Dash / chassis air conditioner on FC
03-07-2007, 10:39
Well, with it starting to get warm again in Texas, I'm contemplating
what to do with my Chassis a/c. I bought my 87FC35 last August and i know that without the dash a/c operational, it gets hot up front in the Texas summers. Here's what i do know about my dash a/c. 1. York compressor is locked up. No big deal. I've got it off and can put another one on. 2. Hoses on top of coach that connect the condensor to the fittings that come out of the roof are gone. Again, not a big deal. I can have those made easily. 3. Condensor will probably be fine if it is cleaned up and cleaned out, but I understand I will probably want to replace it with a new Red Dot condensor when I convert to r134A. Not too big of a deal, just a few $$. 4. Hoses to compressor from evaporator and condensor are 20 years old and could be bad. I"M WORRIED ABOUT THIS POTENTIAL PROBLEM. So, here are my questions. 1.I visually inspected the hoses at the compressor. I couldn't see any external cracks. BUT WHAT DO I DO IF I GET A NEW COMPRESSOR AND CONDENSOR INSTALLED AND FIND OUT THEY ARE LEAKING, especially running higher pressure r134a? I'd hate to spend a bunch of money (and time) only to have an a/c that still doesn't work. 2. How do the hoses currently get from the engine compartment to the overhead? 3. If I had to run new hoses, has anyone done that or seen that done and where do i run them? Inside the bus (and where)? Thanks! Alan Johnson 87FC35 |
03-07-2007, 11:35
Alan, I had the same concerns when I did my dash AC. I decided to go
ahead and rely on the existing hoses as they were well protected from exposure to UV/Ozone being run interior to the bus; that they held a vacume; and that I saw no way to get them replaced easily, my best thought was if needed run new lines up the windshield center seam or along a side pillar and cover up with some trim material. My AC hose guy pointed out that the possibility was that although the hoses were 20 years old, they likely had not been in actual "service and pressure load" for a big part of those 20 years....and had a even chance of working out OK. I have enjoyed dash ac for two summers and love it. I just have to live with the possibility of hose failure...all in all...i would recommend not bending/flexing them, do a good flush, pressure test, and if it the hoses hold...go with it. Someday I'll be doing phase II (hose replacement), but I'll wait for it. Frank 85FC33 Woodbridge, VA (snowing!!!) ll. --- In WanderlodgeForum@yahoogroups.com, "Alan" wrote: > > Well, with it starting to get warm again in Texas, I'm contemplating > what to do with my Chassis a/c. I bought my 87FC35 last August and i > know that without the dash a/c operational, it gets hot up front in > the Texas summers. > > Here's what i do know about my dash a/c. > 1. York compressor is locked up. No big deal. I've got it off and > can put another one on. > 2. Hoses on top of coach that connect the condensor to the fittings > that come out of the roof are gone. Again, not a big deal. I can > have those made easily. > 3. Condensor will probably be fine if it is cleaned up and cleaned > out, but I understand I will probably want to replace it with a new > Red Dot condensor when I convert to r134A. Not too big of a deal, > just a few $$. > 4. Hoses to compressor from evaporator and condensor are 20 years old > and could be bad. I"M WORRIED ABOUT THIS POTENTIAL PROBLEM. > > So, here are my questions. > > 1.I visually inspected the hoses at the compressor. I couldn't see > any external cracks. BUT WHAT DO I DO IF I GET A NEW COMPRESSOR AND > CONDENSOR INSTALLED AND FIND OUT THEY ARE LEAKING, especially running > higher pressure r134a? I'd hate to spend a bunch of money (and time) > only to have an a/c that still doesn't work. > 2. How do the hoses currently get from the engine compartment to the > overhead? > 3. If I had to run new hoses, has anyone done that or seen that done > and where do i run them? Inside the bus (and where)? > > Thanks! > Alan Johnson > 87FC35 > |
03-07-2007, 13:47
When I bought my 88 Bird other owners told me that the dash air in
these babies never works well. The PO had my unit at the factory in 04. They installed a new compressor and believe it or not left it with R12. We have used it driving through Texas in the low 90's as well as in Mexico at the same temps. Works great to about 90 to 92. Beyond that we use the roof air to supplement the cooling. It has never been charged since 04 and still is OK.. I am fortunate that here in Mexico R12 is still easily obtainable. Bruce 1988 FC35 |
03-07-2007, 14:45
Since we only have the 210hp version I didn't want the power or heat load on
the engine. I put a 15,000btu ac on the front, the front vent aimed into the overhead, and turn on the chassis ac fans to help with circulation. This keeps us very comfortable. Because of Kathy's job we always seem to travel at the wrong times, dead of winter and heat of summer. It does keep all the systems exercised! - Chuck Wheeler - 82 FC 31 SB Fort Worth, TX _____ From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Alan Sent: Wednesday, March 07, 2007 4:39 PM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Dash / chassis air conditioner on FC Well, with it starting to get warm again in Texas, I'm contemplating what to do with my Chassis a/c. I bought my 87FC35 last August and i know that without the dash a/c operational, it gets hot up front in the Texas summers. Here's what i do know about my dash a/c. 1. York compressor is locked up. No big deal. I've got it off and can put another one on. 2. Hoses on top of coach that connect the condensor to the fittings that come out of the roof are gone. Again, not a big deal. I can have those made easily. 3. Condensor will probably be fine if it is cleaned up and cleaned out, but I understand I will probably want to replace it with a new Red Dot condensor when I convert to r134A. Not too big of a deal, just a few $$. 4. Hoses to compressor from evaporator and condensor are 20 years old and could be bad. I"M WORRIED ABOUT THIS POTENTIAL PROBLEM. So, here are my questions. 1.I visually inspected the hoses at the compressor. I couldn't see any external cracks. BUT WHAT DO I DO IF I GET A NEW COMPRESSOR AND CONDENSOR INSTALLED AND FIND OUT THEY ARE LEAKING, especially running higher pressure r134a? I'd hate to spend a bunch of money (and time) only to have an a/c that still doesn't work. 2. How do the hoses currently get from the engine compartment to the overhead? 3. If I had to run new hoses, has anyone done that or seen that done and where do i run them? Inside the bus (and where)? Thanks! Alan Johnson 87FC35 [Non-text portions of this message have been removed] |
03-07-2007, 15:01
Alan: i converted my 1983 FC-35 and kept the same condenser. On my BB the hoses
run from the engine compartment behind the right hand panel and up the right hand column forward of the right hand glass.I don't think it would be to tough to run new hoses, but why? you may get 4- 5 yeras out of them. RE in Georgia 1983 FC-35 > > From: "Alan" > Date: 2007/03/07 Wed PM 05:39:05 EST > To: WanderlodgeForum@yahoogroups.com > Subject: [WanderlodgeForum] Dash / chassis air conditioner on FC > > Well, with it starting to get warm again in Texas, I'm contemplating > what to do with my Chassis a/c. I bought my 87FC35 last August and i > know that without the dash a/c operational, it gets hot up front in > the Texas summers. > > Here's what i do know about my dash a/c. > 1. York compressor is locked up. No big deal. I've got it off and > can put another one on. > 2. Hoses on top of coach that connect the condensor to the fittings > that come out of the roof are gone. Again, not a big deal. I can > have those made easily. > 3. Condensor will probably be fine if it is cleaned up and cleaned > out, but I understand I will probably want to replace it with a new > Red Dot condensor when I convert to r134A. Not too big of a deal, > just a few $$. > 4. Hoses to compressor from evaporator and condensor are 20 years old > and could be bad. I"M WORRIED ABOUT THIS POTENTIAL PROBLEM. > > So, here are my questions. > > 1.I visually inspected the hoses at the compressor. I couldn't see > any external cracks. BUT WHAT DO I DO IF I GET A NEW COMPRESSOR AND > CONDENSOR INSTALLED AND FIND OUT THEY ARE LEAKING, especially running > higher pressure r134a? I'd hate to spend a bunch of money (and time) > only to have an a/c that still doesn't work. > 2. How do the hoses currently get from the engine compartment to the > overhead? > 3. If I had to run new hoses, has anyone done that or seen that done > and where do i run them? Inside the bus (and where)? > > Thanks! > Alan Johnson > 87FC35 > > > |
03-08-2007, 06:25
The previous owner of my coach upgraded the chassis air to R134a --
but by the time I purchased it, the coolant had gone away after the coach sat for months on a dealer's lot, unused. (Seals tend to dry out under those conditions.) I had the system recharged. The dash air is not highly effective at general cooling -- the roof ACs are much better at that. However, especially when traveling into the sun (while driving south during the day or west in the afternoon), even when it is otherwise relatively cool, the "fishbowl" at the front of the coach can be uncomfortably warm. That's when the dash air can (and for me) does make a difference. In those conditions, it puts just enough cooling right where it's needed -- no need to fire up the generator and run the roof ACs. So, is it worth restoring/updating the dash air system -- that depends on what you might want. For me, I prefer to be on the cool side ... so it's important. Someone else, who might like it a little warmer, won't. Pete Masterson aeonix1@... '95 Blue Bird Wanderlodge WBDA 42' El Sobrante, CA On Mar 7, 2007, at 5:47 PM, birdshill123 wrote: > When I bought my 88 Bird other owners told me that the dash air in > these babies never works well. The PO had my unit at the factory in > 04. > They installed a new compressor and believe it or not left it with > R12. > We have used it driving through Texas in the low 90's as well as in > Mexico at the same temps. Works great to about 90 to 92. Beyond > that we > use the roof air to supplement the cooling. It has never been charged > since 04 and still is OK.. I am fortunate that here in Mexico R12 is > still easily obtainable. > > Bruce > 1988 FC35 [Non-text portions of this message have been removed] |
03-08-2007, 13:35
My ac compressor was removed prior to my purchasing the coach.
There is a second air intake in it's place which I believe does wonders for the 210 hp 3208. So I fire up the generator and use the roof ACs to cool things off. From other posts I have read the cost of running the generator is not much different than the added fuel consumption of the 3208 running the compressor. And the truth is that the 210hp 3208 needs every bit of hp it can muster when climbing a hill. Gardner 78FC33 --- In WanderlodgeForum@yahoogroups.com, "Chuck Wheeler" > > Since we only have the 210hp version I didn't want the power or heat load on > the engine. I put a 15,000btu ac on the front, the front vent aimed into > the overhead, and turn on the chassis ac fans to help with circulation. > This keeps us very comfortable. Because of Kathy's job we always seem to > travel at the wrong times, dead of winter and heat of summer. It does keep > all the systems exercised! > > > > - Chuck Wheeler - > > 82 FC 31 SB > > Fort Worth, TX > > _____ > > From: WanderlodgeForum@yahoogroups.com > [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Alan > Sent: Wednesday, March 07, 2007 4:39 PM > To: WanderlodgeForum@yahoogroups.com > Subject: [WanderlodgeForum] Dash / chassis air conditioner on FC > > > > Well, with it starting to get warm again in Texas, I'm contemplating > what to do with my Chassis a/c. I bought my 87FC35 last August and i > know that without the dash a/c operational, it gets hot up front in > the Texas summers. > > Here's what i do know about my dash a/c. > 1. York compressor is locked up. No big deal. I've got it off and > can put another one on. > 2. Hoses on top of coach that connect the condensor to the fittings > that come out of the roof are gone. Again, not a big deal. I can > have those made easily. > 3. Condensor will probably be fine if it is cleaned up and cleaned > out, but I understand I will probably want to replace it with a new > Red Dot condensor when I convert to r134A. Not too big of a deal, > just a few $$. > 4. Hoses to compressor from evaporator and condensor are 20 years old > and could be bad. I"M WORRIED ABOUT THIS POTENTIAL PROBLEM. > > So, here are my questions. > > 1.I visually inspected the hoses at the compressor. I couldn't see > any external cracks. BUT WHAT DO I DO IF I GET A NEW COMPRESSOR AND > CONDENSOR INSTALLED AND FIND OUT THEY ARE LEAKING, especially running > higher pressure r134a? I'd hate to spend a bunch of money (and time) > only to have an a/c that still doesn't work. > 2. How do the hoses currently get from the engine compartment to the > overhead? > 3. If I had to run new hoses, has anyone done that or seen that done > and where do i run them? Inside the bus (and where)? > > Thanks! > Alan Johnson > 87FC35 > > > > > > [Non-text portions of this message have been removed] > |
03-08-2007, 14:25
Gardner,
With your engine, you will not want to lose the HP to the AC compressor. The 2nd air intake really helps the 3208 NA engine... Those with more power (i.e. newer 'birds) might want to consider the trade off of 'dash' air vs. running the generator. With the 470 HP of the DD Series 60, I don't really notice the AC compressor demands except in very extreme circumstances. A little fan up on the dash might be nice for those sunny days.... Pete Masterson aeonix1@... '95 Blue Bird Wanderlodge WBDA 42' El Sobrante, CA On Mar 8, 2007, at 5:35 PM, Gardner Yeaw wrote: > My ac compressor was removed prior to my purchasing the coach. > There is a second air intake in it's place which I believe does > wonders for the 210 hp 3208. So I fire up the generator and use the > roof ACs to cool things off. From other posts I have read the cost > of running the generator is not much different than the added fuel > consumption of the 3208 running the compressor. And the truth is > that the 210hp 3208 needs every bit of hp it can muster when > climbing a hill. > > Gardner > 78FC33 <snip> [Non-text portions of this message have been removed] |
03-09-2007, 02:47
Thanks for your experiences and advice here! That really helps. I'm
going to try my luck with the existing hoses. I'll take it to a local shop and see if they hold a vacuum and have them cleaned out. If that looks good, i'll put on a new compressor and probably condensor, and (hopefully) go happily down the road as cool as I want to be. I did look into alternatives. There are aftermarket units that are made for trucks and tractors that I could have used. They were self-contained and the compressors would run off of 120v. After talking to one of these manufactures (http://www.danhard.com) I decided against it just because of capacity. The chassis one should put out around 36,000btu. While even the largest 120v one would be 15,000 btu. Thanks again, Alan |
03-09-2007, 03:21
134A likes more condenser, you can't have too much. I used the old hoses, new
blower motors and had to change the expansion valve, stuff got in it. Flush every thing you want to reuse and do up a new EV. It will all be good. MH ----- Original Message ----- From: Alan To: WanderlodgeForum@yahoogroups.com Sent: Friday, March 09, 2007 8:47 AM Subject: [WanderlodgeForum] Re: Dash / chassis air conditioner on FC Thanks for your experiences and advice here! That really helps. I'm going to try my luck with the existing hoses. I'll take it to a local shop and see if they hold a vacuum and have them cleaned out. If that looks good, i'll put on a new compressor and probably condensor, and (hopefully) go happily down the road as cool as I want to be. I did look into alternatives. There are aftermarket units that are made for trucks and tractors that I could have used. They were self-contained and the compressors would run off of 120v. After talking to one of these manufactures (http://www.danhard.com) I decided against it just because of capacity. The chassis one should put out around 36,000btu. While even the largest 120v one would be 15,000 btu. Thanks again, Alan [Non-text portions of this message have been removed] |
