system
in my bus. I am taking chances, testing them on my bus, in an effort to reduce
overall temperatures in the engine, transmission, retarder and engine oil. I
have changed the Alarmstat, which operates the hydraulic fan to 190 degrees from
195 degrees.
I will not know the full extent this change until summer, but so far it is
working.
Before I decided to make the change I consulted with DD approved shops and BB.
I was not satisfied with the answers sooooo, I pressed on.
The DD manual says to be careful not to have cooling system components operate
out of sequence because the result will be overheating. At this point in my
testing I have concluded the foregoing to mean, the cooling fan, the engine
thermostats, and the alarmstat, primarily because I do not know of any other
cooling affected components other than the cap.
Before I embarked upon my mission, I was told that temperature cycling was the
result of the engine thermostats cycling. Unfortunately, I cannot force that to
happen and I have tried. I have driven the coach in temperatures of below 32
degrees with the fan override on and my water temperature gauge stabilizes at
about 170 degrees, the engine thermostat value. In other words, it doesn't move
once stabilized, so the engine thermostats are not cycling(possibly). If they
are it is happening so quickly that it does not register on the temp guage or
they partially close and shut down the water flow to hold the constant
temperature. I cannot see them work. When I turn the fan override off the
temperature begins to cycle off the Alarmstat between 180-190 degrees.
All of this fits the DD published coolant Series 92 publication in my
possession. Why BB dedided on a 195 degree Alarmstat, only BB knows and they
aren't talking, because I have asked. I simply does not make sense to force the
temperatures to the outer limit of DD specifications, ;and that is what happens
in summer. Heat is our enemy and I have been able to reduce the heat.
Most likely, I will change my cap to 9psi sometime in the summer and see if that
makes any difference. My guess is it will not simply because keeping the engine
cooling system within temperature specifications precludes any real need for the
cap to blow off.
I like my drive train component temps now.
Engine Oil-215
Water Temp-Cycles between 180-190
Transmission Temp- 170
Retarder Temp- 220
All recorded in flat conditions at cruise speed of 68 mph, pulling a 20ft
trailer w/car.
I do not suggest you try anything unless you fully understand your system, I'm
simply reporting what I did.
The foregoing presumes that all system components are in proper working order.
My next project is to install MH's water injection system so when I climb the
mountains next summer I'll have a water flood just in case.
Alright, fire away, I have Redneck engineering paperwork on this one. LOL lol,
lol
Leroy Eckert
Niceville, FL
Sent: Sunday, March 04, 2007 11:44 AM
Subject: Re: [WanderlodgeForum] Coolant Pressure Control Cap
Fred & Jeanne Hulse
Morristown Arizona
03-04-2007, 14:38
Leroy: If you want to increase the cooling of your 8V-92 you
could install a 4" air scoup behind the radiator opening to help
catch the air and redirect it into the radiator. I did this on a 6V-
92. I had it made out of stainless steel it had nice curve to it to
help capture the air. It worked well. Bob
93pt40--Bunker Hill, Illinois....Soon to be back in Jackson,Wy.
higher the boiling point. Assuming BB used top quality hoses and I
believe they did I have some trouble differentiating between the bus
and my Cummins SLT 3/4 ton PU, when it comes to cap pressure. My
diesel truck heating system is tied to the cooling system and it has
a factory 15psi cap. My bus has a 13psi cap that I did not install
says 7-9 psi. I give up, maybe.
cooling system in my bus. I am taking chances, testing them on my
bus, in an effort to reduce overall temperatures in the engine,
transmission, retarder and engine oil. I have changed the Alarmstat,
which operates the hydraulic fan to 190 degrees from 195 degrees.
far it is working.
shops and BB. I was not satisfied with the answers sooooo, I pressed
on.
components operate out of sequence because the result will be
overheating. At this point in my testing I have concluded the
foregoing to mean, the cooling fan, the engine thermostats, and the
alarmstat, primarily because I do not know of any other cooling
cycling was the result of the engine thermostats cycling.
Unfortunately, I cannot force that to happen and I have tried. I
have driven the coach in temperatures of below 32 degrees with the
fan override on and my water temperature gauge stabilizes at about
move once stabilized, so the engine thermostats are not cycling
(possibly). If they are it is happening so quickly that it does not
register on the temp guage or they partially close and shut down the
water flow to hold the constant temperature. I cannot see them
work. When I turn the fan override off the temperature begins to
my possession. Why BB dedided on a 195 degree Alarmstat, only BB
knows and they aren't talking, because I have asked. I simply does
not make sense to force the temperatures to the outer limit of DD
specifications, ;and that is what happens in summer. Heat is our
and see if that makes any difference. My guess is it will not simply
because keeping the engine cooling system within temperature
specifications precludes any real need for the cap to blow off.
> Engine Oil-215
> Retarder Temp- 220
a 20ft trailer w/car.
system, I'm simply reporting what I did.
working order.
climb the mountains next summer I'll have a water flood just in case.
one. LOL lol, lol
> Leroy Eckert
> Niceville, FL
> From: Fred Hulse
into the cooling system and Blue Bird has used that pressure to
protect the other systems in the coach,let alone miles of heater hose!
> Fred & Jeanne Hulse
> Morristown Arizona
03-04-2007, 15:02
Leroy: I also installed what was or is called a swamp cooler
on the radiator. It took water from the potable water tank and thru a
pump and fittings it sprayed water on the radiator on demand. I had
the control at the driver panel. It had about four or five different
settings that sprayed water at timed rates. I would rate it about 5
on a scale of 1 to 10. I really never used it much. The best
procedure was to turn the fan on before the climb and adjust speed
and rpm with a lower gear and just sit and enjoy the ride up the
pass. One draw back might be that if your using really hard
water that you will get a mineral build up on the fin's of the
radiator rather quickly.(hard to get off).
worked for me..sort-of..??;;;;; Bob 93pt-40
bus
has
Alarmstat,
> far it is working.
pressed
> on.
doesn't
not
in
simply
> > Engine Oil-215
> > Retarder Temp- 220
pulling
your
> working order.
I
case.
> one. LOL lol, lol
> > Leroy Eckert
> > Niceville, FL
> > From: Fred Hulse
tied
hose!
> > Fred & Jeanne Hulse
> > Morristown Arizona
03-04-2007, 15:12
Thanks, I totally agree, that is an option. I have determined that air flow
and fan cycling design determines water temperature, and water temperature
affects all the other drive train components. Of course, there are other
factors such as chassis a/c condenser location. While I have never incurred
overheating problems I simply do not understand why I need to run a very
expensive engine in the top of the published temperature range. And I have not
been able to obtain a definitive answer from BB or any approved DD shop I have
contacted. So, I pressed on.
It is not a dragster you know?
I know, H/P rob , but that argument doesn't work in my case, because the fan is
gonna cycle at 195 degrees or 190 degrees, except when you pull the mountain, at
which time you need all the cooling you can get. That 5 degree variance means a
bunch in cooling the other components.
Mine is also different because it is a Royale conversion. That is why I am very
careful when offering advise. Many components are not in the standard location,
and wiring does not match BB schematics most of the time. However, I have very
few problems. They did a fine job.
Thanks again, and Jackson, WY is a beautiful place. Hope to get there in the
bus in summer.
Leroy Eckert
Niceville, FL
Sent: Sunday, March 04, 2007 8:38 PM
Subject: [WanderlodgeForum] Re: Coolant Pressure Control Cap
far it is working.
on.
> Engine Oil-215
> Retarder Temp- 220
working order.
one. LOL lol, lol
> Leroy Eckert
> Niceville, FL
> From: Fred Hulse
> Fred & Jeanne Hulse
> Morristown Arizona
03-04-2007, 15:16
Good idea. I have plenty of room to install a back up distilled water tank for
that purpose just in case. You never know when you might need some help. I
would be easy to do.
Thanks,
Leroy Eckert
Niceville, FL
Sent: Sunday, March 04, 2007 9:02 PM
bus
has
Alarmstat,
> far it is working.
pressed
> on.
doesn't
not
in
simply
> > Engine Oil-215
> > Retarder Temp- 220
pulling
your
> working order.
I
case.
> one. LOL lol, lol
> > Leroy Eckert
> > Niceville, FL
> > From: Fred Hulse
tied
hose!
> > Fred & Jeanne Hulse
> > Morristown Arizona
