RCA backup camera
03-23-2007, 23:00
RCA backup camera
Bob,
Only the power switch is still active and I use it to power up the LCD monitor. Rest of controls are on the monitor which fits exactly in the same hole. George Morris at Bleakley did the installation. He worked at BB on the WL line for many years and is a real wizard with vintage birds. Old cable was left in because of labor considerations to remove. I had the same symptoms with the old tube monitor, blooming picture and the longer the set stayed on, the worse it became. The Sony with sound makes communications when maneuvering with a helper a cinch. Think I've answered all. Ed McDowell 89FC35 Bonaire, Ga [Non-text portions of this message have been removed] |
03-24-2007, 02:44
RCA backup camera
Hi ED,
Do you have the model numbers and manufacturers of the camera and display ?? Does it fit in the same cut out in the over head, as the old display??? Bill 88 FC --- In WanderlodgeForum@yahoogroups.com, "Ed McDowell" wrote: > > Bob, > > Only the power switch is still active and I use it to power up the LCD > monitor. Rest of controls are on the monitor which fits exactly in the same > hole. George Morris at Bleakley did the installation. He worked at BB on > the WL line for many years and is a real wizard with vintage birds. Old > cable was left in because of labor considerations to remove. I had the same > symptoms with the old tube monitor, blooming picture and the longer the set > stayed on, the worse it became. The Sony with sound makes communications > when maneuvering with a helper a cinch. Think I've answered all. > > Ed McDowell > 89FC35 > Bonaire, Ga > > > [Non-text portions of this message have been removed] > |
