Aux, generator capability questions, propane injection and slack adjusters...
03-22-2007, 03:08
Howdy gang,
I bought a Yamaha 2800 watt generator to use on Pokey when I need
some AC power, but don't want to run the big genset.
Here is a link to the specs:
http://www.amazon.com/Yamaha-800-Watt-Po...Generator-
YG2800IH/dp/tech-data/B0000614UI/ref=de_a_smtd/002-0603847-9582408
My hope had been that it would also run one A/C unit, but when I try,
it REALLY pulls the generator down and the overload light comes on. I'm
at 7800" and have had trouble with the effect of altitude on generators
before (read loss of power and efficiency). Should a 2800 watt
generator with a 125V/30 amp outlet run one A/C unit (basement
Cruiseairs)? They run fine otherwise.
Other than that, everything on Colorado is good, spring is springing
and Pokey is ready for the road. I finally got my propane injection
setup installed. Noticeable power difference, I'm anxious to see how it
affects the fuel economy. Also, should an 81 FC35 have automatic slack
adjusters? They have grease fitting on them. Any and all help is
greatly appreciated. Doug n' Pokey
Doug Engel, Gunnison, CO, 1981 FC35SB, "Pokey"
03-22-2007, 03:58
Can you tell us some more about your propane injection system? How is
it set up? Under what circumstances do you use it? What measurable
difference do you experience? Does it raise EGT's? If so, how much?
How hard was the install?
Kerry
82 FC 35
Denver
it
> affects the fuel economy. Doug n' Pokey
03-22-2007, 04:36
Pokey is NA and I do not run an EGT, so I can't answer that. I tapped into the
house propane tank, ran it unregulated into a propane regulator and then into a
soleniod valve, from there it runs thru copper tubing and into the top of the
air cleaner. I had to fiddle with orifice size and pressure, but am running it
at ablut 5 PSI. Since the regulator contriols flow, the initial problem I had wa
too small an orifice, I don't think you can go too big. I have a switch on the
dash and flip it on at highway speeds or when accelerating, ususally not under
2000 RPM. The difference is subtle, but very apparent. It runs smoother, takes
fuel and accelerates better.
After talking to a chemist friend (who lost me but understood what I had
done), he said it has someting to do with a shorter carbon chain in propane
compared to diesel. The introduction of propane into the fuel/air mixture allows
the diesel to start to burn at a lower temp/sooner and burn more completely.
What I understand is that it should not adversely affect the EGT or engine as a
whole in any way, at least not at the level I run it. In fact at idle, if I turn
it on, the engine actually seems to miss, so there is some point at which the
addition of propane will offset the air/fuel mixture in a negative way, so there
does not seem to be any chance of a "runaway" situation.
I still have to fiddle with the "right" amout. At highway speeds, you can
reach a point where I think you not gaining anything, just using more and
pumping it out the tailpipe.
Doug n' Pokey
Kerry
82 FC 35
Denver
it
Doug Engel, Gunnison, CO. 1981 FC35SB "Pokey"
Looking for earth-friendly autos?
Browse Top Cars by "Green Rating" at Yahoo! Autos' Green Center.
