How to clear codes?
03-09-2007, 12:36
How to clear codes?
Remember the problem I had with "check engine light" staying on ... I
found several corroded ground connections but the culprit turned out to be the connectors to the DDEC II unit. Not visibly corroded but first time I removed & then reconnected it fixed problem. I cleaned them well & applied a dab of "corrosion block". Now I need to clear all those bogus diagnostic codes. Can it be done without hooking into test instrument? Thanks, Steve & Kathy Enfinger 91 WBSA Newton, GA |
03-13-2007, 02:54
How to clear codes?
If I remember correctly the tech at DD told me that all you need to
do is put in reverse and then in drive. If you turn off all 12 volt power this should also clear. Jim Riordan 88 WLWB XXV Stuart, Fl. --- In WanderlodgeForum@yahoogroups.com, "Steve & Kathy Enfinger" > > Remember the problem I had with "check engine light" staying on ... I > found several corroded ground connections but the culprit turned out to > be the connectors to the DDEC II unit. Not visibly corroded but first > time I removed & then reconnected it fixed problem. I cleaned them well > & applied a dab of "corrosion block". > > Now I need to clear all those bogus diagnostic codes. Can it be done > without hooking into test instrument? > > Thanks, > > Steve & Kathy Enfinger > 91 WBSA > Newton, GA > |
03-13-2007, 04:29
How to clear codes?
Jim, I think Reverse is how the tranny codes clear???? The engine
codes stay stored but believe recent codes (read via blinks) can be cleared as you say, by turning off battery banks.??? I remember a RalphF post about code clearing??? The repair Steve made sounds like the repair Paul and Jo Carver made to correct their 92pt stay running problem. Paul removed and cleaned all the DDec connections and later replaced the engine batteries that had a short which was determined to contribute to causing problems with current and connections. The best way to test a battery for a short or issue is to charge and read each cell with a hydrometer. On my 94 pt the shoreChargers will not charge start batteries unless I flip on the dash switch to tie batteries banks together. GregoryO'Connor 94ptRomolandCa --- In WanderlodgeForum@yahoogroups.com, "jqrjr" > > If I remember correctly the tech at DD told me that all you need to > do is put in reverse and then in drive. If you turn off all 12 volt > power this should also clear. > > Jim Riordan > 88 WLWB XXV > Stuart, Fl. > > > --- In WanderlodgeForum@yahoogroups.com, "Steve & Kathy Enfinger" > > > > > Remember the problem I had with "check engine light" staying on ... > I > > found several corroded ground connections but the culprit turned > out to > > be the connectors to the DDEC II unit. Not visibly corroded but > first > > time I removed & then reconnected it fixed problem. I cleaned them > well > > & applied a dab of "corrosion block". > > > > Now I need to clear all those bogus diagnostic codes. Can it be > done > > without hooking into test instrument? > > > > Thanks, > > > > Steve & Kathy Enfinger > > 91 WBSA > > Newton, GA > > > |
