Replacing the pulley on a FC to fix the belt issues
03-12-2007, 02:27
I am going to purchase an 82FC 3208T that has no A/C belt due to what
the owner says was the tendancy for the belt to come off and take the other belts with it. He mentioned something about using a pulley off a Mack with 3 v-grooves to replace the 2 groove pulley and routing the belt differently to prevent the issues. Anybody out there know more details for this. I would like to get the parts ordered early and have them ready when I pick up the coach. Regards, Joe Desmond |
03-12-2007, 11:58
Joe:
I have a 1982 35 3208T aftermarket turbo engine installed.I have had no problems with belts coming off.I have removed my AC dash unit due to seized compressor bearing.You may want to check that.I updated to a Horton air fan clutch and updated my power sterring pump.If the compressor bearings are ok I would take a close look at the alignment of the pullys with a straight edge. Ken Kalmakoff 1982 35 3208t Richmond BC > > I am going to purchase an 82FC 3208T that has no A/C belt due to what > the owner says was the tendancy for the belt to come off and take the > other belts with it. He mentioned something about using a pulley off a > Mack with 3 v-grooves to replace the 2 groove pulley and routing the > belt differently to prevent the issues. > > Anybody out there know more details for this. I would like to get the > parts ordered early and have them ready when I pick up the coach. > > Regards, > Joe Desmond > |
03-12-2007, 12:42
What did you do to upgrade your power steering pump? What differences did you
notice? Kerry 82 Fc 35 Denver updated my power sterring pump.I. > Ken Kalmakoff > 1982 35 3208t > Richmond BC |
03-12-2007, 14:15
Joe:
My 83FC35 has a single belt to the AC compressor â it is a long one, prone to bouncing around a bit but like Ken mentioned, I have not had an issue with it coming off and taking the other belts with it. In fact, I have driven over 30K miles and never had a problem (with that belt). There is a modification some folks have done that involves replacing the alternator pulley with a three groove and using one of those grooves to run to the AC compressor â I have chosen not to jump into that mod for the following reasons â 1) I have not calculated the rpm difference/required at the compressor and 2) what size pulley (and magnetic clutch ) one would have to have on the AC compressor to obtain the correct speed, 3) one would probably have to adjust the position of the AC compressor to allow the new belt configuration to properly align with the alternator pulley and 4) then how does on adjust tension of this belt, probably have to modify the AC compressor mount to allow for a tension adjustment or mount a tension idler somewhere. I have chosen to run with the factory configuration, properly adjusted and aligned, it seems to work fine. But, properly engineered and installed the mod would be an improvement over the long bouncy belt. Harry Saddock 83FC35 South Windsor, CT --- In WanderlodgeForum@yahoogroups.com, "fourrubberfeet" > > Joe: > I have a 1982 35 3208T aftermarket turbo engine installed.I have had no > problems with belts coming off.I have removed my AC dash unit due to > seized compressor bearing.You may want to check that.I updated to a > Horton air fan clutch and updated my power sterring pump.If the > compressor bearings are ok I would take a close look at the alignment > of the pullys with a straight edge. > Ken Kalmakoff > 1982 35 3208t > Richmond BC > > > > > I am going to purchase an 82FC 3208T that has no A/C belt due to what > > the owner says was the tendancy for the belt to come off and take the > > other belts with it. He mentioned something about using a pulley off > a > > Mack with 3 v-grooves to replace the 2 groove pulley and routing the > > belt differently to prevent the issues. > > > > Anybody out there know more details for this. I would like to get > the > > parts ordered early and have them ready when I pick up the coach. > > > > Regards, > > Joe Desmond > > > |
03-12-2007, 14:27
you may want to call BB there are two belts on the compressor one short one
long, i will get the nunbers if i can. re brake FC-35 > From: "hsaddock" > Date: 2007/03/12 Mon PM 08:15:08 EST > To: WanderlodgeForum@yahoogroups.com > Subject: [WanderlodgeForum] Re: Replacing the pulley on a FC to fix the belt issues > > Joe: > My 83FC35 has a single belt to the AC compressor â it is a long one, > prone to bouncing around a bit but like Ken mentioned, I have not had > an issue with it coming off and taking the other belts with it. In > fact, I have driven over 30K miles and never had a problem (with that > belt). > > There is a modification some folks have done that involves replacing > the alternator pulley with a three groove and using one of those > grooves to run to the AC compressor â I have chosen not to jump into > that mod for the following reasons â 1) I have not calculated the rpm > difference/required at the compressor and 2) what size pulley (and > magnetic clutch ) one would have to have on the AC compressor to > obtain the correct speed, 3) one would probably have to adjust the > position of the AC compressor to allow the new belt configuration to > properly align with the alternator pulley and 4) then how does on > adjust tension of this belt, probably have to modify the AC > compressor mount to allow for a tension adjustment or mount a tension > idler somewhere. I have chosen to run with the factory > configuration, properly adjusted and aligned, it seems to work > fine. But, properly engineered and installed the mod would be an > improvement over the long bouncy belt. > > Harry Saddock > 83FC35 > South Windsor, CT > > > --- In WanderlodgeForum@yahoogroups.com, "fourrubberfeet" > > > > > Joe: > > I have a 1982 35 3208T aftermarket turbo engine installed.I have > had no > > problems with belts coming off.I have removed my AC dash unit due > to > > seized compressor bearing.You may want to check that.I updated to a > > Horton air fan clutch and updated my power sterring pump.If the > > compressor bearings are ok I would take a close look at the > alignment > > of the pullys with a straight edge. > > Ken Kalmakoff > > 1982 35 3208t > > Richmond BC > > > > > > > > I am going to purchase an 82FC 3208T that has no A/C belt due to > what > > > the owner says was the tendancy for the belt to come off and take > the > > > other belts with it. He mentioned something about using a pulley > off > > a > > > Mack with 3 v-grooves to replace the 2 groove pulley and routing > the > > > belt differently to prevent the issues. > > > > > > Anybody out there know more details for this. I would like to > get > > the > > > parts ordered early and have them ready when I pick up the coach. > > > > > > Regards, > > > Joe Desmond > > > > > > > > > |
03-12-2007, 16:06
Joe. I purchased an 82 FC35 a few weeks ago. The A/C compressor on mine looks
brand new,(shiney black) . Although I haven't tried mine yet, it looks like a York. These compressors weigh a ton, and are prone to vibrate, so it wouldn't surprise me if that belt did fly off. I'd check the mounts, make sure they're not cracked, throw a belt on try it out. Just remember that system needs pressure to kick the clutch on, so make sure it's engauging and not just spinning the pulley, and if it's seized I'd look into some later model aftermarket compressor that's half the size and weight. (maybe a rotary model) I'm not sure if this would work, or if there is a conversion already been done, but it may be worth checking out. Good luck. Jimmy hsaddock My 83FC35 has a single belt to the AC compressor â it is a long one, prone to bouncing around a bit but like Ken mentioned, I have not had an issue with it coming off and taking the other belts with it. In fact, I have driven over 30K miles and never had a problem (with that belt). There is a modification some folks have done that involves replacing the alternator pulley with a three groove and using one of those grooves to run to the AC compressor â I have chosen not to jump into that mod for the following reasons â 1) I have not calculated the rpm difference/required at the compressor and 2) what size pulley (and magnetic clutch ) one would have to have on the AC compressor to obtain the correct speed, 3) one would probably have to adjust the position of the AC compressor to allow the new belt configuration to properly align with the alternator pulley and 4) then how does on adjust tension of this belt, probably have to modify the AC compressor mount to allow for a tension adjustment or mount a tension idler somewhere. I have chosen to run with the factory configuration, properly adjusted and aligned, it seems to work fine. But, properly engineered and installed the mod would be an improvement over the long bouncy belt. Harry Saddock 83FC35 South Windsor, CT --- In WanderlodgeForum@yahoogroups.com, "fourrubberfeet" > > Joe: > I have a 1982 35 3208T aftermarket turbo engine installed.I have had no > problems with belts coming off.I have removed my AC dash unit due to > seized compressor bearing.You may want to check that.I updated to a > Horton air fan clutch and updated my power sterring pump.If the > compressor bearings are ok I would take a close look at the alignment > of the pullys with a straight edge. > Ken Kalmakoff > 1982 35 3208t > Richmond BC > > > > > I am going to purchase an 82FC 3208T that has no A/C belt due to what > > the owner says was the tendancy for the belt to come off and take the > > other belts with it. He mentioned something about using a pulley off > a > > Mack with 3 v-grooves to replace the 2 groove pulley and routing the > > belt differently to prevent the issues. > > > > Anybody out there know more details for this. I would like to get > the > > parts ordered early and have them ready when I pick up the coach. > > > > Regards, > > Joe Desmond > > > --------------------------------- Finding fabulous fares is fun. Let Yahoo! FareChase search your favorite travel sites to find flight and hotel bargains. [Non-text portions of this message have been removed] |
03-12-2007, 16:11
I changed the pump because the seal was leaking and I had blown the
seal twice.The original pump has what looks like a bronze bushing with a lip seal on the out side.The new pump [ RA2X ] has the seal and a sealed bearing on the outer shaft.I de-rated the by pass relief to 1750PSI to match the HF64 steering box.It did not change preformance. Ken Kalmakoff 1982sb 35 3208t Richmond BC > > What did you do to upgrade your power steering pump? What differences did you notice? > > Kerry > 82 Fc 35 > Denver > > updated my power sterring pump.I. > > Ken Kalmakoff > > 1982 35 3208t > > Richmond BC > |
03-14-2007, 01:41
Joe,
I removed the A/C compressor in our FC due to freon leaks in the condenser hoses and the estimated cost of updating/repairing a system that wouldn't cool the whole coach in Louisiana/Texas summers anyway. I replaced the A/C drive belt with a second one between the crank and radiator fan. There is a 3208 belt data drawing in the files section you may refer to on this change. Most belt problems I've had on our coach is with the power steering belt slipping during low speed turns. I open up the front of the coach to check belts for condition and tension annually. This spring, I'm going to look into a two groove pulley for the power steering pump to see if it will improve the situation. Regards, Eric in San Antonio 84FC35SBWL2 --- In WanderlodgeForum@yahoogroups.com, "Joe" > > I am going to purchase an 82FC 3208T that has no A/C belt due to what > the owner says was the tendancy for the belt to come off and take the > other belts with it. He mentioned something about using a pulley off a > Mack with 3 v-grooves to replace the 2 groove pulley and routing the > belt differently to prevent the issues. > > Anybody out there know more details for this. I would like to get the > parts ordered early and have them ready when I pick up the coach. > > Regards, > Joe Desmond > |
03-14-2007, 03:01
Power Steering Specialists in Columbus OH did the pulley up date for my 83. A
new pump shaft is required and a dedicated Blue Bird pulley. OE on 87 and up. The two belt pulley is 6.5" dia., pump runs a little slower, less likely to cavitate. MH ----- Original Message ----- From: Eric Johnson To: WanderlodgeForum@yahoogroups.com Sent: Wednesday, March 14, 2007 6:41 AM Subject: [WanderlodgeForum] Re: Replacing the pulley on a FC to fix the belt issues Joe, I removed the A/C compressor in our FC due to freon leaks in the condenser hoses and the estimated cost of updating/repairing a system that wouldn't cool the whole coach in Louisiana/Texas summers anyway. I replaced the A/C drive belt with a second one between the crank and radiator fan. There is a 3208 belt data drawing in the files section you may refer to on this change. Most belt problems I've had on our coach is with the power steering belt slipping during low speed turns. I open up the front of the coach to check belts for condition and tension annually. This spring, I'm going to look into a two groove pulley for the power steering pump to see if it will improve the situation. Regards, Eric in San Antonio 84FC35SBWL2 --- In WanderlodgeForum@yahoogroups.com, "Joe" > > I am going to purchase an 82FC 3208T that has no A/C belt due to what > the owner says was the tendancy for the belt to come off and take the > other belts with it. He mentioned something about using a pulley off a > Mack with 3 v-grooves to replace the 2 groove pulley and routing the > belt differently to prevent the issues. > > Anybody out there know more details for this. I would like to get the > parts ordered early and have them ready when I pick up the coach. > > Regards, > Joe Desmond > [Non-text portions of this message have been removed] |
03-15-2007, 01:06
Mike,
Sounds like what I need to do. Did you have to modify pump mount to align the belts? Did Power Steering Specialists do the modifications on your pump? Thanks for the information. Eric in San Antonio 84FC35SBWL2 --- In WanderlodgeForum@yahoogroups.com, "Mike Hohnstein" <MHOHNSTEIN@...> wrote: > > Power Steering Specialists in Columbus OH did the pulley up date for my 83. A new pump shaft is required and a dedicated Blue Bird pulley. OE on 87 and up. The two belt pulley is 6.5" dia., pump runs a little slower, less likely to cavitate. > MH > ----- Original Message ----- > From: Eric Johnson > To: WanderlodgeForum@yahoogroups.com > Sent: Wednesday, March 14, 2007 6:41 AM > Subject: [WanderlodgeForum] Re: Replacing the pulley on a FC to fix the belt issues > > > Joe, > I removed the A/C compressor in our FC due to freon leaks in the condenser hoses and > the estimated cost of updating/repairing a system that wouldn't cool the whole coach in > Louisiana/Texas summers anyway. I replaced the A/C drive belt with a second one > between the crank and radiator fan. There is a 3208 belt data drawing in the files section > you may refer to on this change. > > Most belt problems I've had on our coach is with the power steering belt slipping during > low speed turns. I open up the front of the coach to check belts for condition and tension > annually. This spring, I'm going to look into a two groove pulley for the power steering > pump to see if it will improve the situation. > > Regards, Eric in San Antonio > 84FC35SBWL2 > --- In WanderlodgeForum@yahoogroups.com, "Joe" > > > > I am going to purchase an 82FC 3208T that has no A/C belt due to what > > the owner says was the tendancy for the belt to come off and take the > > other belts with it. He mentioned something about using a pulley off a > > Mack with 3 v-grooves to replace the 2 groove pulley and routing the > > belt differently to prevent the issues. > > > > Anybody out there know more details for this. I would like to get the > > parts ordered early and have them ready when I pick up the coach. > > > > Regards, > > Joe Desmond > > > > > > > > [Non-text portions of this message have been removed] > |
