Found another problem, solved Retarder problem
03-04-2007, 16:02
Hi All,
The problem I have had with the retarder is directly related to the new problem I have incurred... I did not notice it before, but the HWH pump motor was running as soon as I put on the master leveler switch... This when it was turned on would drop the voltage down to 11 volts on the volt gauge, which in turn would not let the retarder work, due to too low voltage for it to operate... was experimenting and when I turned on the level master the retarder would not work, turn it off and in a few seconds the alternator would recoup the voltage and the retarder would work, hearing distinctive clicks from the control box... Now, I am thinking the HWH pumps problem is the solenoids shorting internally to keep the motor running when flipping the switch... What do you all think??? Does it sound like the solenoids or do I look somewhere else??? All suggestions appreciated... TIA Sea Ya Larry NYC 84 35FCSB ________________________________________________________________________________\ ____ Don't pick lemons. See all the new 2007 cars at Yahoo! Autos. http://autos.yahoo.com/new_cars.html [Non-text portions of this message have been removed] |
03-05-2007, 03:59
I just was wondering why you would have the leveler on when you need
the retarder?? Jim Riordan 88WBWL XXV Stuart, Fl. --- In WanderlodgeForum@yahoogroups.com, Larry wrote: > > Hi All, > > The problem I have had with the retarder is directly related to the new > problem I have incurred... I did not notice it before, but the HWH pump > motor was running as soon as I put on the master leveler switch... This > when it was turned on would drop the voltage down to 11 volts on the > volt gauge, which in turn would not let the retarder work, due to too > low voltage for it to operate... was experimenting and when I turned on > the level master the retarder would not work, turn it off and in a few > seconds the alternator would recoup the voltage and the retarder would > work, hearing distinctive clicks from the control box... > > Now, I am thinking the HWH pumps problem is the solenoids shorting > internally to keep the motor running when flipping the switch... What > do you all think??? Does it sound like the solenoids or do I look > somewhere else??? > > All suggestions appreciated... > > TIA > Sea Ya > Larry > NYC > 84 35FCSB > > > > > > ______________________________________________________________________ ______________ > Don't pick lemons. > See all the new 2007 cars at Yahoo! Autos. > http://autos.yahoo.com/new_cars.html > > [Non-text portions of this message have been removed] > |
03-05-2007, 06:07
Hi Jim,
I have a leveling jack that continues to set off the warning buzzer when I start the CAT, it is annoying to listen to when troubleshooting the problems with the retarder... checking the level master I can see which jack has set off the alarm... I then drop the jack and get it in a position where it stops the buzzer, while testing for the retarder, this is when I discovered the voltage drop when the leveling master was on, and then I noticed the drop in voltage on the gauge when it was turned on and the increase when it was turned off... I have to get the jack fixed to stop the buzzer altogether, right now it is just a location of the jack against the stop that sets it off... I have been removing the sensor from the jack and cleaning the mating surface as well as the ground... It stops for a while and then it starts up again, I am getting close to getting it fixed, but not quite... I hope this answers your question...;-) Sea Ya Larry NYC 84 35FCSB ----- Original Message ---- From: jqrjr To: WanderlodgeForum@yahoogroups.com Sent: Monday, March 5, 2007 10:59:18 AM Subject: [WanderlodgeForum] Re: Found another problem, solved Retarder problem I just was wondering why you would have the leveler on when you need the retarder?? Jim Riordan 88WBWL XXV Stuart, Fl. --- In WanderlodgeForum@ yahoogroups. com, Larry wrote: > > Hi All, > > The problem I have had with the retarder is directly related to the new > problem I have incurred... I did not notice it before, but the HWH pump > motor was running as soon as I put on the master leveler switch... This > when it was turned on would drop the voltage down to 11 volts on the > volt gauge, which in turn would not let the retarder work, due to too > low voltage for it to operate... was experimenting and when I turned on > the level master the retarder would not work, turn it off and in a few > seconds the alternator would recoup the voltage and the retarder would > work, hearing distinctive clicks from the control box... > > Now, I am thinking the HWH pumps problem is the solenoids shorting > internally to keep the motor running when flipping the switch... What > do you all think??? Does it sound like the solenoids or do I look > somewhere else??? > > All suggestions appreciated. .. > > TIA > Sea Ya > Larry > NYC > 84 35FCSB > > > > > > ____________ _________ _________ _________ _________ _________ _ ____________ __ > Don't pick lemons. > See all the new 2007 cars at Yahoo! Autos. > http://autos. yahoo.com/ new_cars. html > > [Non-text portions of this message have been removed] > <!-- #ygrp-mlmsg {font-size:13px;font-family:arial,helvetica,clean,sans-serif;} #ygrp-mlmsg table {font-size:inherit;font:100%;} #ygrp-mlmsg select, input, textarea {font:99% arial,helvetica,clean,sans-serif;} #ygrp-mlmsg pre, code {font:115% monospace;} #ygrp-mlmsg * {line-height:1.22em;} #ygrp-text{ font-family:Georgia; } #ygrp-text p{ margin:0 0 1em 0; } #ygrp-tpmsgs{ font-family:Arial; clear:both; } #ygrp-vitnav{ padding-top:10px; font-family:Verdana; font-size:77%; margin:0; } #ygrp-vitnav a{ padding:0 1px; } #ygrp-actbar{ clear:both; margin:25px 0; white-space:nowrap; color:#666; text-align:right; } #ygrp-actbar .left{ float:left; white-space:nowrap; } .bld{font-weight:bold;} #ygrp-grft{ font-family:Verdana; font-size:77%; padding:15px 0; } #ygrp-ft{ font-family:verdana; font-size:77%; border-top:1px solid #666; padding:5px 0; } #ygrp-mlmsg #logo{ padding-bottom:10px; } #ygrp-vital{ background-color:#e0ecee; margin-bottom:20px; padding:2px 0 8px 8px; } #ygrp-vital #vithd{ font-size:77%; font-family:Verdana; font-weight:bold; color:#333; text-transform:uppercase; } #ygrp-vital ul{ padding:0; margin:2px 0; } #ygrp-vital ul li{ list-style-type:none; clear:both; border:1px solid #e0ecee; } #ygrp-vital ul li .ct{ font-weight:bold; color:#ff7900; float:right; width:2em; text-align:right; padding-right:.5em; } #ygrp-vital ul li .cat{ font-weight:bold; } #ygrp-vital a { text-decoration:none; } #ygrp-vital a:hover{ text-decoration:underline; } #ygrp-sponsor #hd{ color:#999; font-size:77%; } #ygrp-sponsor #ov{ padding:6px 13px; background-color:#e0ecee; margin-bottom:20px; } #ygrp-sponsor #ov ul{ padding:0 0 0 8px; margin:0; } #ygrp-sponsor #ov li{ list-style-type:square; padding:6px 0; font-size:77%; } #ygrp-sponsor #ov li a{ text-decoration:none; font-size:130%; } #ygrp-sponsor #nc { background-color:#eee; margin-bottom:20px; padding:0 8px; } #ygrp-sponsor .ad{ padding:8px 0; } #ygrp-sponsor .ad #hd1{ font-family:Arial; font-weight:bold; color:#628c2a; font-size:100%; line-height:122%; } #ygrp-sponsor .ad a{ text-decoration:none; } #ygrp-sponsor .ad a:hover{ text-decoration:underline; } #ygrp-sponsor .ad p{ margin:0; } o {font-size:0;} .MsoNormal { margin:0 0 0 0; } #ygrp-text tt{ font-size:120%; } blockquote{margin:0 0 0 4px;} .replbq {margin:4;} --> ________________________________________________________________________________\ ____ Do you Yahoo!? Everyone is raving about the all-new Yahoo! Mail beta. http://new.mail.yahoo.com [Non-text portions of this message have been removed] |
