What is standard 50amp while traveling
04-30-2005, 10:43
Question for the group....
What is the (normal)standard 50amp camp ground hook ups while
traveling? Is the 50amp boxes in most camp grounds 120v @ 50amp or
240v @ 50amp?
Does one always want to make sure before hooking up if there seems to
be not a general 50amp standard (check for 120v vs. 240v)? Most camp
grounds have 120v @ 30amp & 20amp as I recall, but not for sure on the
50amp hook ups that handle the big coaches.
I am wanting to do the 50amp box (for my coach)at my house along with
the additional 30amp box to cover all needs (in case some one comes to
see me), thus the reason for the question. It seems I've alway got by
with the 30amp box hook ups and I want to cover all situations of need.
Gregg Kizer
New Castle,IN
85PT40
04-30-2005, 11:28
50a @ 240 is nice when you can find it in a campground. That's what I have in
the 'bird house. Far as I know all 50a is 240 unless the electrician made a
major mistake.
Mike Hohnstein
Germantown WI
83FC35
Sent: Saturday, April 30, 2005 5:43 PM
Subject: [WanderlodgeForum] What is standard 50amp while traveling
240v @ 50amp?
Gregg Kizer
New Castle,IN
85PT40
Yahoo! Groups Links
a.. To visit your group on the web, go to:
04-30-2005, 12:48
250 (240) volt.
This is the main link you need:
http://users3.ev1.net/~crossstitch/RVWiring/wiring.html
More misc info:
http://www.phrannie.org/surge.html
http://www.phrannie.org/battery.html
http://www.phrannie.org/phredex.html
Dan 94 BMC 37'
--- In WanderlodgeForum@yahoogroups.com, "Gregg Kizer"
or
> 240v @ 50amp?
to
camp
with
comes to
got by
need.
> Gregg Kizer
> New Castle,IN
> 85PT40
04-30-2005, 15:16
As Mike said: 50a/240v unless improperly wired.
- Jeff Miller
http://www.wanderlodge.net
http://www.millercoachworks.com
> 240v @ 50amp?
to
camp
with
to
by
need.
> Gregg Kizer
> New Castle,IN
> 85PT40
05-01-2005, 02:16
Hi Gregg (KB9BG @ arrl),
Best way to check/tell is to first plug in your
Surge protector. I have to add that close to 1/2 of
50A I've plugged my Surge protector into in last
couple of years do not register the 240 that they
should.
For others not familiar, each leg of a 50 amp
connection carries 120 volts when measured/compared to
the neutral and/or the ground. The 240 volts referred
to, is developed when each of the 120 volt legs is
"out of phase" (60 cycle alternating current) with the
other leg such that when measured from one hot leg to
the other hot leg, 240 volts is the net result.
Notice, neither measured to the neutral nor the
ground.
My experience is that many campgrounds have
"jerry-rigged" their older pedestals so each 50 amp
leg has its own breaker but many actually carry the
same phase and therefore 240V is really not present
across the two hot legs. All this is just academic in
most cases, as most coaches do not need or use 240V
but be careful in either case.
John Suter
WA5QCT (formerly WA9JPU & WA4JAB)
> ups while
> 120v @ 50amp or
> 240v @ 50amp?
> if there seems to
> 240v)? Most camp
> not for sure on the
> house along with
> some one comes to
> I've alway got by
> situations of need.
> Gregg Kizer
> New Castle,IN
> 85PT40
Do You Yahoo!?
http://mail.yahoo.com
05-01-2005, 13:16
> 240v @ 50amp?
Greg,
You've gotten good advice in the previous posts.You can also go to:
<http://users3.ev1.net/~crossstitch/RVWiring/wiring.html>
for info on 30/50 amp wiring. Good technical explanations and
pictures/schematics. I used the info when I wired my garage/homebase.
I plan on carrying my Klein ac/dc voltage meter with me from now on
to check before plugging in and flipping the switch.
If yahoo truncates the url I've posted it in the links under RV
Wiring.
Jim Owens 77 FC33SB (Gas)
Sweetie's Dream
Lake of the Ozarks, MO
